Welcome to the North American Subaru Impreza Owners Club Friday August 28, 2015
Old 07-12-2007, 01:14 AM   #1
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Default The "Will this suspension part fit my car?" thread.
This is a work in progress and took me a little while as it is, but I think it's a pretty decent start on finally making an all encompassing "fitment" thread. I tried to make it as easy to go through as possible while still covering everthing. It's still a little confusing. Blame that on Subaru, not me.
PLEASE if you notice I'm missing something, don't flame me.....just let me know! I'll change/add it as soon as I can. And yes, please double check my work.
I may rearrange the organization, but for the time being i'm focusing on content.
Click on your car below:
1. 1993-2001 Impreza 2.5RS, L, and Outback Sport
2. 2002-2003 Impreza WRX, WRX Wagon, 2.5RS, 2.5 TS Wagon, Outback Sport
3. 2004-2007 Impreza WRX, WRX Wagon, 2.5i, 2.5RS, 2.5 RS Wagon, Outback Sport
4. 2004 Impreza STi
5. 2005-2007 Impreza STi
6. 2008+ Impreza 2.5i, WRX, and Outback Sport
7. 2008+ Impreza STI
Thanks so far to:
UkNuck
TurbojonLS
sixtoo
stoney98
- Andrew
RaceComp Engineering is offline   Reply With Quote
Old 07-12-2007, 01:14 AM   #2
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
2002-2003 WRX, WRX Wagon, 2.5RS, 2.5 TS Wagon, Outback Sport
Struts
Springs
Strut tops and Camber Plates
Camber Bolts
Strut Bars
Coilovers
Swaybars and Swaybar mounts/bushings
Endlinks
Other
Wagon Differences
Struts
The following have a specific fitment for 02-03 WRX and RS, and all of the following spring and strut top fitment with these is the same as it is for the stock struts.
1. KYB AGX
2. KYB GR2
3. Koni Inserts (not a complete strut, see here for install http://forums.nasioc.com/forums/show....php?t=1219607)
4. Tokico HP
5. Tokico D-SPEC
6. STi/SPT Version 7
To use OEM or aftermarket struts that have a specific fitment for 04-07 RS, WRX, or 04 STi, you must use 04+ style rear strut tops and 04+ springs.
05+ STi struts will not fit.
Wagons are different, see notes below.
Springs
Springs for 02-03 Impreza RS or WRX will fit.
Springs designed for 04+ Impreza will fit on your 02-03 Impreza struts or 02-03 aftermarket struts, but you must use 04+ rear strut top mounts and the Scooby921 strut spacer. Details on why the spacer is needed available here:
http://forums.nasioc.com/forums/showthread.php?t=563382
Scooby921 Strut Spacer available here:
http://turninconcepts10.chainreactio...5e77d30c577da7
Aftermarket springs designed for Impreza STi will be too stiff for stock struts. OEM STi springs work well though.
You can use 04+ springs with 04-07 RS, WRX and 04 STi struts. You must then use 04+ style rear top mounts.
All 02+ RS, WRX, and STi front strut top mounts and front camber plates will fit the front.
02-03 rear strut tops fit the rear only with 02-03 springs.
04+ style rear strut top mounts require 04+ style springs.
2002-2007 2.5RS, TS, and 2.5i strut tops are softer then both WRX and STi strut tops (which are the same stiffness). confirmed?
WRX and STi strut tops are the same stiffness. STi strut tops are NOT Group N strut top mounts, which are even stiffer.
Camber bolts
All 02-07 Impreza RS, WRX and STi camber bolts are interchangeable and 14mm.
Strut Bars
Front and rear strut bars from any 02-07 RS, WRX, and STi will fit.
Coilovers
Any complete coilover for 02-07 RS, WRX and 04 STi will fit.
05+ STi coilovers will not fit.
All rear swaybars for any 02-07 RS and WRX will fit. STi rear swaybars will mount on the outside of the endlinks and their effectiveness is reduced.
04+ RS, WRX, and STi rear swaybar bushings will not fit 02-03 swaybar mounts.
04+ RS, WRX, and STi rear swaybar mounts will fit and are an upgrade but require 04+ swaybar bushings.
Front swaybars for 02-07 WRX will fit, except on RS models.
02-07 Impreza RS require a specific sway bar to clear the non-turbo headers. WRX and STi front swaybars will not fit an RS.
Endlinks
Wagons require wagon specific front endlinks.
Front endlinks from any sedan 02-07 RS, WRX, or STi will fit the sedan.
Rear endlinks from any 02-07 RS and WRX will fit sedan and wagon. STi rear endlinks will not fit.
Other
All rear lateral links and trailing arms for 02-07 RS and WRX, and 04 STi will fit, except from a wagon. Rear Lateral Links from a STi will require rear STi endlinks and STi rear swaybar. Also see notes on wagon differences.
