Originally Posted by Dayekuang123
This should bolt up on my base model with no problems right?
If yes this is definitely gonna be my next mod.
I believe you will also need end links, since your base Impreza has no RSB at all.
For those of us upgrading a 16 mm RSB to a 19 mm RSB, we can continue to use our existing end links, and just replace the bar and bushings. But the base Impreza has no bar, and therefore has no end links.
I'm sure someone will correct me if I'm wrong about this.
