Old 11-07-2001, 08:12 PM   #1
Ardrossan
Member#: 12055
Unhappy Twoing WRX behind RV with RV mounted tow hitch
Can any one help me find the under car brackets for 2002 wrx? All the suppliers that i have contacted tell me that there is nothing available?
Is it possible to use brackets for a regular Impeza?
Brgds
Ardrossan is offline   Reply With Quote
Old 11-07-2001, 08:26 PM   #2
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Unhappy Good bye tranny..
your AWD system isn't going to like you after you've towed your vehicle with all 4 wheels on the ground. If you're going to do any long-distance towing of your WRX, I strongly suggest you getting a trailer and carrying your WRX on that.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 11-08-2001, 02:23 AM   #3
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
You will have to put it on some sort of contraption with no wheels touching the ground
Old 11-08-2001, 06:43 AM   #4
Marquis
Member#: 64
1999 Impreza 2.5RS
Rally Blue Pearl
Why is that? There's some mechanism that I'm obviously not understanding. What's the difference between what he wants to do and rolling along in neutral after you've accelerated? It's not like any one or pair of wheels is spinning faster (i.e., like would happen if two wheels were off the ground).
Please explain...
Marquis is offline   Reply With Quote
Old 11-08-2001, 09:52 AM   #5
Foxbat
Member#: 654
2003 WRX, Silver
'08 Tribeca, Brown
Check your owners manual about towing. Basically, you can not two your Subarus with any wheels on ground w/o risk of damage the tranny. And if you think all four wheels are always rotate in the same speed, you are wrong. It is ture only if you go straight lines w/o any turns.
Foxbat is offline   Reply With Quote
Old 11-08-2001, 09:56 AM   #6
Ardrossan
Member#: 12055
Unhappy
This is a reply I rec'd from Subaru???
Dear Mr. Betts:
Thank you for taking the time to contact us. I am not aware that Hitch Suppliers do not have a tow bar for the '02 WRX models. The bodies of all of the '02 Impreza models are the same, so if one is available for the '02 Impreza, then that is applicable to your '02 Impreza WRX Wagon.
AWD Subaru vehicles with manual transmision can be towed with all four wheels on the ground and the transmission in neutral or with ALL FOUR WHEELS OFF the ground on a trailer with the parking brake firmly set. Towing must NEVER be attempted with only TWO wheels ON the ground or TWO wheels ON a dolly. Distance and speed will not create any concerns.
When towing a manual transmission model with all four wheels on the ground, the steering must NOT be locked. Move the ignition key to the first position away from 'LOCK' and confirm that the steering wheel can be turned from one side to the other.
Other precautions:
* The Parking Brake must be released when towing with any wheels on the ground.
* Auxiliary Brake energizers may be required to preserve the braking effectiveness of the motor home. The additional load of the 'dinghy' will increase braking distance. This type of equipment is available through motor home dealers and/or camping equipment/hitch retailers.
Please consult with these experts for your specific application and usage.
Thanks for the opportunity to assist. Best wishes!
John J. Mergen
Subaru of America, Inc.
YOUR ORIGINAL MAIL:
I wish to to tour my WRX behind my motor home, using a tow bar
which keeps all four wheels on the road.
But everyone tells me that the brackets that fit underneath the car are
not available for the WRX 2002. Can I use brakets that
a regular Impreza.
Regards
David Betts
Old 11-08-2001, 03:30 PM   #7
Marquis
Member#: 64
1999 Impreza 2.5RS
Rally Blue Pearl
That's kinda what I thought. It didn't make any sense not to be able to tow with all four wheels on the ground.
Foxbat: I know all four wheels aren't going to turn at exactly the same speed all the time. I'm not a fool. I was mostly referring to the potential damage of towing a car with a traditional (i.e., two-wheel) tow truck or some similar device (like some towing apparatus for cars).
