Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 04-07-2007, 04:47 PM   #1
newerWRX
Member#: 144716
2003 wrx
Default will i pass the smog test in california?
ok i have a question that i can't seem to find the answer to. i have an 03 wrx. i want to get the ECU tuned, but im afraid that if i do that then i wont pass the smog test here in california. is this true or will i still be able to pass with a tuned ECU???
newerWRX is offline   Reply With Quote
Old 04-07-2007, 04:49 PM   #2
prometheum
Member#: 92003
04 bicycle!
they're normally more worried about exhaust components. do you have all your cats?
prometheum is offline   Reply With Quote
Old 04-07-2007, 04:51 PM   #3
bmms8
Member#: 36287
2004 WRX
World Rally Blue
I heard you can get away with just the stock downpipe meaning if you gut or get an aftermarket uppipe you will be fine. or if you want, you can go stage 2 with everything catless and when it comes times to get emissions get your stock downpipe installed before. its a lot easier than the uppipe which is good.
bmms8 is offline   Reply With Quote
Old 04-07-2007, 04:52 PM   #4
newerWRX
Member#: 144716
2003 wrx
yes the exhaust system is still oem except for an after market muffler that was welded on the end. bought the car like that. would it change the read out of the smog test if the ecu was altered?
Old 04-07-2007, 04:58 PM   #5
dibblejr
Member#: 94070
05 LGT
You should ask this question in your local forum section, more specific answers can be found.
Jay-R
dibblejr is offline   Reply With Quote
Old 04-07-2007, 04:58 PM   #6
bmms8
Member#: 36287
2004 WRX
World Rally Blue
also, even if you tuned your car with say accessport or even open source, you can always revert to stock, so i dont see you having any types of problems but i think stage 1 wont have any complications with passing smog. believe me, i am in the same boat as you, i just have stage 1, and have all my cats but i dont think smog will be a problem, good luck
Old 04-07-2007, 05:07 PM   #7
newerWRX
Member#: 144716
2003 wrx
thanx for the info, california sucks big ballz, my civic is from minnesota and it wont pass cause i have no cat, owell.
Old 04-08-2007, 12:36 AM   #8
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
It all depends how youre tuned. Many people can tune their cars to pass the sniffer with no cats at all, but that wont work in Cali where you have the visual inspection.
Old 04-08-2007, 09:30 AM   #9
rkramer
Member#: 118209
2015 WRX Limitec
gutted stock...?
rkramer is offline   Reply With Quote
Old 04-08-2007, 11:18 AM   #10
EDM
Member#: 82078
2015 VW GTI
Carbon Steel Grey
There have been a few people that have passed with only 1 cat.
EDM is offline   Reply With Quote
Old 04-08-2007, 11:26 AM   #11
prometheum
Member#: 92003
04 bicycle!
do all cars get the sniffer in CA?
Old 04-08-2007, 04:06 PM   #12
EDM
Member#: 82078
2015 VW GTI
Carbon Steel Grey
Sniffer and visual just no dyno like the 2WD cars have to do.
Old 04-08-2007, 02:23 AM   #13
skydes
Member#: 141347
2005 WRX
I heard the rule was changed for '03+ cars. Someone told me they won't have to get tested till 2012 or something like that.
skydes is offline   Reply With Quote
Old 04-08-2007, 01:56 PM   #14
subi_2.5rs
Member#: 67538
2003 impreza wrx
black/blue/purple
you'll pass if you have no cel. iirc all the 2000 and up cars are obd2 tested. they wont test from your exhaust, an engine bay check is all. from exprience
subi_2.5rs is offline   Reply With Quote
Old 04-08-2007, 02:06 PM   #15
Superglue WRX
Member#: 106275
New Chevy SUV
Government Motors White
Where and when did this happen?
They will look under the hood to make sure all of the emission parasites are still there. You don't need a smog till next year either by IIRC.
<---- has an '03 in CA never been smogged
Superglue WRX is offline   Reply With Quote
Will a Cobb Stage 2 OTS Map pass a Smog Test? flukewrx Bay Area Impreza Club Forum -- BAIC 5 06-30-2009 02:24 AM
Would the aftermarket FMIC fail the smog test in california. ix8vii Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 09-06-2005 03:17 PM
Need help passing smog test in Merced acer72 Bay Area Impreza Club Forum -- BAIC 6 03-16-2004 05:06 PM
APS Club Spec - Will It Pass CA Smog Test Rally Punx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 07-01-2003 12:14 PM
HELP! I need a SMOG test locally. Won't pass the "visual" test! ARG Southern California Impreza Club Forum -- SCIC 13 05-02-2002 10:20 PM
