Old 12-21-2001, 09:56 AM   #1
Radio Flyer
Member#: 374
'98 2.5 GT Wagon
Rio Red
Question Problem, or, 'Don't do that'?
I've noticed a couple times, no, I don't do it or feel it often, that when turning with the wheel at full-lock (left -- haven't tried right), that the car bobs and lurches as though the front right tire is flat and buckling. This occurred in the parking lot at my grocery store.
First time I felt it, I actually jumped out of the car to check the tire - which, of course, was fine.
I figure that what is happening is that the u-joint/CV-joint is being forced to move at it's maximum angle, pushing the suspension up and down.
My question: Is it likely that something is broken/breaking, or should I just not do that (turn at full lock)?
TIA,
  - Eric
    '98 2.5 GT Wagon - Pics - Page -
    ICQ #: 9292601
Radio Flyer is offline   Reply With Quote
Old 12-21-2001, 11:19 AM   #2
francophile
Member#: 8666
2005 STi
Crystal Gray
Default 'Problem'
It almost sounds as though you have a LSD in the front, or a locker diff, but I doubt you have either of those; you would have had to add them yourself. Barring that, something in the suspension is binding. Perhaps a strut, maybe CV joint. I'd definitely have it looked into the next time the car is in for service. In the meantime, 'don't do that'
Cheers,
-wdb
francophile is offline   Reply With Quote
Old 12-21-2001, 02:45 PM   #3
subyspeed2
Member#: 10914
1992 legacy turbo
black
i've noticed the exact same thing a few times. really worried me(feels kinda like you're about to run the wheel right over) and i quit 'doing that' as much as possible. if you find out why yours does it please let me know.
subyspeed2 is offline   Reply With Quote
Old 12-21-2001, 02:56 PM   #4
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Sounds like the viscuous coupling is allowing the rear wheels to "over-ride" the front ones just a tad. If you've ever driven a 4WD vehicle on dry roads this would be most familiar to you, as the rear diff, with no slippage, runs forward, pushing through the front tire/wheel which is at an angle, and moving forward at lower relative speed. This is never noticed in mud and snow with the road surface allowing things(tire contact) to slip 'n slide. The viscuous coupling(on MT cars) and the 4EAT (on autos) allows some loss of forward momentum at the rear(effectively lowering the gear ratio) when this occurs in our AWD cars, thus allowing efficient use of AWD on dry roads. Hope that makes some sense.
Something you may wish to discuss with a Subie tech to determine the degree of severity and whether or not it's really a problem.
Glenn O
nuburu2 is offline   Reply With Quote
Old 12-21-2001, 10:24 PM   #5
JoeT
Member#: 3956
2000 Turbo Legacy GT
Titanium
Hi Radio Flyer,
If your car is automatic, the center clutch pack may be siezed. This happened once on my friends 97 Outback LTD and Subaru replaced it under warranty.
One of the causes for failure is too much difference in tire diameters between the front and the rear tires. I warned him, cheap b-terd, used a mix of tires same size, but not the same brand.
Hope this helps.
JoeT is offline   Reply With Quote
Spinoff: What do you do that's bringing you closer to dying TarmacRally Off-Topic 60 12-28-2008 03:33 PM
EGT Problem or ECU Problem??? STUDAndring Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-29-2006 10:01 PM
Clutch problem or tuning problem? earlmale Transmission (AT/MT) & Driveline 3 02-21-2006 12:24 AM
Web problem or my problem? No search? RyeDaddy General Community 2 08-22-2003 12:17 PM
Help: Please post your Tranny/Turbo problems or lack of problems! Rich L Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-21-2001 04:10 PM
