Originally Posted by Matt Monson
Doesn't change where it will run at freeway speeds. If you are referring to using it on the track, it might give you enough, but I would personally run a gearchart before commiting.
Right, comment was meant for track. My typical usage will be general street and some rallyx. AutoX and track use would be as time <cough cough> permits.
Reasonable Hwy cruising in 5th is a priority. This 5th gear/FD combo would be essentially the same as the stock RS with the benefit of the rocketship inducing first through fourth. I can't wait
-Rob
