Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Old 06-15-2007, 01:15 PM   #1
Member#: 80012
04 BMW M3
Ducati 620 Dark / 08' 848
Default Spark plug gapping procedure help
I am going to swap out my spark plugs after work today and I have a few questions. I am going to be going with NGK copper's and they usually come with a gap of .030+ and I want to be at a .028 gap. What do you guys do to shorten the gap? I've been told by some to tap the "prong" down on a hard surface to close the gap but have also been told that this is bad. What is the correct procedue?
Now after closing the gap is there a special way or tool to use to widen the gap to .028? I've been told that the wire gauge is the best to use to check the gap because the coin piece leaves a slight angle. Is this correct? Thanks for your help.
02blueru is online now   Reply With Quote
Old 06-17-2007, 10:48 AM   #2
Member#: 1134
2010 Legacy GT Ltd.
Pep Boys and other places sell plug gapping tools, they look like this:
Now I'm sure these are cheap and I'm not sure about reliability. But who knows. You slide the end of the plug over the edge, and slide it up to the measurement you're looking for. It will widen the gap as you slide it across.
Siper2 is offline   Reply With Quote
Old 06-17-2007, 03:37 PM   #3
Member#: 127429
2006 Legacy GT Limit
well i use a wire guage, one but i dont know if its the best because its so touchy, i adjust and double check like 50 times before its perfect. on the wire guage there should be a gapper prong well use that in the opposite way to make the gap smaller, try not to bang it on something hard. a lot of ppl do it, and i have heard stories of the electrode breaking off.
Rexwagon03 is offline   Reply With Quote
spark plug gapping help imprexaRS03 Normally Aspirated Powertrain 3 10-15-2007 02:19 AM
spark plug gap NGK Iridium plugs? SeaRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 09-12-2004 09:49 PM
Spark Plug Gap Scooby South Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-27-2001 12:10 AM
Spark Plug Gap??? Ben Legacy Forum 0 01-28-2001 10:49 AM
Spark Plug Replacement Procedure arejay SVX Forum Archive 2 08-10-2000 05:16 PM
