Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
Old 05-15-2007, 11:37 PM   #1
jamal
Member#: 71875
98 2.5GT
my wheels fit
To start, you can put almost any set of Subaru brakes on any other Subaru. If you want WRX brakes on your L or something you pretty much just have to buy some and bolt them on. There are some exceptions, however, mostly relating to the rear, which are explained later on. And also in this thread
Additionally, the 05+ sti has a different bolt pattern (5x114.3 vs 5x100) so those rotors are not compatible with other models.
If your car has rear drum brakes, a disc swap is fairly more involved. I'm not entirely sure on the process but there are more details farther down.
I would also be wary about trying to exchange stuff with the 08s. The rear backing plate is completely different so to the best of my knowledge nothing is interchangeable.
So, if you're wondering what brakes you have and what other brakes are out there, I've made this big list of most of the different brakes found on modern Subarus. The information came from a lot of places like the DBA catalog (click the rotor size for spec sheets provided by DBAsteve), cars101, and various threads/FAQs here and on scoobymods. This is mostly just about US model cars. Generally brakes were the same around the world but there are a few little special exceptions that are linked to later on.
Disclaimer: While I have tried to make this post as accurate as possible, there are some mid year revisions. I also can't be positive all the year ranges listed are correct, especially for pad shapes. In some cases, it is necessary to call a dealership with your VIN number or physically compare parts.
Front Brakes
242x16mm
Smallest Subaru front brakes, found on FWD non-abs Imprezas (93-96). The caliper and bracket are similar to those for early 260mm brakes with a shorter bracket and they use the same pads. These things fit under 13" wheels.
Applications:
93-96 Impreza 2WD.
260x24mm
This is the most common front rotor size before 2000. It was found on many Imprezas and Legacies and uses a single piston caliper and bracket. Somewhere around 96/97 the caliper/bracket/pad design changed. These fit under 14" wheels.
Applications:
90-99 Legacy non-turbo/-GT/-Outback
1995 Outback
93-01 Impreza AWD (non RS)
276x24mm
This uses a two piston sliding front caliper and there are three caliper/bracket designs. One for the 91-94 Legacy SS/TW, an early Legacy 2.5GT/Impreza RS bracket (~96-99), and a Later RS/GT bracket (03+). It's possible to exchange some of these calipers onto taller WRX brackets as long as the pad shapes match.
Applications:
91-94 Legacy turbo
96-01 Legacy GT
96-01 Outback
00-04 Legacy non-GT
98+ Impreza RS/TS/2.5i
98+ Forester
Some non-us BRZ/FRS/86 models.
294x24mm
295x25.5mm
This is the WRX front rotor. It uses a two piston sliding front caliper or the Subaru fixed 4-pot. The sliding caliper, bracket, and pad were changed in 03 and that's something you need to be aware of when upgrading from RS brakes or purchasing pads. The 4-pots are only on the 06-07 WRX in the US, though they were on many older non-US STis and WRXes (the black calipers with Subaru across them). Generally 16" wheels are required with these brakes but there are some 15" wheels out there that work. Also 16x6.5 Subaru wheels do not clear 4-pots.
Applications:
01 Legacy GT LTD?
02-04 Legacy GT
05-09 Legacy non-gt *
01-09 Outback
02+ Impreza WRX (including 08, which uses 2-pots)
03+ Forester
Baja
BRZ/FRS/GT86
Here is the description on the different DBA rotors in this size:
Originally Posted by WRXBrakes View Post
DATA
DBA 1 piece:
Standard series - p/n 650 - fits 2 or 4 piston WRX w/294mm rotor
4000 series - p/n 4650 - Again fits all 2 or 4 piston 'WRX' applications. However - some street pads w/ shims on them may not fit w/ the shim as the rotor is intentionally a bit thicker to add heat mass. Take shims off - run a few weeks - if it gets noisy wait till they can fit.
p/n 4000 - Original 4000 series rotor w/ tapered HAT section to clear OUTBOARD ABS tone ring. This ABS system is all pre-2000 MY afaik.
5000 series:
p/n 5000 -the OG - fits 4 pot WRX (pre-USDM 2 pot)
p/n 5010 - fits 2 pot OR 4 pot front WRX calipers. This rotor was made when it was realized that the caliper bracket from the USDM WRX hit the rotor hardware on p/n 5000. Thus 5010 has a different design- the hardware is recessed for clearance.
