Welcome to the North American Subaru Impreza Owners Club Thursday December 8, 2016
Old 07-14-2006, 12:22 PM   #1
e11ys
Member#: 77106
'02 Brodozer
'11 Outback 3.6R
Default Seal replacement instructions?
Anyone have a link to a detailed install write-up, or shop manual scans, for installing the cam and crank seals on a 2.5RS? I don't want to attempt it until I have some instructions in front of me. Thanks!
e11ys is offline   Reply With Quote
Old 07-15-2006, 09:09 PM   #2
e11ys
Member#: 77106
'02 Brodozer
'11 Outback 3.6R
Bump?
Old 07-16-2006, 01:34 AM   #3
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
A haynes/chiltons manual has plenty of info. They're a cake walk. The timing belt is the hardest part about changing them out. On my 2.2 I used a small flat head screw driver, pried out the old ones and stuck in the new with a tiny bit of oil on the outside. Best to use a socket that is the same outside diameter as the seal to drive it in square.
Plays_With_toys is offline   Reply With Quote
Old 07-16-2006, 10:26 AM   #4
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Default Install Cam & Crank Seals
An important part to not screw up is when removing the seals, be extra careful not to scratch the bore in which the seal will call home.
Removal:
A lot of people use a straight screwdriver and work their way around the seal a little at a time to gradually pry the seal out. You can also buy a seal pull for less that $10, but I've never used one.
Replacement:
Wipe the seal bore clean and then take your finger to rub a small amount engine oil around the seal bore. Also, lightly coat the new seal with oil and this will help the seal go in smoothly. A large socket or piece of PVC pipe that is about the same diameter of the seal is good driving the seal in square. I just take a socket, piece of wood, and hammer and slowly tap the seal in. They also make a seal driver kit for cheap, again, I've never used one.
If you really don't trust yourself, here is a link to the tool I mentioned above, but are not necessary for this job. Good luck.
Lisle Seal Puller $6.99
Craftsman Seal Puller $9.99
Snap-on Seal & Bushing Driver Set
^ You can find these really cheap and www.harborfreight.com
-Charles-
ImprezaVA is offline   Reply With Quote
Old 07-16-2006, 06:55 PM   #5
Skidd
Member#: 1853
GC6 Supercharged
STM
This has helped me out in my cam swap. It's not exactly instructions for replacing seals, but it might help.
www.cobbutning.com/instructions.html
Skidd is offline   Reply With Quote
Alternator replacement instruction? Dougeefresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-09-2004 03:54 PM
Window replacement instructions. Help needed. ProdriveRex Interior & Exterior Modification 4 05-20-2004 02:04 PM
Looking for EJ25 SOHC Timing Belt replacement Instructions Rickd Service & Maintenance 1 10-07-2003 02:26 PM
rotor and brake replacement instructions Lil'Blue Brakes, Steering & Suspension 2 09-19-2003 03:32 PM
Strut Replacement instructions bbaerotek Brakes, Steering & Suspension 3 02-18-2002 08:35 PM
