Old 01-23-2007, 01:14 PM   #1
saloonracer
Member#: 62687
2007 Its a Suby
Yeah..its stock :)
Default Need help Please
Hi all,
I have a 2004 rs with the single din factory radio. Its cd player broke so I upgraded to a new Alpine unit mp3/wma all that. But with the Alpine I cant seem to get radio stations when i let it seek. I checked antenna and it is plugged into the alpine adapter no problems.
Any suggestions on what could be causing this bad reception? The radio just will not find a station using DX or local seek.
Final question. Will a double din radio from a 2005 or older sti/wrx fit the 2004 rs?
Thank a lot
saloonracer is offline   Reply With Quote
Old 01-23-2007, 01:20 PM   #2
LastResort
Member#: 99289
http://forums.nasioc.com/forums/showthread.php?t=824983
Why do I get lousy reception with my new aftermarket radio?
It is very common that the power antenna wire wasn’t hooked up to the new radio (even “professional” installers have not done this correctly). More information can be found in this link...
http://forums.nasioc.com/forums/show...hreadid=464212
LastResort is offline   Reply With Quote
Old 01-23-2007, 01:39 PM   #3
02BlueSuperRoo
Member#: 78290
2011 WRX 5-door
SSM
Why do I post stupid questions without searching?
It is very commong for n00bs to ask questions that have been answered a million times because they don't search. (Even "professional" NASIOCers have not done this correctly). More information can be found at this link... http://forums.nasioc.com/forums/search.php?
02BlueSuperRoo is offline   Reply With Quote
Old 01-23-2007, 01:50 PM   #4
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
It seems like this question gets asked every day lately.
khail19 is offline   Reply With Quote
Old 01-23-2007, 04:02 PM   #5
saloonracer
Member#: 62687
2007 Its a Suby
Yeah..its stock :)
Default hmm strange
I think my first post states that the antenna is hooked up correctly ---"white wire". Ive had numerous techs look at it and they see nothing wrong with the install.
Any other bright ideas from you so called specialists. lol joking. Thanks for the Noob Alert but I am a little past that point.
Old 01-23-2007, 04:23 PM   #6
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
Originally Posted by saloonracer View Post
Hi all,
Thank a lot
Your first post sounded like you just plugged in the antenna like every other car. You didn't say anything about hooking up the white wire.
Only other common problem I know of is some kinds of window tint can affect reception. And any double din radio will fit your car. You just remove the din pocket and the existing HU and install the double din.
Old 01-23-2007, 04:38 PM   #7
saloonracer
Member#: 62687
2007 Its a Suby
Yeah..its stock :)
I am sorry for the somewhat lacking post. I guess that was a Noob post then. 1000 apologies. I was actually talking about the Antenna wire (white)and not the coaxial cable.
I found out that metallicized(sp) tint kills AM reception on my S4 (Bose system) So I figured it would do the same on the scoob since both have the antenna in the rear window. FM should be fine. But no tint in the scoob.
I just threw in that double din question since I was already posting, just as a backup noob question.
cheers
need help please!! nicknpar Transmission (AT/MT) & Driveline 1 06-03-2010 10:54 PM
NNJ: Need to use a lift or need help! PLEASE! CoBB_tHiS! Tri-State Area Forum 6 05-05-2010 05:46 PM
need help, please help!!! ralyrcr Mid West Subaru Owners Club Forum -- MWSOC 11 08-30-2005 08:39 PM
I need to order a clutch ASAP - Need help please Rizzo314 Transmission (AT/MT) & Driveline 3 11-05-2004 07:10 AM
Hard Drive Recover Help much needed... ATA RAID 0 knowledge needed HELP PLEASE!!! 2k2 Off-Topic 63 12-24-2003 10:35 PM
Message Board Statistics All times are GMT -4. The time now is 02:25 AM.