Added bonus points: This rotor is also available in 5x114.3 to make it possible to swap an 05-07 STi to the subaru 4-pots for rally. Not sure where to find that rotor but I would start with rally shops. A standard WRX rotor cannot be re-drilled to 5x114 as it won't fit over the larger hub.
*The non-turbo Legacy actually has a slightly different rotor that is technically 292mm in diameter. It is also slightly heavier than the WRX rotor. They can be interchanged without issue.
316x30mm
This uses a two piston sliding caliper similar to the other 2-pots, although brackets and calipers aren't compatible between other 2-pots. 17s are required with them.
Applications:
05-09 Legacy GT
Tribeca (5x114.3 bolt pattern)
326x30mm (5x100)
326x30mm (5x114.3)
STi rotor that goes with the 4-piston Brembo calipers. There are two rotors, the 04 has a 5x100mm hub bolt pattern, 05+ uses 5x114.3. The calipers all mount the same way so you can attach front Brembos to other Subarus without trouble. There were some changes to the caliper over the years that involved some sort of stiffening, so from what I can tell an 07 caliper would be slightly better than an 04.
Applications:
04+ STi
A note about the SVX:
The SVX has brakes that are about the same size as WRX brakes and the SVX has 5x114.3 hubs. However, up front, the rotor hat offset (how close or far the rotor surface is from the hub) is different from that on other Subarus. The knuckle also locates the caliper bracket in a different position. That unfortunately means that you can't just buy some 05-07 STi brembos or Tribeca brakes or something to upgrade your SVX. I'm pretty sure that in the rear things are compatible with other Subarus.
Rear Brakes
266x10mm
The most common Subaru rear rotor. It uses a single piston sliding caliper, of which there are a few variations. Early Legacy sedans (non-turbo) and Imprezas have a smaller piston than Legacy wagons and turbos, and there are a few bracket/caliper revisions.
Applications:
90-99 Legacies/Outbacks with rear discs non-turbo
93-07 Imprezas with rear discs (except sti, 06-07 wrx)
98-08 Foresters with rear discs
Bajas
274x10mm
This rotor is on most 05-09 Legacy/Outbacks. The exception is the LGT and probably the 3.0R. Parking brake is 170mm. Seems to be only be on these models.
286x10mm
2008+ impreza/wrx
2009+ forester (with rear discs)
2010+ Legacy 2.5i
Some non-US BRZ/FRS/GT86 models
uses a 190mm parking brake and 1-pot sliding calipers.
290x10mm
This is well known as the H6 rear rotor. The Legacy caliper is the same as most other 99-07 1-pot Subaru calipers so you can upsize to this rotor simply by purchasing the brackets and correct pads.
The "H6" bracket is part number 26625AE000. It uses pad shape D770
Applications:
00-04 Legacy/Outback non-brighton
SVX (5x114.3, 190mm parking brake)
Ver5 STI type-RA (5x100, 190mm parking brake)
266x18mm
This is the Legacy turbo rear rotor. The caliper is similar to the other calipers but is wider to accomodate the vented rotors. I hear it was also found on the v1 WRX (93-94).
Applications
91-94 Legacy turbo
290x18mm (170mm parking brake)
290x18mm (190mm parking brake)
290x18mm (2010+ Legacy GT, BRZ)
There are actually three different rotors in this size. The first is the standard 06-07 WRX and 05-09 LGT rotor. It uses either a 2-piston opposed caliper or a 1-pot slider. The 2-pot will not bolt up to other Subarus without something like the Kartboy brackets or having a new backing plate pressed onto the spindle. The next version is for the STi 190mm parking brake so that 2-pots can be used on rally cars. The third version is for the newer cars. It can be found on the 2010+ LGT and the BRZ/FT86/FRS. This third version could also be used as an upgrade for the 08+ Impreza if you wanted to go to slightly larger vented rotor. It does not interchange with the group n rotor.
Applications:
05-09 Legacy GT (1-pot, 170mm park brake)
06-07 WRX (2-pot)
04-07 STi with FHI 2-pot conversion
2010+ Legacy GT
BRZ/FT86/FR-S
Some older non-us spec-b Legacys and wrx/sti models (see rear brake redux)
Note: The LGT uses a different brake line than older Legacies and Imprezas. So I think you need to grind down part of the caliper where the line mounts to get it to work on an Impreza. The LGT lines are a different shape and mount and a different angle and you can't use them.
