Old 03-21-2007, 10:13 PM   #1
racerX_244
Member#: 125778
Default RPM Surge, Bypass valve not functioning?
i've got an '03 wrx. seems like when i get into boost when its warm, and go to shift (clutch in, letting out the throttle to grab the next gear) i get a ~500rpm surge, almost as if the blow off valve isn't releasing the boost pressure, and its pushing the throttle body open. its in the same "burst" that a blow off would be as well.
Would a vacuum line issue be causing this? the blow off valve not getting a vacuum signal and opening up when it should? faulty valve? I'm new to subarus, but i've built custom turbo projects in the past. no mods, factory boost gauge tee'd into the vacuum hose coming off the blow off valve.
let me know if this is normal. thanks
racerX_244 is offline   Reply With Quote
Old 03-21-2007, 10:52 PM   #2
firebox40dash5
Member#: 107361
Now, with 100% less
trunk space!
It's normal. Srsly.
firebox40dash5 is offline   Reply With Quote
Old 03-22-2007, 12:00 AM   #3
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
Originally Posted by firebox40dash5 View Post
It's normal. Srsly.
It is. The only real problem is that you have a BOV
ErasureWRX is offline   Reply With Quote
Old 03-21-2007, 10:56 PM   #4
bdpAKAknox
Member#: 121248
The bov being in existence would cause that problem.
bdpAKAknox is offline   Reply With Quote
Old 03-22-2007, 03:00 AM   #5
racerX_244
Member#: 125778
BOV, BPV, sorry if i'm not explaining it right. its the stock "bypass valve." not some xs power blow off or something. its all stock. this is where my confusion hits.
so its normal to run at wot until 7k, then go to shift and watch the tach spin further after i lift off the gas, and not hear the stock bypass valve? I understand its not supposed to be a noisy vrrrm-pshhh ricer blow off valve. i've driven other subarus, and I could at least faintly hear their bypass valve.
guess i'll just start checking vacuum lines and the blowoff valve itself. thanks guys...
Old 03-22-2007, 10:53 AM   #6
Force
Member#: 123515
2005 vette c6 z51
LeMans Blue
^^you have to adjust your shifting techniques to compensate for this. This is normal on our cars, especially while under more load. More load = more throttle = turbo spooling = rpm spike when you quickly let off the gas. Let off the gas for a brief second and then clutch in to avoid this. It happens to me everyday at least a couple of times. I've learned to shift at 7K RPM so this does not happen, you just have to get to know how your car responds a little better. When I first got the car, this happened to me all the time at WOT...at first I thought it was the car, but it's somewhat the driver's technique as well.
Force is offline   Reply With Quote
Old 03-22-2007, 02:41 PM   #7
racerX_244
Member#: 125778
thanks wrxgon. this makes sense, as its not a constant thing. guess its something i'll have to get used to.
sorry for sounding ignorant, just really like my car and wanting to make sure i don't have something wrong.
the previous owner, for some reason, had a one way check valve in the vacuum line heading to the factory boost gauge. right after the bov. i took off the valve and found that it must be blown out, since it will allow vacuum or pressure to pass through either end. was this some sort of band aid fix for the surging i wonder? if it was it didn't work.
either way, thanks for the advice. guess i'll just have to learn to not drive like a noob.
Old 03-22-2007, 03:19 PM   #8
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
This bothered me at first, too, but sadly it's just normal
Old 03-22-2007, 03:50 PM   #9
aps2fast4u
Member#: 57871
2004 WRX
13.4 @ 102
Yep, normal. Happens on most forced induction cars I believe.
aps2fast4u is offline   Reply With Quote
Off Idle (1500 RPM and up) RPM surging / hunting mccorry Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 05-18-2008 10:21 PM
Belt squeal NOT going away at high rpm!! silence2-38554 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-26-2007 09:20 AM
car will not go over 6ooo rpms sti350zguy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 04-18-2005 10:23 PM
RPM Surge JTremble Newbies & FAQs 2 01-03-2003 03:56 PM