All front control arms for 02-07 RS, WRX and STi will fit. See notes on wagon differences.
All Anti-lift kits for 02-07 WRX and STi will fit.
Fender Braces do not fit non-turbo models.
WRX Wagon, OBS and 2.5 TS Wagon Differences
Struts
Struts are specific to the Wagon. While sedan OEM and aftermarket struts and coilovers will fit, you will lose negative camber.
This can be corrected with camber bolts and/or camber plates.
The only upgraded struts that retains stock camber numbers are KYB GR2s and Koni inserts in gutted OEM wagon struts.
Springs
Using sedan springs on a wagon often results in a saggy rear end. Prodrive WRX springs are a notable exception. Wagon specific versions are available from a few manufacturers.
Swaybars
Wagon front swaybars are shorter then sedan and require a specific wagon fitment. Sedan bars have been used successfully in certain cases with certain endlinks.
Endlinks
Wagons require wagon specific front endlinks, unless you swap to sedan front control arms.
Other
Front control arms are different. Upgrading to sedan control arms gives you a wider track. It allows you to run sedan front swaybars, of which there are more choices. It also allows you to run sedan struts without losing negative camber, or you can keep your wagon struts and gain negative camber. You will be required to use a sedan front swaybar and sedan front endlinks. It is recommended to use sedan front axles as well, but not required.
Rear lateral links are different. Switching to sedan lateral links requires switching to sedan rear axles.
Old 03-02-2010, 04:23 PM   #3
chaltig
Member#: 226274
2002 WRX wagon
Originally Posted by RaceComp Engineering View Post
Springs
will tein s tech spring off a 4th 2005 gen legacy gt work on my 2002 wrx?
chaltig is offline   Reply With Quote
Old 03-03-2010, 09:00 AM   #4
relliMmoT
Member#: 206931
2004 WRX Wagon
6MT JBP 318WHP//300WTQ
Bad idea. Read the S-Tech FAQ . They wouldnt fit anyhow but hopefully youll read that and not want to get ones that do fit either.
relliMmoT is offline   Reply With Quote
Old 07-12-2007, 01:14 AM   #5
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
2004-2007 Impreza WRX, WRX Wagon, 2.5RS, 2.5 RS Wagon, Outback Sport
Struts
Springs
Camber Bolts
Strut Bars
Coilovers
Endlinks
Other
Wagon Differences
Struts
The following have a specific fitment for 04-07 WRX and RS, and all spring and strut top fitment with these is the same as it is for the stock struts.
1. Koni Inserts (not a complete strut, see here for install http://forums.nasioc.com/forums/show....php?t=1219607)
2. Ohlins Fixed Perch Struts
3. STi Version 8 OEM (2004 USDM STi)
4. STi Version 8 Arai Pink Struts
5. KYB GR2 (now also available in 04+ fitment)
The following OEM and aftermarket struts for 02-03 Impreza can work in 2 ways.
1. KYB AGX
2. KYB GR2
3. Koni Inserts (there is an 04+ specific version too, so you can just get that)
4. Tokico HP
5. Tokico D-SPEC
Either by using 02-03 springs and 02-03 rear strut top mounts.
OR
By using 04+ style springs, 04+ style rear strut top mounts, and the Scooby921 strut spacer. Details on why the spacer is needed available here:
http://www.turninconcepts.com/produc...=234&osCsid=d9
Springs
Springs for 04-07 RS or WRX will fit.
To use springs designed for 02-03 Impreza, you must use 02-03 Impreza struts and rear strut top mounts.
See strut section above for spring fitment when using 02-03 struts.
Camber bolts
Strut Bars
Front and rear strut bars from any 02-06 RS, WRX, and STi will fit.
Front strut bars for 02-05 Impreza fit the 06-07 WRX but with some difficulty regarding the AC lines. There are a few 06-07 specific front strut bars.
Coilovers
04+ RS, WRX, and STi rear swaybar mounts will fit are an upgrade but require 04+ swaybar bushings.
Front swaybars for 02-07 WRX will fit, except on RS models. Wagons are different, see notes below.
Endlinks
Front endlinks from any sedan 02-07 RS, WRX, or STi will fit the sedan. Wagons are different, see notes below.
Other
All front control arms for 02-07 RS, WRX and STi will fit. Control arms are aluminum for 06 WRX, but fitment remains the same. Wagons are different, see notes below.
2006 Impreza and 2005-2007 Impreza STi use the same steering rack bushings. All other applications will not fit.
WRX Wagon, OBS and 2.5 RS Wagon Differences
Struts
The only upgraded struts that retain stock camber are KYB GR2s and Koni inserts in gutted Wagon Struts.
