Old 01-01-2007, 09:04 PM   #1
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Default Will JDM STI AVCS cams in USDM STI AVCS heads?
I have been searching for a good while now and I have found lots of info about using AVCS JDM cams in non-AVCS USDM 02-05 WRX heads but nothing about using JDM AVCS cams in the USDM STI AVCS heads.
Will JDM AVCS cams fit in the USDM STI AVCS heads and work correctly assuming proper tuning and supporting mods? To me, supporting mods to the heads would include valvetrain modifications to support 8K RPMs and porting.
I don't have huge power goals or anything. I would be very very happy with a well running motor making 375-400whp and the ability to crank to eight grand without the power dropping like a rock form the early sixes.
dexterous is offline   Reply With Quote
Old 01-02-2007, 03:13 AM   #2
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Yes, they fit. But JDM STI cams have less lift and more duration compared to USDM STI cams.
Marnix is offline   Reply With Quote
Old 01-02-2007, 09:38 AM   #3
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
less lift?
TROLL is offline   Reply With Quote
Old 01-05-2007, 01:52 AM   #4
BLUE STINGER
Member#: 84206
Originally Posted by Wrinkleboi View Post
less lift?
That's how high the the valves open and the duration is how long they stay open.
Ron
BLUE STINGER is offline   Reply With Quote
Old 01-02-2007, 11:48 AM   #5
S L O W W R X
Member#: 95109
The cam sensor pick ups are completely diffrent, I'm not sure if you can make the avcs work
S L O W W R X is offline   Reply With Quote
Old 01-03-2007, 10:43 AM   #6
dexterous
Member#: 23553
2014 WRX - Daily
Interesting. So does anybody have any recommendations for CAM options? Am I correct in thinking that I would need cams to have a well rounded motor spinning to 8K?
Old 01-03-2007, 09:45 PM   #7
zanderspeed
Member#: 72818
2002 Bugeye
EJ25 | FPGreen
The pick ups are completely different. Why not purchase a set of aftermarket avcs cams?
zanderspeed is offline   Reply With Quote
Old 01-04-2007, 08:11 PM   #8
dexterous
Member#: 23553
2014 WRX - Daily
Sure, recommend something and I will look into it.
Old 01-04-2007, 09:33 PM   #9
zanderspeed
Member#: 72818
2002 Bugeye
EJ25 | FPGreen
Old 01-03-2007, 11:12 PM   #10
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
If you are spinning to 8k I'd get bigger cams than stock, I don't care what stock motor they were in.
wrxfactor is offline   Reply With Quote
Old 01-05-2007, 02:43 AM   #11
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
yeah i thought they had more lift and more duration... but maybe i'm just ASSuming. i know they are more aggressive than usdm, but maybe that can be achieved still with less lift but more duration? i'm a cam noob.
Old 01-05-2007, 07:31 AM   #12
Assami
Member#: 130699
2005 STI JDM 2.0L
Blue 315whp
yes they will fit, the only thing youl not have is the mid rang power that the AVCS will normally supply you with.
with AVCS the timing will be different between RPMs.
Assami is offline   Reply With Quote
Old 01-07-2007, 05:45 AM   #13
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
It seems there are two types of pick-up for the AVCS sensor on the rear end of the cams. The JDM cams have 4 positive signal pick-up points on the cam, whereas the USDM cams seem to have negative pick-up points (slots). Can anyone comfirm this?
I'm running JDM Legacy EJ20X/Y heads/cams on a USDM Legacy EJ255 ECU and loom, with AVCS working, meaning the USDM cams must have the same slots as the JDM Legacy EJ20X/Y have (so the JDM Legacy EJ20X/Y cams differ from for instance JDM STI cams regarding AVCS pick-up).
Old 01-07-2007, 09:50 PM   #14
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
That would have been great to know when MZM was working on my WRX with EJ20X swap that that couldn't get to run correctly without the proper ECU.
Old 01-08-2007, 06:33 AM   #15
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
I almost ordered JUN AVCS intake cams for a customer's engine which runs EJ20X/Y cams on a USDM MY05 Legacy GT ECU.
