Originally Posted by al_s14
This is why i remove pipe plugs and blow out/brake clean out all passages on all block/head jobs. Both block and head, a must. But one plugged passage at the end of the line wouldn't cause that kind of pressure build up that it would blow past seals, oil would just bleed out the other orifices in the head, its not a completely one way street. There is something else
Still this sounds odd, get pictures. Why are you so sure its coming from the cam seal?? Did you take timing covers off and watch for spray/drip as you crank or run the engine? There is avcs line behind the timing cover too
Yes I have the side covers off the just pouring out from around the back of the right intake cam. Think is it didnt do they befor I have the new valves and springs put in. So has to be trash in there somewhere right ? I might try to take vcover off and see what I can see but probly be easyer with motor out
