Welcome to the North American Subaru Impreza Owners Club Monday December 5, 2016
View Poll Results: How often do you clean your MAF sensor?
Once a month or more 23 3.50%
When i change my oil 91 13.85%
When it needs it, I can tell by my EM or my butt dyno 159 24.20%
NevAR 387 58.90%
Multiple Choice Poll. Voters: 657. You may not vote on this poll
Old 06-06-2006, 02:14 AM   #1
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Default How often do you clean your MAF sensor?
I would like to know how often you clean your maf sensor. I usually do mine about once a month or so.
modaddict is offline   Reply With Quote
Old 06-06-2006, 02:16 AM   #2
UndertoW101
Member#: 100587
2012 WRX 5D Ltd.
I've never cleaned mine
UndertoW101 is offline   Reply With Quote
Old 06-06-2006, 02:21 AM   #3
Calitri-Boost
Member#: 109090
08 IS-F
WFC Mbr # 004
If you have a dry type air filter you wont need to clean it near as much.
Calitri-Boost is offline   Reply With Quote
Old 06-06-2006, 02:57 AM   #4
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Not true. Bone stock STI with 2000miles, still with stock filter - and the MAF sensor was filthy when I pulled it out to swap the intake.
nhluhr is offline   Reply With Quote
Old 06-07-2006, 01:53 AM   #5
Calitri-Boost
Member#: 109090
08 IS-F
WFC Mbr # 004
It can be true when people buy K&N or other brand oiled filters and load them up with way too much oil. The MAF will get dirty very fast and the car will run like poop.
Old 06-06-2006, 02:56 AM   #6
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
I try to do it somewhat regularly which I would say is about once quarterly.
FYI, CRC's "MAF Sensor Cleaner" product, at $5.99 a can, is 100% identical to their "QD Electronics Cleaner" at $3.99 a can.
Old 06-06-2006, 03:17 PM   #7
Illusive
Member#: 90436
2005 STI
Obsidian black pearl
brake clean for 1.69 a can ftw.
you should clean your maf before you get any kind of tune, and before / after doing mods to the car, and generally speaking once per oil change is enough to keep it clean and reading properly. (typically 3-4 mo)
Illusive is offline   Reply With Quote
Old 06-06-2006, 04:39 AM   #8
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
once a year
jigga is offline   Reply With Quote
Old 06-06-2006, 08:52 AM   #9
jays05
Member#: 78165
05 STI 35r + e85
I usually do mine about a week after cleaning the filter.
jays05 is offline   Reply With Quote
Old 06-06-2006, 03:22 PM   #10
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
check the ingredients on brakleen. It is definitely NOT the same and not very safe for the plastic and rubber on the maf sensor.
Old 06-06-2006, 07:34 PM   #11
modaddict
Member#: 95840
sold to a good bud
awaiting next car
I just cleaned my MAF w/ brakekleen. I will agree it will eat plastic and swell rubber, thats why i didnt spray any on the o-ring. I think ill invest in some other type of cleaning solution though.
Old 07-03-2006, 10:05 AM   #12
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
Carb cleaner eats plastic and rubber. Brakeclean is safe for plastics. Ask a mechanic.
gabedude is offline   Reply With Quote
Old 07-03-2006, 10:56 AM   #13
sonic rx
Member#: 33457
Chapter/Region: PRSIC
HAHA EVERYONE KNOWS
DYNO JET IS NOT REAL WHP
i have never cleaned mine
sonic rx is offline   Reply With Quote
Old 06-06-2006, 07:35 PM   #14
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
just fyi - if you do mess up that little o-ring, replacements are hard to find. i had to resort to using a completely different o-ring and "making it fit"
Old 08-01-2009, 03:13 AM   #15
TreyS
Member#: 42478
2004 WRX STi
White/Gold
Question
What other o-rings can be used? I have one that is nicked and needs to be replaced. Don't want to buy a new MAF if I don't have to.