Springs
Swaybars
Wagon front swaybars are shorter then sedan and require a specific wagon fitment. Sedan front bars have been used successfully in certain cases with certain endlinks.
Endlinks
Other
Front control arms are different. Upgrading to sedan control arms gives you a wider track. It allows you to run sedan a front swaybar, of which there are more choices. It also allows you to run sedan struts without losing negative camber, or you can keep your wagon struts and gain negative camber. You will be required to use sedan front swaybars and sedan front endlinks. It is recommended to use sedan front axles as well, but not required.
Old 08-10-2007, 09:47 AM   #6
Sideshowbob
Member#: 50304
97 TJ, 04 Matrix
12' TSX Wagon
Other
I am trying to get this question answered, to no avail....
What years WRX Sedan Axle's are compatible with my 2004 WRX?
Sideshowbob is offline   Reply With Quote
Old 08-20-2007, 03:38 PM   #7
Sideshowbob
Member#: 50304
97 TJ, 04 Matrix
12' TSX Wagon
bump5
Old 08-20-2007, 03:50 PM   #8
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
bump5
I think you'll have better luck asking that, in a separate thread, in the Tranny forum... there was a change from 'innie' to 'outie' stubs iirc, but I don't know when
UkNuck is offline   Reply With Quote
Old 02-22-2008, 11:14 AM   #9
noboost4u
Member#: 126442
My car is slower
than your car
Other
This may be true for some cars, I definitiely have Shane's fender braces on my 05 RS sedan.
noboost4u is offline   Reply With Quote
Old 06-09-2009, 07:03 PM   #10
gaugeof12
Member#: 132859
2015 WRX
CWP
Struts
1. KYB AGX
2. KYB GR2
4. Tokico HP
5. Tokico D-SPEC
OR
The GR2s now have 04+ rear fitment available. Part numbers 334359 & 334358.
You can note the difference in the photo here...
KYB Stock photo 04-07
KYB Stock Photo 02-03
Photo from the spacer thread
gaugeof12 is offline   Reply With Quote
Old 02-23-2010, 04:32 PM   #11
relliMmoT
Member#: 206931
2004 WRX Wagon
Endlinks
Im using 04-07 STi rear endlinks on my 04 wagon front sway. Theyre Whiteline Spherical endlinks. I just had to drill out the holes in the steel control arm to 12mm, which was cake. Since theyre length adjustable theyre pretty modular.
Aaand you can pretty much 'make' Whiteline Spherical ripoffs with parts from mcmaster.com or equivalent.
Old 02-25-2010, 08:20 PM   #12
subi400
Member#: 216984
1996 Impreza outback
Green
Hi everyone,
I have a 1996 impreza outback with stock kyb struts and stock springs. I know that the wrx wagon 02-03 springs will fit with the wrx rear top hats on my car. However, will 2007 wrx wagon springs fit on my wagon with the 07 rear top hats? Or will I need all four top hats?
Let me know guys, thanks!
subi400 is offline   Reply With Quote
Old 04-10-2014, 05:12 PM   #13
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Waitaminute.... why would this be the case?
Assuming the bar mounts outside the endlink instead of in does not (effectively) change the leverage arm length, approximating that the endlink is roughly in the same orientation (which would especially be true if going from RS/wagon sway bar to a STI one), then the effectiveness of the sway bar would be essentially the same regardless of the connection point.
chimchimm5 is offline   Reply With Quote
Old 04-10-2014, 05:43 PM   #14
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
It's not the mounting that changes the effectiveness, it's the fact that the STI bar is longer (which requires the change in mounting).
AndyRoo is online now   Reply With Quote
Old 04-10-2014, 06:44 PM   #15
Bikelok
Member#: 254851
2002 WRX wagon 5mt
I've been told by big knowledge people (Turn in Concepts, Kartboy), that the reduced effectiveness is so minimal, that you can not tell the difference. So in other words, don't worry about it at all.
Bikelok is offline   Reply With Quote
Old 03-04-2015, 09:28 PM   #16
Natan23
Member#: 406563
RaceComp Engineering, what springs will fit on my 2006 IMPREZA 2.5i.
I've been getting mixed information. Some say WRX springs will fit some say they won't.
Natan23 is offline   Reply With Quote
Old 03-04-2015, 09:55 PM   #17
Bikelok
Member#: 254851
2002 WRX wagon 5mt
04-07 WRX or STI springs will fit.
The STI are probably a bad match for your stock struts.
Old 07-10-2015, 02:54 PM   #18
BamShifts
Member#: 425419
Default Springs
Struts
Springs
Camber Bolts
Strut Bars
Coilovers
Endlinks
Other
Wagon Differences
Struts
1. KYB AGX
2. KYB GR2
4. Tokico HP
5. Tokico D-SPEC
OR
Springs
Camber bolts
Strut Bars
Coilovers
Endlinks
Other
Struts
Springs
Swaybars
Endlinks
Other
Wondering if you would know If 06/07 WRX Wagon Springs would fit on an 07 STi?