Old 11-08-2001, 03:43 PM   #8
Ardrossan
Member#: 12055
Talking
Thanks for all the responses.
I know that I can tow with all 4 whells on the road...
But does any one know where I can buy the damn towing brackets for a 2002 Impreza.......
Old 01-27-2016, 01:03 PM   #9
SoCalDissident
Member#: 137251
13 WRX
Old thread resurrection! But the only one I could actually find on this topic.
Any other owners out there flat towing a WRX or STI (or just base Imprezza) behind an RV? Shopping for a manual Subaru now and wondering if any particular model is better or worse.
SoCalDissident is offline   Reply With Quote
Old 01-27-2016, 01:34 PM   #10
SoapBox
Member#: 204578
S54 E46, N54 E82,
N55 E84, AKA REX8
https://www.etrailer.com/vm/Subaru/Impreza/towbar
Seems like there are some options out there now.
SoapBox is offline   Reply With Quote
Old 01-27-2016, 06:57 PM   #11
SoCalDissident
Member#: 137251
13 WRX
Thanks! Is one of these systems required, too?
https://www.etrailer.com/dept-pg-Tow...g_Systems.aspx
Old 01-27-2016, 01:18 PM   #12
Sikk
Member#: 241662
2006 WRX VF48
do not tow Subarus on the ground. Maybe the BRZ, maybe.
also leave old threads to die, jesus.
Sikk is offline   Reply With Quote
Old 01-27-2016, 01:26 PM   #13
SoCalDissident
Member#: 137251
13 WRX
Read in multiple places that all manual subarus can be flat towed.
Would you prefer I start a new thread to ask instead? This already had all the relevant data (including that they can be towed)
Old 01-27-2016, 01:26 PM   #14
SoapBox
Member#: 204578
S54 E46, N54 E82,
N55 E84, AKA REX8
You absolutely, 100% can flat-tow a Suby with a tow bar.
It is no different/harder on your AWD system then coasting or driving down the road.
Jesus, stop spreading crappy info.
Hell, you have a mechanical oil pump, you could technically tow it in gear.
Old 01-27-2016, 10:29 PM   #15
zore
Member#: 202850
2006 WRX Limited
Curious where your source is that this can't be done? And why not bring an old thread back if it's topical?
zore is offline   Reply With Quote
Old 01-27-2016, 10:47 PM   #16
Broxh
Member#: 415302
2016 WRX
DMG
Its really not good for the differentials to tow the car flat.
For short trip it probably won't do too much damage, but over a longer distance you will add necessary wear to the system. Just disconnect the axles and you will be fine
Broxh is online now   Reply With Quote
Old 01-28-2016, 08:11 AM   #17
SoapBox
Member#: 204578
S54 E46, N54 E82,
N55 E84, AKA REX8
Do tell, how is it any harder on the diffs vs. driving or coasting the car?
Old 01-28-2016, 10:18 AM   #18
zore
Member#: 202850
2006 WRX Limited
I'm with you. Subaru says it's ok to do but the so called exports say doom and gloom with no facts other than a hunch. It's not just this thread, but countless others I've read on here that makes statements sound like tested fact when they are simply not.
Really irritating when you are looking for real information and getting 20 hunches made to sound as if they came from the owners manual.
From Subaru
Towing a Subaru behind a motorhome or a tow truck
The following is from Subaru Helpline Update, Feb 1999
updated November 2009 about automatic and CVT transmission
There has been a change to the policy regarding towing of Subaru vehicles behind motorhomes. The following applies to 1990 through present model year Legacy (Including Outback), 1993 through present year Impreza (incl. Outback Sport), and 1992 through present year SVX. (Note: should also include 1998 through present year Forester. Joe)
The factory hitch is 1.25" a 2" hitch can be installed aftermarket
Manual Transmission:
All Wheel Drive vehicles can be towed with all four wheels on the ground or with all four wheels off the ground on a trailer but towing an AWD vehicle must never be attempted with only two wheels on the ground or two wheels on a dolly.