316x20mm (5x100)
316x20mm (5x100, 170mm parking brake)
316x20mm (5x114)
STi brembos. There are multiple versions of this disc. One for the 04 STi, one for 05-07, one for 08+ and one with a 170mm parking brake drum. There's an explanation how to install rear brembos on other cars a little farther down. 08+ sti rear rotors have a different backspacing.
Applications
04+ STi
320x18mm
Hey that's an odd size now isn't it. I was previously wrong with my thinking the Tribeca uses the same rotor as an STi. It does have the same bolt pattern (5x114.3) though. AFAIK, it uses a 170mm parking brake but don't quote me on that.
So, what does that mean? The calipers and brackets should work on an SVX. Unfortunately no front brakes are interchangeable onto an SVX because of the rotor hat back-spacing.
Drums
Some cars have rear drums that are like 9." I don't really know anything about Subaru drum brakes so it would help if someone filled that stuff in.
Some of them are: Legacy and Impreza Brighton models, Some 95-99 Legacy L models, some foresters and I think 02+ Impreza TS and OBS. (I'm not sure exactly)
To swap out drums, at the least you will need new parking brakes, backing plates, discs, calipers, and brake lines. It is usually best to get a whole knuckle/hub/parking brake assembly out of a car with rear discs. If you want to put rear discs on your front wheel drive Subaru, you might have to parts from a 90-94 Legacy, since they might be the only FWD Subarus with rear discs and the FWD rear hubs/spindles/struts/etc are different.
Installing rear Subaru 2-pots or Brembos on a non 2-pot car:
The Subaru and Brembos have the same backing plate, which is different from all the other Subaru rear disc backing plates. So calipers don't swap between the two. Additionally, the STi uses a 190mm parking brake drum. Pretty much everything else uses a smaller 170mm drum. That means if you take a set of rear brembos and put them on your WRX, the parking brake will not work.
However, there are Subaru 2-pot rotors (290x18mm) with a 190mm parking brake hat and Brembo rotors (316x20) w/ a 170mm e-brake so you can put either setup on either car. There are also Kartboy brackets that will adapt the 2-pot calipers to any other Subaru, and since both rotors are available in 170mm parking brake variety, you can swap either one onto any other Subaru. Here's a thread about fitting the brembos to other cars with the new Kartboy brackets and DBA rotors.
Here is the rear brake redux, which has more information about the older rear brakes that came on STis and fancy Legacys in Japan.
Some D-plate numbers
Originally Posted by stoptech
The Friction Materials Standards Institute (FMSI) is an association that assigns numbers to different pad shapes that are used as a guideline for pad manufacturers to refer to, and bring a common numbering system to the brake pad aftermarket. Virtually every pad manufacturer will either use the FMSI number in their numbering system or have a readily available interchange to cross-reference their part number to the FMSI number.
I should note that the caliper bracket, and not the caliper, is what determines pad shape. So while there are a few different pads, in some cases the calipers are the same.
Front 1-pots
D470:
1990-1995 Legacy
1993-1996 Impreza
D722:
1996-1999 Legacy
1997-2001 Impreza
Front 2-pots
D563:
1991-1994 Legacy Turbo
1996 Outback
1996 Legacy GT
D721:
1997-2002 Legacy
1998-2001 Impreza RS
2002 Impreza and WRX
1998-2002 Forester
D929/D1539:
2002-2009 Legacy/Outback (non-gt)
2003+ Impreza/Forester
8/2002-2005 WRX
2008+ WRX
BRZ/FRS/GT86
I added a new shape, 1539. It is listed specifically for the 11+ but the basic shape is still the same. Difference is that the new pad has more friction material on it and slightly different wear indicators.
See this article for clarification on 02-03 shapes
D1078:
2005-2009 Legacy GT
Tribeca
Rear 1-pots
D471:
1990-1999 Legacy
1993-1998 Impreza
1993-1997 SVX
D770:
2000-2004 Legacy
2005-2009 Legacy GT
1999-2002 Impreza
D1004:
11/2002-2005 WRX
2003-2007 Impreza
D1114:
2005+ Legacy 2.5i/Outback (incl 2010+)
2008-2011 Impreza
2008-2012 WRX
2009+ Forester
non-vented FRS/BRZ/86 rear brakes
D1124:
2010+ Legacy GT
FRS/BRZ/GT86
FHI 4/2-pots
Front: D647 (or D1170, D460, D1182)
Rear: D461
STi Brembos
Front: D1001
Rear: D961
Missing information:
- non-us market vehicles
- 2012 Impreza
- BRZ (but I'm pretty sure the rear brakes are the same as the 08+ WRX)
jamal is offline   Reply With Quote
Old 05-16-2007, 02:12 AM   #2
coolcougar
Member#: 19674
2006 Baja Turbo 4EAT
Brilliant Silver Metallic
Great Job. Thank you!
coolcougar is offline   Reply With Quote
Old 05-16-2007, 09:29 AM   #3
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Someone suggested stickying this, and hey, it definitely deserves some time up there for folks to see it and add to it.
