Old 06-02-2006, 10:21 AM   #1
ejh25
Member#: 65267
Default Helix 264 or V8 cams
I need to make a decision quickly so any replies are welcome.
I will be running a GT30r .63 A/R on a built block and V8 big port heads. The questions is: should I go with a Helix 264 cam or stick with the V8 cams?
I won't be running AVCS in either situation.
My biggest concern is usable power and lower end grunt. I had previously thought the V8 cam would be my best bet but now am rethinking things.
Thanks,
Eric
ejh25 is offline   Reply With Quote
Old 06-02-2006, 12:15 PM   #2
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Do a mixed cam set, 272 intake and 264 exhaust. that's what I am running and love it. if you don't want to do that do the 264's, they will open up the potential for far greater power up top.
If you are not running AVCS then don't run the V8 cams.
mick_the_ginge is offline   Reply With Quote
Old 06-02-2006, 02:21 PM   #3
ejh25
Member#: 65267
I'm just a little concerned that the I will loose some low end with the 264. I know the V8's were intended to be used with AVCS, but it was my understanding that the V8 cams were more aggressive than any USDM cam.
Thanks Mick for the reply.
- Eric
Old 06-02-2006, 03:12 PM   #4
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Are you building the shortblock or is it stock compression?
What do you consider "low end" power?
With 264 you will lose low end even more with the 272s. The real question is how much low end are you willing to give up for a kick in the pants a little higher in the rpms?
What redline are you planning to set? That should also be a big factor in determing what cams to run. You probably won't be able to fully reap the benefits of 272s unless your reving to 8k or above.
264 should be a good choice for stock or nearly stock redline (sub 8k) on stock compression.
Brad
MY99 2.5GT is offline   Reply With Quote
Old 06-02-2006, 04:00 PM   #5
ejh25
Member#: 65267
Redline will be 7500-8000 and compression will be bumped up a hair.
Old 06-02-2006, 04:23 PM   #6
ShaggyGT
Member#: 19221
2005 Legacy GT (STi)
UR35R/Rotated Intake Mani
Go with the Helix cams. Easier to get and if you have problems you dont have to hunt down another cam or pay a premium to get it.
-Matt
ShaggyGT is offline   Reply With Quote
Old 06-02-2006, 11:31 PM   #7
ejh25
Member#: 65267
ShaggyGt,
Are you saying that I should go with the Helix if I have a cam sprocket (sp?) problem? I was thinking the V8 cams in the V8 heads would be easy and non-problematic. I guess the Helix 264 wouldn't be very expensive and I could do it easily.
I can easily afford the Helix 264 cams but I was thinking the V8 cams would be better suited for my purpose, I wicked fast spooling 2.5
I am all ears to advice...
I will make my decision over the weekend b/c the motor is in the build process and I am psyched.
Old 06-04-2006, 09:57 AM   #8
ShaggyGT
Member#: 19221
Originally Posted by ejh25
ShaggyGt,
I am saying that in the event that something might happen to one of the cams, I doubt it, but something did it would be easier to get a replacement Helix cam than a Version 8 cam. Not only that but the price between the two should be quite a bit and availibility is very limited on V8 valvetrain parts. Plus with the Helix cams you have several combinations to choose from whereas Version 8 cams are what they are.
-Matt
Old 06-05-2006, 09:53 AM   #9
ejh25
Member#: 65267
-Matt
Thanks for the advice.
I have decided on sticking with the V8 cams for now, hopefully I won't run into any problems.
The install should be complete by the end of July with dyno results a month later.
Old 06-05-2006, 10:32 PM   #10
sonic rx
Member#: 33457
Chapter/Region: PRSIC
HAHA EVERYONE KNOWS
DYNO JET IS NOT REAL WHP
here is my first tune on 20 psi with port and polished wrx heads and helix cams
sonic rx is offline   Reply With Quote
Old 06-03-2006, 11:54 PM   #11
Sadisticracer1
Member#: 96724
how high should your compression be if you want to redline around 8500 and what cams are exactly needed? can stock ones we used to bump to that rpm range if the heads are port & polished stg3 with a 3angle valve job on all ports?
Sadisticracer1 is offline   Reply With Quote
Old 06-04-2006, 12:09 AM   #12
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
272 sounds perfect for 8500+ redline. You will need shimless buckets or shim under buckets as well as stiffer valve springs and retainers. Some very good port and pollish work will be much need to run smoothly that high in the revs. I would have them rework the combustion chamber as well to smooth out some of the rough angles.
Old 06-04-2006, 01:00 AM   #13
jvcastillo21
Member#: 14321
2002 GT35rrrrrrr
Imprezzzza
Phil from Element is running Kelford 272's in his stock heads. I believe they are standard USDM STi. Stock meaning STOCK, no modifications at all.
jvcastillo21 is offline   Reply With Quote
Old 06-16-2006, 12:22 PM   #14
Sadisticracer1
Member#: 96724
i will have stiffer valves springs and retainers to go along with the port and ppolish and 3 angle valve job. the combustion chambers are being honed and darton sleeved. would this work out with the stock cams to raise the redline safely or do they need to be modded to the 272's? where could i get 272's and are they usually really expensive thanks.
Old 06-07-2006, 04:44 PM   #15
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
What's the lift and duration of the v8 cams? If you don't know - you'd better find out.
PeteDucati is offline   Reply With Quote
Old 06-08-2006, 09:49 AM   #16
ejh25
Member#: 65267
Slight change of plans... I will be running a Hydra and utilizing the AVCS with along with a slight bump in compression.
Old 06-08-2006, 11:44 AM   #17
AK'S REX
Member#: 12163
Let me know how this works for you. I never ran AVCS on my V8 heads.
As for me I'm about to get the Helix 264s and drop them in V8 heads. The main reason, I broke one of the JDM cams and gear, and the helix stuff is easy to come by and about the same price. I'll post with results if I ever finish
-Adam
AK'S REX is offline   Reply With Quote
Old 06-15-2006, 12:25 AM   #18
InfamousDX
Member#: 25413
-Adam
Holy crap... almost hte exact same situation as me. I broke the pass. side exhaust cam gear and the Helix prices are so sick that I might try it. For me, it'll be a drag car so I want the power up top over my stock jdm v7 cams/valvetrain. Hopefully it'll work out nicely, although without AVCS.
InfamousDX is offline   Reply With Quote
Old 06-16-2006, 12:00 PM   #19
babyblue22681
Member#: 51981
03 fast wrx-e55
blue/desert silver
go with crower....stg 2
babyblue22681 is offline   Reply With Quote
Helix 264 Cams, Who Has Them? spoolinsuby Built Motor Discussion 2 09-29-2006 09:54 AM
BUILD YOUR MOTOR! Helix 264 Camshafts, +2mm Long Rod Ratio Kit, Forged Components Gruppe-S Engine/Power/Exhaust 2 08-22-2006 09:45 PM
Spec C cams for V7 or V8 heads sjl1614 Private 'Wanted' Classifieds 0 02-05-2006 09:46 PM
264 or 272 Delta cams? bstarr Normally Aspirated Powertrain 4 01-30-2006 07:41 PM
