Old 11-29-2012, 11:34 AM   #1
02 wrx roar
Member#: 199600
Default Rhd Bugeye 505hp 452tq Finsihed
Ok im gonna start off with a little back ground on me and the car just for those who wondered how i desided to do this... back in 2007 when i was going to School i bought this car at the end of my schooling and i have been slowly building it sense, first starting off by doing all the bolt ons and everything possible for the 2.0 with out pushing it past the line of destruction, you will see in my pics below the ones with the motor in was the 2.0. I at the time was doing as much as i could with out building the motor, i wanted it to look good and still get it down the highway.. i got the car to hit 322whp and 289wtq on a evo 3 16g... then came all the porting and a good road tune and i sqeezzed alittle after that.. i did not make it back to the dyno i focused on makeing the tune perfect by having my laptop with me everyday to make the small changes that for a year or so while i started gathering for something more.
finally i desided to go and tare the car down and do a 2.5 swap about a month past and the car was just a roler at that the time i had sold everything off it..shortly after i linked up with a guy who was parting out his 05 sti that was a cover car for dsport...i quickly jumped on it and began to make the trip to michigan to get what i needed..after my 16 hour trip to and back from virgina i started to assemble the drive line i had purchessed a dccd 6speed and the controlls, rear diff., drive shaft, and axles along with some carbon goodies..while i was there i had looked at some other stuff he had for sale couple motors and a sweet rhd clip..
Soon after returning home i made the guy a offer on a motor,and had it shipped to me.. i was so excited to tear into to it only to find that it was trashed,i was so aggervated i called the guy to tell him and he told me i cant do a refund but if i wanted a good deal on any other parts he would help me out.I proposed that if he allowed me 500 bucks from the motor ill part it out and make the rest up. he agreed...i then proceeded to tell him i wanted him to send me the RHD clip... then the real project began haha.. In two days i had my car gutted the clip stripped..I also had the everything welded in and i had to start wireing it after deciding to flip my factory harness over and use the wrx harness i began cuting and soldering everything for weeks straight every day i cut and sodered and repeat...long story short its al almost done just finshing up the heads and the built motor is going in and exhaust is gonna get made and fueling finshed..... then for the cage and it ready to hit the street..
Final numbers 505/452
LINK FOR DYNO VIDEO-https://plus.google.com/100347370782183201881/posts/J5jh29p1UFv
SO HERES THE MODD LIST
ENGINE
-MANLEY PISTONS, coated tops
-EAGLE ESP RODS W/ AGED 625 arp rod bolt upgrade
,ACL RACE BEARINGS,
FILE FITTED RINGS,
KILLER BEE PICK UP TUBE,
09 11MM OIL PUMP,
DECKED AND CLEANED
PERSISION 58/58 BALL BEARNING TURBO WITH 4INCH PORTED HOUSING AND VBAND OUTLET, 4 BOLT UP PIPE
CUSTOM HEADER AND UPPIPE WITH SLIP FIT
CUSTOM DOWN PIPE
TXS FROUNT MOUNT,
CRAWFORD AIR OIL SEPERATOR
PORTED AND POLISHED MANIFOLD/TGV DELETE/COOLANT LINE AND FITTING DELETE
PHENOLIC SPACERS
POWDERCOATED
TORQUE SOLUTIONS ENGINE MOUNTS
TORQUE SOLUTIONS PITCH MOUNT
GOD SPEED TURBO BLANKET
CUSTOM AIR BOX
HALLMAN BOOST CONTROLLER
PORTED THROTTLE BODY
-HEADS
BRIAN CROWER 280 CAMS,
BRIAN CROWER SPRINGS AND RETAINERS
ARP STUDS
PORTED POLISHED AND CHAMBER MATCHED
SUPER TECH 1MM+ VALVES INT. EXH INNCONLE AND A 3 ANGLE VALVE JOB RADIUS CUT ON EXHAUST
ALSO COATED CHAMBERS AND VALVE FACES
DECK AND CLEANED
FUEL SYSTEM
PERRIN V2 TOP FEED RAILS
INJECTOR CLINIC 1100CC
AREOMOVTIVE 340LPH IN TANK PUMP
FUEL LAB PRESSURE REGULATOR W/ -AN FITTINGS
-6 AREO SPACE BREADED LINE
KENSLER FUEL FILTER
SNOW METH PREFORMACE KIT
DRIVELINE
05 STI 6SPEED
ACT PRO LIGHTEND FLYWHEEL
COMPETITION STAGE 4 SIX PUCK DUEL SPRUNG CLUTCH
DSS ALUM. DRIVE SHAFT
STI REAR DIFF
CUSTOM HYBRID AXLES
COBB SHORT THROW w/ STI PISTON KNOB
SUSPENION
SET OF TEIN MONO FLEX COILOVERS
THE REST CAN WAIT HAHA
BRAKES
STOP TECH BIG BRAKE KIT W/ SLOTTED ROTORS
BRADED STOP TECH LINES
BODY
FRONT LIP/AND SPLITTERS/ALUM. UNDERTRAY
CUSTOM FROM CRASH BEAM AND TETHERS
CUSTOM MADE HID PROJECTORS
EYE LIDS,
PAINTED SIDE SKURTS
REAR SPATS
STI SCOOP
HELLA TONES
MIRO 398 18/9.5/+20
TIRES 235 40 18
JDM GRILL
CUSTOM ROLED FENDERS
I-EMBLEM
CARBON SPLITERS
TINTED FOGS
JDM GRILLE
CUSTOM SIDE SPILTERS
REAR DIFFUSER
JDM RAIN GAURDS
VORTEX GENERATORS
HOOD SHOCKS
04-05 STI TAILLIGHTS
DULUCK LIPPED CARBON TRUNK
REAR WINDOW SPIOLER
AUDIO/INTERIOR
PIONEER HEAD UNIT
BOSTON ACOUSTIC DOOR SPEAKERS
ALPINE TYPE S 12
500w ALPINE AMP
BATTERY RELOCATION
CUSTOM HARNESS BAR
SIMPSON RACE BELTS
CARBON WRAPED DASH
AEM EGT GAUGE
AEM WIDEBAND
AUTOMETER BOOST GAUGE
AUTOMETER OIL PRESSURE GAUGE
FACTORY UP GRADE GAUGES VOLT/ BOOST/OIL TEMP
ILL ADD MORE AS I GO
heres some pics of the car b4 during and after i will load up more from the swap as well
02 wrx roar is offline   Reply With Quote