I'm now discussing with JUN if they can supply the cams with the other AVCS pick-up pattern. If they can't, I will use standard Subaru intake cams off a MY07 Legacy 2.0R. Those are atmo cams with AVCS, 248 degree (standard turbo AVCS cam is around 240) and 9.8 mm lift. The atmo engine makes 168 ps @ 6800 rpm.
I think the difference (slots or ribs) has to do with solid cams (cast ribs) or the latest hollow cams (slots machined into them).
Old 01-08-2007, 11:33 AM   #16
zanderspeed
Member#: 72818
2002 Bugeye
EJ25 | FPGreen
The pickup points and sensors are completely different. The JDM are two-wire magentic sensors. The USDM STI sensors are 3-wire hall-effect sensors.
Old 04-29-2011, 08:09 PM   #17
nedalrabadi
Member#: 244358
1996 impreza
orange & black
please any info about the EJ20X
are they like the EJ205 or EJ207 ?
nedalrabadi is offline   Reply With Quote
Old 01-07-2007, 01:45 PM   #18
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
Cosworth, TSR70, MZM Tune
The USDM STi AVCS cams do indeed have slots at the rear. I forget how many though...
-D
Dasani is offline   Reply With Quote
Old 07-31-2008, 08:36 AM   #19
WhiteKnight
Member#: 56133
2004 Euro spec Sti
Black - Rotated gt3037s
EJ25 heads + cossy euro/japan spec cams + euro spec ecu + euro AVCS sensors
Would these combo work?
AVCS solenoid bracket needs a little work but i think it is ok.
Any ideas?
WhiteKnight is offline   Reply With Quote
Old 04-26-2011, 11:50 PM   #20
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
white knight, did you ever figure out if the combo worked? I'm about to buy a 207 just to measure things up and see if the JDM ecu, cams, sensor and solenoids can be used...basically all the parts that are easy to buy. Heads are hard to come buy and guys seem to think they are gold or give ZJs.
Old 04-27-2011, 08:51 AM   #21
biodude
Member#: 271720
Im curious as well for the same reasons.
biodude is offline   Reply With Quote
Old 04-27-2011, 10:16 AM   #22
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
I have a ver8 jdm engine, the cams profiles for the pickups are positive, not negative like the usdm, I don't see why you couldn't use jdm cams in 2.5 heads as long as you used the ecu that was needed as well the holes should be the same where the cams bolt up, so for building an engine it would be ok, or for doing a hybrid, just remember you need everything including the jdm engine harness., also they have more duration and less lift which aids in higher rpms
seanathanq83 is offline   Reply With Quote
Old 04-27-2011, 10:29 AM   #23
Homemade WRX
Member#: 33782
96 bastard child
I know the difference in sensor type and cam trigger but I'm wondering as to placement in degrees relative to crank the difference is in trigger times and sensor placement...also no one has been able to clarify (including Dave @ RalliSpec, Steve at IA performance) if the sensors can fit. Though Dave was saying that he doesn't think JDM sensors will physically fit without some machine work.
I've also brought this thread back from the dead. I hope Waxed can be more specific on sensor alignment.
http://forums.nasioc.com/forums/showthread.php?t=992216
Old 04-29-2011, 09:39 PM   #24
seanathanq83
Member#: 173241
I have the jdm Cam sensors, let me see if I can either find usdm sti Cam sensors or if I can find a 2.5 to try them out, they look the same, I can snap a pic tonight
Old 04-30-2011, 02:11 PM   #25
Homemade WRX
Member#: 33782
96 bastard child
if you can get a side by side and actual dimensions (tip length from shoulder, offset from center of bolt hold to center of pick up, and tip diameter).
I think the big issue is going to come with alignment of heads and cams triggers.
JDM avcs cams vs. USDM avcs cams are they interchangable? cubuff Built Motor Discussion 13 12-17-2008 11:41 AM
Analysis of Cosworth AVCS cams vs USDM STI cams bboy Built Motor Discussion 89 06-18-2008 03:48 PM
Non-AVCS Cams in STI Heads SloRice Built Motor Discussion 3 10-07-2006 03:18 PM
STI v5-6 cams in USDM ej20t markk26 Subaru Conversions 3 10-14-2004 09:07 PM
Trade JDM Spec C cams for USDM Sti Cams Julio Private 'For Sale' Classifieds 0 11-16-2003 09:09 PM
