Old 07-08-2006, 01:46 AM   #1
lvperuano
Member#: 82264
Default passing smog
I have an 02 wrx with a straight exaust. MY CEL is constanly on. I went to autozone to clear the light so I can get a smog check. Does anybody know for how long does the light stay off after clearing codes?
lvperuano is offline   Reply With Quote
Old 07-08-2006, 02:00 AM   #2
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
before you get flamed. cel's may come on at any time. there is no time limit. your basicly rolling the dice before the next one if you get them all the time.
hybrid gti 2 is offline   Reply With Quote
Old 07-08-2006, 03:38 AM   #3
digitalboy40
Member#: 63328
02 WRX
Blaze Yellow
you can buy the cel fix for like $15
digitalboy40 is offline   Reply With Quote
Old 07-08-2006, 04:16 AM   #4
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
yet he does not list the reason for the cel's coming on or the code it has. yet that might explain it. That generally points to catless or something.
Old 07-08-2006, 07:09 AM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
What state are you located in? Do you have OBDII inspection? If you do, clearing the code will NOT allow you to pass because doing so resets the readiness monitors so they will show a "not complete" status at the time of inspection. Once the monitors have set the CEL will probably be back on since the true problem has not been corrected.
You need to know the exact code that has been set. If it is P0420 for catalyst inefficiency you'll need to install a mechanical fix.
Also depending on the inspection procedure and how thorough the inspector is, you may still fail a visual inspection.
Passed smog w/out 3rd cat forcefed Newbies & FAQs 9 07-22-2003 06:01 PM
Passing smog with a stock exhaust...check it out jarelee Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 05-20-2003 10:01 PM
Pass smog check with these mods?? SoBaLo Southern California Impreza Club Forum -- SCIC 9 02-18-2002 12:53 PM
headers/exhaust and passing smog GTkrockett Normally Aspirated Powertrain 12 07-28-2001 05:36 AM
Bay Area Smog: Has any with RS+TURBO passed SMOG? lo0pback Bay Area Impreza Club Forum -- BAIC 10 05-10-2001 04:35 PM
