Originally Posted by zer0psi
I'm a little confused by the 3063. I'm guessing that's a 30R with a .63 a/r, but which 30R? There's the 3071, 3076, and 3082, all named by their 71mm, 76mm, and 82mm compressor wheels respectively.
The 3082 is my choice...I'd imagine with the .63 you'd make 400hp @ less than 28psi, but then again I'm used to USDM fuels/tuning/dynos. With the .82 you'll lose spool but gain power and top end overall. I think you should be ok.
im confused i thought all gt30r's had 52mm compresser wheels? or are they 52 lb wheels or something? thats different from compresser wheels.
what is the difference between the two???
me is confuuused.
Chris