BamShifts is offline   Reply With Quote
Old 07-10-2015, 03:14 PM   #19
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
They will physically fit but will be very poorly matched to the shocks.
- Andy
Old 07-10-2015, 03:29 PM   #20
Bikelok
Member#: 254851
2002 WRX wagon 5mt
They will physically fit.
The struts will be under sprung (springs over damped).
You may have a slight lift in the rear.
Old 07-12-2007, 01:14 AM   #21
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
2004 Impreza STi
Struts
Springs
Camber Bolts
Strut Bars
Coilovers
Endlinks
Other
Struts
STi Version 8 OEM or STi Version 8 Arai Pink Struts and Ohlins Fixed Perch Struts (for 04 STI) are the only direct replacement struts for 2004 STi.
*There is now a KYB GR2 strut available in 04 STI fitment.
Koni Inserts have a 04 WRX fitment; however they will not fit in 2004 STi strut bodies due to the inverted design of the STi struts. They can be fitted to any 02-07 Impreza WRX or RS strut body. Fitting them to wagon strut bodies will result in extra negative camber. This assembly will fit a 2004 STi without issue. See here for install http://forums.nasioc.com/forums/show....php?t=1219607
1. KYB AGX
2. KYB GR2
3. Tokico HP
4. Tokico D-SPEC
5. STi/SPT Version 7
OR
By using 04+ style springs, 04+ style rear strut top mounts, and the Scooby921 strut spacer, available here:
Springs
Springs designed for 04-07 STi will fit.
Springs for 04-07 RS or WRX will fit, but will be too soft for the stock struts.
Camber bolts
Strut Bars
Coilovers
All rear swaybars from any 04-07 STi will fit. WRX rear sway bars will not fit.
Front swaybars for 02-07 WRX sedan will fit.
Front swaybars for 02-07 Impreza RS will not fit.
Front swaybars for 02-07 Impreza Wagon will not fit.
Endlinks
Front endlinks from any 02-07 wagon will not fit.
Rear endlinks from any 04-07 STi will fit.
Rear endlinks from any 02-07 WRX or RS will not fit.
Other
All rear lateral links and trailing arms for 02-07 RS and WRX, and 04 STi will fit, except from a wagon. Rear Lateral Links from a WRX will require rear WRX endlinks and WRX rear swaybar.
All front control arms for 02-07 RS, WRX and STi will fit, except from a wagon. Control arms are aluminum for STi and have greater caster, except in 07 which have the same amount of caster as the WRX.
Old 07-12-2007, 01:15 AM   #22
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Same as 2004 STi, except for:
Struts
The only struts that will fit are Ohlins Fixed Perch Struts and STi Version 9 OEM or STi Version 9 Arai Pink Struts.
Coilovers
Only coilovers specific to 05+ STi will fit.
Strut Bars
Front strut bars for 04-05 STi fit the 06-07 STi but with some difficulty regarding the AC lines. There are a few 06-07 STi specific front strut bars.
All rear strut bars from any 02-07 Impreza fit.
Other
Only Lateral Links specific to 05+ STi will fit.
2005-2007 Impreza STi and 2006 Impreza use the same steering rack bushings, all other applications will not fit.
Old 04-09-2008, 07:16 PM   #23
ritky
Member#: 72285
2003 WRX PSM w/FXHID
FLA Turnpike > I-95
Coilovers
FYI, apparently from this thread you can fit rear 02-07 impreza coilovers/struts to fit the rear of the 05-07 STi. I guess only mainly applicable to doing the koni inserts.
This information may be helpful to others since it was very helpful with me.
ritky is offline   Reply With Quote
Old 06-05-2008, 09:23 AM   #24
Airborne_J
Member#: 93045
2004 FXT 5mt
2001 2.5 RS
Why, camber plates? control arm? the 5X114 knuckle?
Airborne_J is offline   Reply With Quote
Old 06-05-2008, 11:18 AM   #25
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Originally Posted by Airborne_J View Post
the 5X114 knuckle?
Another "Vote for my ___ " Thread. This time, my badass dog. Sharkbait Off-Topic 56 10-14-2009 11:46 AM
The parting out my car feeler thread vision.dynamix NESIC Private Classifieds 51 04-25-2009 06:00 AM
The official "Will this part fit my car?" thread Butt Dyno Brakes, Steering & Suspension 20 07-12-2007 06:41 AM
The Official "Will you print my car?" thread MeanEditor Grassroots Motorsports Magazine Forum 0 02-11-2007 10:25 PM
