Old 11-08-2001, 02:26 PM   #1
Tainted
Member#: 7996
1980 Human Biped
Flesh tone.
Question Compression ratio?
What compresion ratio does my engine run at?
Tainted is offline   Reply With Quote
Old 11-08-2001, 02:33 PM   #2
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
10:5:1 if I'm not mistaken...
DanzBorin is offline   Reply With Quote
Old 11-08-2001, 02:51 PM   #3
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Default check your owners manual...
That info is in there too, along with other vital information.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 11-08-2001, 03:15 PM   #4
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
I know the 01 RS's are 9.7:1, I would be suprised if it was higher than ten for the 2000 model.
Graham
Graham is offline   Reply With Quote
Old 11-08-2001, 03:24 PM   #5
Jademonkey
Member#: 9213
2000 RS
Red
I thought the compression ratio for the 01 rs was 10:1?!?!
Jademonkey is offline   Reply With Quote
Old 11-08-2001, 04:49 PM   #6
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
9.7:1 for 98-99, 10:1 for 00-01 (and probably for 02).
Ben
bsquare is offline   Reply With Quote
Old 11-08-2001, 06:48 PM   #7
jhonas
Member#: 9015
2002 Impreza 2.5RS
Platinum Silver Metallic
It is indeed 10:1 for the MY02 RS. The recent car and driver issue has lots of specs you might want to know.
jhonas is offline   Reply With Quote
Old 11-09-2001, 02:05 AM   #8
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
the 02 RS's are 10.0:1 as well as the MY00-01. They made no changes because they have gotten what they wanted out of the motor.
Jeremy
HndaTch627 is offline   Reply With Quote
Old 11-14-2001, 04:03 PM   #9
cakagan
Member#: 251
1998 Impreza 2.5 RS
Question
What would the compression ratio be for the Phase 1.5 motors? My '98RS has DOHC heads w/ SOHC block.
Thanks,
-Chris
cakagan is offline   Reply With Quote
Old 11-14-2001, 04:53 PM   #10
bsquare
Member#: 1911
2000 Impreza 2.5RS
Changing the heads on the EJ25 doesn't change the compression ratio. You'll still be at 9.7:1.
Ben
Old 11-14-2001, 04:56 PM   #11
cakagan
Member#: 251
1998 Impreza 2.5 RS
Thumbs up
Cool, thanks.
-Chris
Old 11-15-2001, 08:53 AM   #12
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
Actually, changing the heads could change the compression ratio. Compression ratio is a function of cylinder bore, stroke length, cylinder head volume, deck height, head gasket thickness.
Richard
http://www.whitetyphoon.com/impreza/
Richard L. is offline   Reply With Quote
Old 11-15-2001, 11:01 AM   #13
cakagan
Member#: 251
1998 Impreza 2.5 RS
The tech that installed my new engine thought the compression was raised, since the SOHC engines are higher now. I hope not. I think I'll ask him to find out what it is when I drop my car off to fix the valve chatter. It wasn't a problem on my original DOHC engine, but this new Phase 1.5 engine is loud as hell.
Btw, nice Typhoon Richard! When I finally buy a house in the mountains and need an SUV, I'm buying a Typhoon...
-Chris
Old 11-15-2001, 11:19 AM   #14
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
I believe the heads do affect the compression ratio. 98's and 99's(all 99's, that I am aware of) are both labeled as 9.7:1 compression. and since the block changed mid-99, but the compression did not, it is not something to do w/ bore or stroke. The only other option is the pistons themselves, which did get redesigned, but the heads were a more significant change...
mrbell is offline   Reply With Quote
Old 11-15-2001, 01:29 PM   #15
bsquare
Member#: 1911
2000 Impreza 2.5RS
I believe they changed the pistons. Can someone with detailed knowledge comment?
I am aware of how compression ratio is calculated, but I sepcifically said that THIS head swap on THIS engine shouldn't change the ratio.
Ben
Old 11-15-2001, 01:32 PM   #16
cakagan
Member#: 251
1998 Impreza 2.5 RS
Actually, I think Subaru changed the block mid-98, as mid- to late-98 2.5L owners have the Phase 1.5 from the factory.
-Chris
Old 11-15-2001, 02:09 PM   #17
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
I thought the block changed in 99... I could be wrong about that... i also realized my other mistake... I think they went to SOHC in 99, not 00, right? 00 was the year they switched to MAP... sorry, my bad
Compression ratio? Naturally Aspirated Normally Aspirated Powertrain 31 11-30-2003 10:37 PM
('93-'01) what is the compression ratio on a... wop Impreza Forum 9 06-15-2001 05:34 AM
Boost and compression ratios 98mpreziveRS Normally Aspirated Powertrain 4 03-29-2001 06:58 PM
Compression Ratio for 98-01 RS Delhi Normally Aspirated Powertrain 4 03-14-2001 03:00 PM
Compression ratio question fellfrosch7 Normally Aspirated Powertrain 12 03-14-2001 12:43 AM
