Originally Posted by jroa82
Hey guys I just finish installing my Defi racer Gauges in my '12 WRX and everything is working fine but I think that my gauges are too dim.
This is how I have my fuses connected:
1) constant 12v-fuse #3 (red cables)
2) swiched 12v-fuse#4 IG2(orange cables)
3) Ilumination-fuse #16 ILM
Do you guys have any Ideas if this is a issue or something I may have done wrong? if is an issue, do you guys have any ideas how to fix it ?
Thanks for all the help in anticipation
were you following the step provided in this thread? i'm pretty sure you're taping the wrong switched fuse
O.C.D.
Constant 12v - Fuse # 3 - DOOR LOCK
Switched 12v - Fuse # 26 - IG2
Illumination/Dimmer - Fuse # 16 - ILLUMINATION
or you could also try
CTSPARKY (STI)
http://forums.nasioc.com/forums/show...1&postcount=80
Orange # 4
Red #24
White #14
both should yeld the same results, i believe i'm using the fuses O.C.D. suggested.
