05-22-2007, 11:31 AM | #1 |
Member#: 104507
SCIC
Vehicle:Haw deeeewdddddd |
DC-to-AC Power Inverter
So I have one of these:
and my question is.. Instead of using the cig lighter, would I be able to cut off that adapter and just use the power and ground directly somewhere? I'm trying to put that adapter somewhere clean and flush and I want to hide those wires. I searched around and seen a couple people do it, but I wasn't sure if it was safe/possible. Any input appreciated. Thanks, Getti |
05-22-2007, 11:37 AM | #2 |
Member#: 99289
Yes, just use a good attachment method, and properly insulate. You could probably just tap the cigarette lighter wires for convenience.
05-22-2007, 11:37 AM | #3 |
Member#: 117003
Vehicle:02 Bugeye WRB |
Yes you can with no problems. Make sure you find the right wires for positive and negative. And then properly crimp and heatshrink your connections and you'll be good to go!
05-22-2007, 11:41 AM | #4 |
Member#: 104507
SCIC
Awesome, just wanted to double check! Thanks for the quick responses guys!
05-22-2007, 11:42 AM | #5 |
Member#: 92141
Vehicle:2014 GT-NC-PRHT Zeal Red. |
I'd think you'd want to tap ACC power.
so make sure that you are in a 12v ACC line, and check the fuse rating of the line you go in on. |
05-22-2007, 11:49 AM | #6 |
Member#: 104507
SCIC
^^-- will do.
other than the cig lighter.. anyone know, for sure that is, a wire to tap into? |
05-22-2007, 11:56 AM | #7 |
Member#: 134262
Vehicle:-1 centrifugal bumble-puppy |
For power sources, try here:
http://forums.nasioc.com/forums/show....php?t=1210133 This may be helpful as well: http://forums.nasioc.com/forums/showthread.php?t=488917 |
05-22-2007, 12:10 PM | #8 |
Member#: 104507
SCIC
Thanks floyd! I'll send you some bomb from socal.
05-22-2007, 12:27 PM | #9 |
Member#: 104507
SCIC
found the positive and neg near the fuses, again, thanks guy.
05-22-2007, 02:19 PM | #10 |
Member#: 132820
Vehicle:2005 Impreza RS Silver |
I just did this....i took out the outlet and switch, extended the wires, mounted it into the dash and spliced the power into the cigarette lighter
and it came out very clean |
05-22-2007, 02:23 PM | #11 |
Member#: 100655
SCIC
Vehicle:2003 Wrx Sonic Yellow |
^Nice install
05-22-2007, 02:38 PM | #12 |
Member#: 99289
Just watch the heat in an install like that, without air circulation, you could trip the unit. Looks very nice though.
05-22-2007, 03:14 PM | #13 |
Member#: 104507
SCIC
thats exactly where im putting it!
BUT im doing it the other way around (outlet pointing backward, anda i have 2 outlets) and then im cutting air vents on the sides of the armrest (the sides that are next to the seats) so you wont notice the slits, but it will be able to breathe! @micker - very very clean job man! |
05-22-2007, 03:58 PM | #14 |
Member#: 85938
Vehicle:2004 WRX WRB |
When tapping wires. I would run straight from the battery. I installed one in my car. I tried just using the cig adapter and my ps2 would not start. It had enough power for the lights but the game disc would not spin. I hard wired to a splitter that has 2 gauge running to. After that the ps 2 works great. This is with the car not running. Micker72 That is an awsome looking install. You have given me some ideas.
Similar Threads | ||||
Power inverter connected to battery, battery charger plugged into inverter... | El Camino | Off-Topic | 27 | 08-16-2010 12:48 AM |
FS in VA: 2004 STi UTEC, 300W DC to AC power inverter | WRXtranceformed | Engine/Power/Exhaust | 8 | 09-06-2006 07:33 PM |
aftermarket gauges w/ power inverter, what voltage/wires to hook up to? | jt1583 | General Community | 0 | 07-09-2005 09:10 PM |
how many watt power inverter needed to charge a laptop computer? | Poe | Car Audio, Video & Security | 7 | 04-23-2003 04:01 AM |
DC->AC power inverter | chkltcow | Car Audio, Video & Security | 4 | 11-06-2001 04:03 PM |