I'm open to a more attention grabbing thread title as well
john
Butt Dyno is offline   Reply With Quote
Old 05-16-2007, 11:22 AM   #4
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Good thread.
Might want to include the technical bolt pattern #'s in there too, and maybe even include Tribeca brakes and the older drum brakes.
Old 05-16-2007, 02:14 PM   #5
stoney98
Member#: 65888
2010 FXT
where do the TS/RS fit in? Thanks.
stoney98 is offline   Reply With Quote
Old 05-16-2007, 02:21 PM   #6
jamal
Member#: 71875
98 2.5GT
my wheels fit
for front, they're listed as 02-06 non-wrx, non-sti.
I'm not really sure exactly which cars have rear drums so if anyone wants to chime in on that it would be good. Also with the tribeca stuff.
Old 05-16-2007, 02:31 PM   #7
stoney98
Member#: 65888
2010 FXT
my TS has two pot front, rear drum. The OBS have the same. I ordered up a set of WRX rotors for an 03 WRX and they were too big for the TS bracket.
Old 05-16-2007, 02:36 PM   #8
jamal
Member#: 71875
98 2.5GT
my wheels fit
yeah it's 276mm compared to the 294mm wrx rotor.
Old 05-16-2007, 03:08 PM   #9
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
Some edits
LGT fronts are 316 x 20
I am pretty sure the RS fronts are 276 x 24 - same thickness as WRX - just smaller diameter
Early RS have a different rear pad - same as 2G DSM rear
WRX 4 pots = D460 which must be the same as the newer D number
There may be a few more in there - 2000 Legacy has been incorrect before.
Otherwise - good info!
KNS Brakes is offline   Reply With Quote
Old 05-16-2007, 03:21 PM   #10
jamal
Member#: 71875
98 2.5GT
my wheels fit
Are you sure the LGT front rotors aren't thicker?
Yes you're right the RS rotors are 24mm wide.
Oh yeah it seems some 98 Imprezas use the later two pin bracket/caliper but D1186 pads. That's kind of odd.
Also I think my year ranges are a little off for the old rear pad sizes.
Old 05-16-2007, 03:25 PM   #11
KNS Brakes
Member#: 125739
2015 WRB WRX
There is a new rear shape on new legacy outbacks - exact application is a bit unclear but it's out there - no aftermarket pads available yet afaik
Old 05-17-2007, 12:58 PM   #12
rougeben83
Member#: 115154
2005 Outback XT
White on grey
05+ LGT fronts, 4 pots, and a dinner plate
LGT rotors are indeed thicker; 30mm vs. WRX/4pot 25mm
For the record; the 03-04 Legacy GT's got the WRX front brakes, the older years got the same size fronts as GC RS's, and all L's in the BE/BH got those brakes as well. There may have been some overlap on the 02 year, but I'm not 100% sure.
rougeben83 is offline   Reply With Quote
Old 05-17-2007, 02:20 PM   #13
jamal
Member#: 71875
98 2.5GT
my wheels fit
Nice. Here's one of my tiny old L rotors next to my new WRX rotor:
my car stops good now.
One thing I've heard is that some of the 01-02 GT LTD models may have gotten 294mm front discs. Maybe just 02. The 00s for sure have 276mm front discs though.
Old 05-17-2007, 04:38 PM   #14
KNS Brakes
Member#: 125739
2015 WRB WRX
yup - meant 30 not the 20 - typo
The conversion from 276 to 294 mm fronts for Legacies is apparantly not clear to the aftermarket - lots of my catalogs are incorrect or differ.
