Old 07-28-2006, 07:50 PM   #1
DomozitoLK
Member#: 58668
2015 WRX Limited
Lightning Red
Default STI vs WRX oem turbo inlet pipe (size difference?)
I searched but didn't see anything comparing the two. Are there any difference between USDM WRX, STI, JDM STI, and Spec-C turbo inlet pipes? Is there any advantage to using any of the oem STI inlet pipe/hose on a WRX?
Thanks!
DomozitoLK is offline   Reply With Quote
Old 07-28-2006, 10:05 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
All those pipes are the same, so switching would be madness.
Old 08-09-2006, 06:27 PM   #3
DomozitoLK
Member#: 58668
2015 WRX Limited
Lightning Red
Just to let you guys know...I ended up buying a v8 Spec-C inlet hose and it is noticeably bigger than the standard WRX version. I pasted my inlet next to the Perrin/WRX comparison shot from Perrin's website to show the size difference.
The main issue I notice right away is that one vaccuum nipple is missing. I will have to check what connects to that one. I may just have to T-it off of the one near the bracket I guess.
Old 07-28-2006, 10:17 PM   #4
Crawdads
Member#: 30907
SWP GDB-G
they are all junk...all of them will tear where they clamp onto the turbo inlet.
(although, doesn't one model of JDM STi use a silicone inlet? maybe the s203/204?)
Crawdads is offline   Reply With Quote
Old 07-29-2006, 02:03 AM   #5
DomozitoLK
Member#: 58668
2015 WRX Limited
Lightning Red
The S204 has the red inlet but not sure what it's made of...
Old 07-29-2006, 01:08 AM   #6
flatusboy
Member#: 63023
02 WRX
I just saw a STi (JDM??) silicon inlet at Super Autobacs in Buena Park for $1166.00 (thats right, didnt misplace the decimal)
Looked pretty in the Cherry Blossom color though ;-)
flatusboy is offline   Reply With Quote
Old 07-29-2006, 02:51 AM   #7
distorto
Top Scoob 024
Member#: 56364
RIP stompr :(
bagged vulvva
Originally Posted by flatusboy
$1166.00
you should have bought 2!
distorto is offline   Reply With Quote
Old 07-29-2006, 03:11 AM   #8
esteve
Member#: 28716
2006 STI
The one on display looked more like Toilet Plunger Red to me.
esteve is offline   Reply With Quote
Old 07-29-2006, 01:30 AM   #9
r0n
Member#: 91839
They're the same. Be sure to get what you want, because after you install it you wont want to install it ever again, lol.
r0n is offline   Reply With Quote
Old 07-29-2006, 01:43 AM   #10
DomozitoLK
Member#: 58668
2015 WRX Limited
Lightning Red
Good to know...thanks for the info!
Old 06-11-2014, 11:48 AM   #11
audiRS4ever
Member#: 225123
2005 Saab 9-2x Aero
Arctic Silver
Bump - If you're still on the forums, did you figure out any way to deal with that extra vacuum nipple? I have a WRX with a ripped inlet (the one pictured on the right) and accidentally bought a spec C inlet (in the middle) to replace it - The two problems I have are
1., the WRX inlet contains the extra nipple by the bracket where the spec-c one does not, and
2. the hose near the top of the spec-c inlet that comes out the top and goes to the left (pictured as just a hole on the WRX inlet here) is smaller in diameter than the WRX one.
Any help would be appreciated!
audiRS4ever is offline   Reply With Quote
wtb oem turbo inlet pipe krazballr247 SCIC Private Classifieds 3 09-09-2009 12:14 AM
wrx oem turbo inlet, maf sensor arrowscooby Engine/Power/Exhaust 19 10-24-2008 08:26 PM
greddy type s bov, gutted uppipe, sti engine harness, oem turbo inlet and xover pipe arrowscooby Engine/Power/Exhaust 20 09-26-2008 07:55 PM
8cm stock location turbo's and turbo inlet pipe size? mpower22 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 06-17-2005 12:48 PM
need an OEM turbo inlet pipe goingfor400HP New England Impreza Club Forum -- NESIC 3 09-27-2003 10:08 PM
