Old 10-07-2012, 10:56 PM   #12
05wrxSTiguy
Member#: 334426
2005 STI
do you have any pics? how did you secure the key to the tumbler? Zip tie?
Originally Posted by DTM21 View Post
Pretty much. You take the bottom plastic shroud off and place the key right under the switch. I found that you have to mount it with the key facing the driver and as close to the switch as possible. Luckily there is a metal bracket that is used as a wire tray that works perfect
You don't have an STI...WRX's got them starting in 06, STI's in 05.
05wrxSTiguy is offline   Reply With Quote
