Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 07-27-2006, 09:57 AM   #1
jr4jc
Member#: 76834
2005 STI
crystal metalic gray
Default DP and drop in and access port
i've done a drop in K+N and about to install an invidia down pipe and then want to get an access port - if anybody knows of one for sale let me know
2005 sti
my question is after getting the access port do i NEED to get the car tuned and what will be the difference between the car w these mods and access port and these mods and access port and TUNED????
jr
jr4jc is offline   Reply With Quote
Old 07-27-2006, 10:39 AM   #2
Assassin4457
Member#: 96773
04 WRX, RIP GC8
Subaru Stars
Well for the Stage II you will need those upgrades you've listed plus a catback. Once you have all those, you can run the Off the Shelf (OTS) Stage II map from Cobb on the Access Port and have no problems. It even allows an Up-pipe and a crank pulley with that map with no negative effects.
The difference if you get a pro-tune with that setup is perhaps a bit more power, but again as I said, its safe to run those and the OTS map, so no tune is necessary.
I personaly wouldnt get a tune unless you plan to do more to the car, protunes are expensive and to me are only for people in search of serious power. But no, you dont NEED one with that setup using the off the shelf maps, just dont forget the cat-back.
If you start to want more power after this and plan a turbo swap or something like that, a protune is definitely required.
This is how it is for WRX's at least, if anything is different for the STI's, it will all be specified which upgrades are safe to use with their maps on the map notes on this page : http://cobbtuning.com/sti/accessport/index.html
Click map notes for whichever map you plan to use, and all the information you will need should be in there.
Assassin4457 is offline   Reply With Quote
Old 07-27-2006, 10:47 AM   #3
Assassin4457
Member#: 96773
04 WRX, RIP GC8
Under closer inspection of the STi map notes (first time reading them) they dont mention anything about the crank pulley or up-pipe like they do for the WRX, so you might want to ask one of the STi guys using the AP about that.
APS & COBB in stock and ready to ship. Access Ports FREE overnight shipping. Fine Line Imports Engine/Power/Exhaust 7 11-11-2008 04:01 PM
COBB and APS all in stock Access Ports FREE overnight air shipping Fine Line Imports Engine/Power/Exhaust 10 07-16-2008 04:25 PM
2008 WRX, 2007-2008 LGT and SPEC-B, 2007-2008 FXT and 2008 STi .COBB ACCESS PORT! RallySport Direct Engine/Power/Exhaust 2 12-12-2007 02:34 PM
Back in Stock 05 and 04 STI Cobb Access Ports! Spun Autosports Engine/Power/Exhaust 3 05-04-2006 08:38 AM
