I just installed the 4pots today. What cross shaped clip are you referring to. I had the 4 big pins and then a clip that goes through both sides of the pins (doesn't look very stable). I also got 3 (I think I should of had four) clips that cliped in the corner of the pads. Are these the clips you are talking about? They look like they hold the pad and shim together. Installed one on the outside pad on the top and the other on the inside pad on the bottom. The right side I olnly had one to put on Does anyone have a drawing or picture.
[This message has been edited by PRODRIVEN (edited May 30, 2001).]
