Just in case anyone was wondering why they run coolant throught the throttle-body: It is to prevent icing. Not because it is cold outside like in the winter time. Any time air goes from an area of higher pressure to an area of lower pressure, it drops in temperature. If you cruise for extended periods of time without moving the throttle plate, it can actually stick in that position for a few seconds! Summer or winter...
