#1 |
Member#: 96448
Vehicle:02 WRX VF34 |
My friend recently upgraded his stage 2 WRX to stage 4.
AP VF34 map VF34 ported JDM STi TMIC Perrin turbo inlet Borla header catless TBE Uppipe Stock intake Stock T-hose and "pill" from TD04 Now, problem is that he's only able to hit 12psi at max... that's what's read on AP live meter and defi boost gauge. Can someone point to where he should look as far as fixing the boost problem? He doesn't hear any whining or high pitch sounds which would point to potential leak problem... Your help is appreciated. |
#2 |
Member#: 46241
RMIC
Vehicle:- RIP SDF-1 |
I'd point him to a protuner to have a custom map made for those extra parts he's running. Unless he wants to take them off and get back to Cobb's spec.
He'll make more power with a tune, way more. |
#3 |
Member#: 84188
Vehicle:05 legacy caravan full of kids now |
over ported turbo, pre turbo exhaust leak, or weak wastegate. try a helper spring and check for leaks
#4 |
Member#: 103320
Vehicle:2005 wingless aspen white |
data log. see if your ECU is hanging the WG open at 100%. I'd bet on a boost leak somewhere. See the EM forum sticky's for the DIY leak finder.
| Thread Tools | |
| Display Modes | |
| WTB: gear set or just 3rd and 4th gear of 02 wrx | AFBeefcake | Private 'Wanted' Classifieds | 12 | 10-16-2006 10:20 PM |
| Access Port Stage 2 only hitting 13.3psi in 3rd gear | Airboy | Western Canada | 2 | 07-17-2006 11:30 PM |
| Those of u with td06-20g or 18g on sti-in 4th gear at what rpm do u hit full boost? | odin1 | Factory 2.5L Turbo Powertrain | 38 | 11-22-2005 12:43 AM |
| Stock (?) MY04 WRX pulling 12psi+ in 1st gear.. that's not good, right? | woody77 | Factory 2.0L Turbo Powertrain | 19 | 10-22-2005 08:42 AM |
| TurboXS Stage 2 loss of power in 4th gear | camdoc | Factory 2.0L Turbo Powertrain | 28 | 09-04-2002 10:48 AM |