TreyS is offline   Reply With Quote
Old 08-22-2010, 03:43 AM   #16
BLKonBLK05
Member#: 249379
2005 STI, black ....
hence the screen name
[QUO...TE=nhluhr;14049719]just fyi - if you do mess up that little o-ring, replacements are hard to find. i had to resort to using a completely different o-ring and "making it fit"[/quote]
If anything happeneds to that o ring it can get messed up...but I found the exact one at Lowe's ....supprisingly it works good as hell...2 for 55 cent..
BLKonBLK05 is offline   Reply With Quote
Old 01-03-2011, 11:53 PM   #17
Columbo
Member#: 17328
2002 WRX Wagon 4EAT
Appliance White
Ahem....120k miles. Never cleaned. But I'm REALLY PISSED that I paid $450 to YIMI SPORT in Santa Clarita for a "dyno-tune" and they did NOT check/clean this first!!! ARRGGHHHHH!!! (I told them the air filter was okay...OEM). I will call and ask them if a re-tune is the proper thing to do. (Yeah, they'll probably say nope!) They only got me +6 hp, but I think +10 ft.lbs. of torque on a stock set up.
Columbo is offline   Reply With Quote
Old 06-06-2006, 07:53 PM   #18
Evil STI
Member#: 36792
2015 Z/28 (Vader)
Gold chains & meatballs
Every 3000 miles or less. Something so simple shouldn't be overlooked.
Evil STI is offline   Reply With Quote
Old 06-06-2006, 07:55 PM   #19
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
does cleaning it so often damage the MAF?
silver arrow is offline   Reply With Quote
Old 06-06-2006, 08:01 PM   #20
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
not if you do it correctly.
which means:
-carefully remove it from the intake
-spray cleaner onto the IAT probe (the part you can see that looks like a tiny kernel of red corn)
-spray cleaner indirectly up into the hollow of the tube to clean the heater wires. You should avoid blasting the heater wires directly, as it could damage them somehow.
-let air dry
-carefully replace MAF, beign sure to get it pointed the correct direction (plug in front, not in back)
-reset ECU to clear out the AF Learned trims
Old 06-06-2006, 08:13 PM   #21
modaddict
Member#: 95840
sold to a good bud
awaiting next car
which means:
-let air dry
+1^^^^
and im really surprised that 'most' people that have polled do not clean their MAF. I guess as a Ford tech, and seeing how many engines have been DESTROYED by faulty MAF sensors...I am over cautious.
BTW, by DESTROYED, it has ALWAYS been from an engine running lean. 'usually' from dirty air filters (lack of maintenance by the customer) and/or oil bath filters.
Old 07-16-2008, 01:45 AM   #22
Fred Fredburger
Member#: 2539
On my '05 (and probably most/all of the others) it's impossible to put the MAF sensor in backwards. The body of the MAF is closer to one screw than it is the other.
Fred Fredburger is offline   Reply With Quote
Old 07-22-2008, 02:34 PM   #23
Spootypuff
NASIOC SUPER Supporter
n00b jesus
Member#: 200000
2012 Wrangler
I just cleaned it yesterday and there is a noticeable difference. It was pretty dirty, and now it seems to push me back harder than before. Also I can hear alot more of the bpv
Spootypuff is offline   Reply With Quote
Old 04-09-2009, 08:31 AM   #24
SBW
Member#: 38469
07 LGT spec-b
Crystal Grey Metallic
which means:
-let air dry
instructions for those who cant check the first page
SBW is offline   Reply With Quote
Old 02-08-2010, 02:24 AM   #25
bryantkalagian
Member#: 226391
01 Silverado
which means:
-let air dry
noob question: what are the heater wire and the hallow?
bryantkalagian is offline   Reply With Quote
How often do you change your synth oil in your wrx D-I-Z-Z-L-E Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 58 12-03-2012 09:30 PM
How often do you wash your hair (if you have any)? HoRo1 Off-Topic 33 12-02-2003 04:22 PM
How often do you clean your K&N/reusable air filter??? megatron Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-18-2002 12:05 PM
how often do you wash your car? inpreza kid Canada Region Forum 12 02-24-2001 06:07 PM
How often do you clean your rims? John2.5RS General Forum Archive 12 05-22-2000 09:02 AM
