Old 09-14-2006, 07:47 PM   #1
OB2
Member#: 51500
1999 impreza rs-t
sylver
Default suspension setup for 2.5RS for track days?
What is the best setup (Camber' Caster) for road track day on a 99RS???
OB2 is offline   Reply With Quote
Old 09-15-2006, 11:29 AM   #2
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
depends on what you have.....
I have Hotbits 46mm coilovers with front/rear camber plates. I maxed out caster (around 3-3.5) and run -3 camber in the front and -1.5 in the back with 0 toe all around.
I had tire rubbing issues (in the rear) where the tire would hit the coilover rings... so 1.5 is the max i could get. It will be different for next year since I'll run 225-50-15 track tires or remove the helper springs on the coilovers.
Robin2 is offline   Reply With Quote
Old 09-15-2006, 12:13 PM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
You'll probably have more replies (and find more info) if you post/search in the Motorsports forum.
Old 09-15-2006, 06:09 PM   #4
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Stock, or with aftermarket bits?
Just get as much negative front camber as you can with 0 toe all around.
My cgm sti hood for your 2.5rs cgm hood, and my cgm sti wing for 2.5rs wingless NYC Sti_ck_IT Private 'Wanted' Classifieds 15 08-16-2007 10:42 PM
AVO turbo kit for 2.5RS for So. Cal pickup asusimpreza Private 'For Sale' Classifieds 0 06-29-2005 10:00 PM
stromung track pipe for 2.5rs rsracer2005 Private 'For Sale' Classifieds 15 02-02-2005 01:08 PM
2.5RS-T Track times AntonioS Normally Aspirated with bolt-on Forced Induction Powertrain 26 12-06-2003 05:36 PM
2000 BRP 2.5RS for sale w/ suspension tach Bay Area Impreza Club Forum -- BAIC 1 08-14-2001 06:58 PM