STI, to tow: DCCD must be in manual mode, with the DCCD control dial set to the furthest rearward position (rolled toward rear seat).
Front Wheel Drive vehicles can be towed with all four wheels on the ground in neutral or with the two front wheels off the ground.
Automatic Transmission
November 2009. Automatic transmission and CVT vehicles can be towed with all wheels on the ground in an emergency for very short distance (under 31 miles) and at very slow speed (under 20mph).
AWD automatic 4 and 5 speed vehicles should not be towed with any wheels on the ground. The vehicle can only be towed on a trailer with all 4 wheels off the ground and the transmission in park.
Note: always inspect and check your car- radiator, coolant, all hoses, all fluids, brakes, towing equipment, lights etc
Old 01-28-2016, 11:14 AM   #19
Broxh
Member#: 415302
2016 WRX
DMG
It depends on if it has active or passive cooling on the differentials. If its purely passive then it won't matter but if its active it would require the engine to be on to prevent overheating. (esp on the central diff)
Old 01-28-2016, 11:14 AM   #20
SoCalDissident
Member#: 137251
13 WRX
Good to know even the STI has a way to do it. My only fear at this point is total cost, rock chips, and ground clearance during snowy conditions....
Old 01-28-2016, 11:41 AM   #21
sedagive
Member#: 186334
I always thought you had to flatbead a Subaru... never tow.
sedagive is offline   Reply With Quote
Old 01-28-2016, 12:00 PM   #22
SoapBox
Member#: 204578
S54 E46, N54 E82,
N55 E84, AKA REX8
You're confusing towing in general with using a tow truck...with just two wheels off the ground. That's a no-no with the driveshaft still connected.
If someone wants to tow your car from, say an illegal parking spot, they should use a flatbed. As a more likely alternative, a tow truck operator will fit a dolly under the non-lifted set of wheels.
Old 01-28-2016, 12:24 PM   #23
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
You CAN flat tow a MT Subaru, but why not just spend the $1500-2500 for a trailer?
vision.dynamix is online now   Reply With Quote
Old 01-28-2016, 01:22 PM   #24
D-rock240
Member#: 284221
2011 WRX GV SSM
2001 Legacy BH 5MT DD
Yeah, I wouldn't want to put the rolling mileage on the car if I wasn't driving it.
D-rock240 is offline   Reply With Quote
Old 03-17-2016, 01:07 PM   #25
SoCalDissident
Member#: 137251
13 WRX
1) It's additional time to load and unload the vehicle
2) An RV+a trailer won't fit in most RV spots, AND they'll charge you to keep it in the overflow lot (if there's room), which means
3) Extra time to unhook and rehook up the trailer
4) Even more extra weight of the car AND the trailer on the RV, which makes mileage even worse and adds additional strain on the RV
5) Somewhere to store not just an RV but a trailer now too
So when you get somewhere and it's cold, instead of just unhooking the car and driving off, you have to unload it, unhook and move the trailer, etc etc etc
Greg, awesome site! Thanks!
And the comment about "maybe a BRZ, but not any other" is kinda funny, since I think that's one of the FEW (only?) manual Subarus that you CAN'T flat tow!
http://www.edmunds.com/subaru/brz/20...motorhome.html
Towing a small trailer with a 2.0L WRX HankWest Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 07-30-2009 12:35 AM
Complete WRX Turbo Kit with Front mount. Grip&Dip Engine/Power/Exhaust 22 01-18-2009 07:49 PM
Towed with a 2wheel tow AltimaJay General Community 30 11-21-2003 05:25 PM
Question about towing a wrx behind a motor home LiquidForce Transmission (AT/MT) & Driveline 7 08-14-2003 12:17 AM
Who tows stuff behind their WRX?? jonmacs22 Mid Atlantic Impreza Club -- MAIC 11 04-15-2003 04:35 PM