Old 05-22-2007, 11:54 PM   #15
kaos200
Member#: 2692
wow, great writeup!
kaos200 is offline   Reply With Quote
Old 06-06-2007, 02:40 AM   #16
orwrx
Member#: 33869
2002 wrx
rally blue
STI brembo caliper with OEM 326mm rotor, can I put bigger diameter for the caliper? Where I can find info on how to put rear brembo on WRX with KB bracket? Pls help!!
orwrx is online now   Reply With Quote
Old 06-06-2007, 07:04 PM   #17
jamal
Member#: 71875
98 2.5GT
my wheels fit
Originally Posted by jamal View Post
The Subaru 2-pots will bolt to an STi Brembo backing plate and there are 290x18mm rotors with a bigger 190mm parking brake hat. This is so rally cars can easily switch to 4/2-pot Subaru brakes for wheel clearance/group-n rules. So the Brembos will bolt to an 06 wrx backing plate, but need a rotor with a 170mm parking brake hat. Here's a thread about fitting the brembos to other cars with the new Kartboy brackets and DBA rotors. The first sets have been made as of this post. There are also taller parking brake shoes available.
12345
Old 06-13-2007, 06:41 AM   #18
ci82b4u
Member#: 151324
great information, it will be so helpful and a great reference
ci82b4u is offline   Reply With Quote
Old 06-25-2007, 03:26 PM   #19
Timon
Member#: 152314
1995 1995 GF
blurple purps
so what would be the best 2000 legacy sedan caliper/disk upgrade. I'm trying to upgrade on a budget, using better subaru products from wrx or other models.
Timon is offline   Reply With Quote
Old 06-28-2007, 03:19 AM   #20
not12listen
Member#: 147078
2006 WRX Wagon
Grey
ok, i'm new to the subaru ways... so, i've got some basic questions.
can i just bolt on a set of 94 legacy turbo rear brakes (calipers and brackets) onto a 99 rs? i understand that if this works, i would have to swap rotors as well. i just want better brakes.
also, could i take the 02+ wrx front brakes (calipers and brackets) and put them onto a 99 rs? again, i just want better brakes.
i'm hoping that these upgrades would bolt on without drilling or fabrication... if any is necessary, just lemme know.
thanks!
not12listen is offline   Reply With Quote
Old 06-28-2007, 10:05 AM   #21
jamal
Member#: 71875
98 2.5GT
my wheels fit
yes, any brake setup will bolt to any car, with the exception of the 2-pot Subaru and Brembo rears.
Old 07-01-2007, 08:20 PM   #22
scubywagon
Member#: 65967
2004 WRX WGN 2.5
Java Black Pearl
is it possible to put the subaru 4pot calipers and vented rotors on the rear of an 04 wrx and if so, who makes a rotor for the rear that will work with the parking brake set up? don't know if it is possible but thought it would be worth asking if anyone knows.
scubywagon is offline   Reply With Quote
Old 07-01-2007, 08:24 PM   #23
Butt Dyno
Member#: 17301
is the "dark side"
It may be possible, but here's a thread detailing some of the issues involved:
http://forums.nasioc.com/forums/showthread.php?t=32102
Old 07-01-2007, 08:26 PM   #24
jamal
Member#: 71875
98 2.5GT
my wheels fit
To clarify a bit: Front and rear brakes are not interchangeable.
You would need a custom bracket and rotor made.
Old 07-02-2007, 07:15 PM   #25
McFrosty
Member#: 151492
1994 Legacy GT Wagon
I just got a set of front and rear WRX calipers to throw on my Legacy. I was told they were from a 2002 or 2003 WRX. So I want to make sure I order the right pads because the caliper design changed at some point in 2002.
The only numbers I've found on the web are these:
Front Calipers:
1/2002-7/2002 WRX: D 721
8/2002-2005 WRX:: D 929
Rear Calipers:
1/2002-10/2002 WRX: D1379/ D770
11/2002-2005 WRX: D1004
None of the numbers on my calipers match any of these. This is what I have found on my calipers:
Rear calipers -
3818
AD38
4 BI
2432
10-14
Front calipers -
(left) 62L T1
(right) 62R T2
TOKICO
2XP
How do I decipher this???
McFrosty is offline   Reply With Quote
Tribeca Brake/Suspension technical information THAWA Tribeca Forum 5 03-31-2006 10:07 PM
Looking for thread that contains information on Clearence of Stop Tech Big Brake kit MooseWRX Brakes, Steering & Suspension 4 02-22-2004 04:24 PM
brake upgrade information STEALTH-WRX Brakes, Steering & Suspension 43 03-11-2003 01:31 PM
Outback owners: brake information needed! bagio Legacy Forum 1 08-02-2002 03:47 PM
Outback owners: brake information needed! bagio Brakes, Steering & Suspension 1 08-01-2002 05:24 PM
