Old 08-11-2007, 10:27 PM   #1
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
Default replace factory front a/f sensor w/ a wideband
I have an extra 5 wire wide band & a damaged factory 4 wire front a/f sensor
Anyone know if I can splice the harness w/ the wide band , If possible which wires would connect where?
any help would be great
sense of nature is offline   Reply With Quote
Old 08-12-2007, 12:57 AM   #2
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
Do you mean O2 sensor? The front O2 (bank 1) is a narrowband. I would suggest putting the wideband in the downpipe, otherwise I believe the EGTs get high enough to destroy the wideband if you put it pre-turbo.
wrxfactor is offline   Reply With Quote
Old 08-12-2007, 11:10 AM   #3
gto7419
Member#: 44256
05 outback xt
02 wrx wagon - crushed :(
You cannot use the wideband to replace the stock o2 and send the signal back to the ecu.... It wont work...
You CAN use a wideband that has an o2 output and get both a gauge reading from the wideband and send a simulated signal back to the ecu...
Best option here, would be to have a second bung welded into place, and use the wideband at least 16" after the turbo....
gto7419 is offline   Reply With Quote
Old 08-12-2007, 11:42 AM   #4
sense of nature
Member#: 112759
SexyRP
OK so if I have another wide band w/ a output for say 2 gauges ( bosch 5 wire I believe ) I could eliminate the factory a/f & just tap the signal from the wideband & feed it to the ecu? or something like that ?
thanks again
Old 08-12-2007, 11:48 AM   #5
Drink
Member#: 102682
... ripper's
sister.
You won't be able to eliminate the factory wideband at all. You may be able to do it if you are running an elaborate standalone.
For tuning, you don't want to measure preturbo a/f, best location would be inches behind the exhaust housing of the snail. Hell, even if you could get and accuracte auxilary a/f reading before the turbo, you'd get tired of replacing $100 burnt out bosch senders.
You can however eliminate the rear 02 and run a wideband there, I did that for a while in the winter when it was too cold to mess with removing my downpipe and welding a bung.
Drink is offline   Reply With Quote
Old 08-12-2007, 01:48 PM   #6
sense of nature
Member#: 112759
SexyRP
O.k here is what is going on inside of part of my head, my factory front a/f sensor was damaged from my last engine pull for the clutch , (good help is so hard to find ) anyway, I have a cel for low input voltage from the damaged wires. I have a spare wideband for my Lc-1 I was going to wire that in stead of replacing the factory a/f sensor .. Maybe I should have said that to begin w/ . It was hard to single out that 1 voice in my head to get it all correct info together .
thanks
again
Old 08-14-2007, 08:09 PM   #7
NJWagon03
Member#: 85232
2002 Impreza WRX Wgn
Midnight Black
If you are using the front o2 sensor you need to replace it with another factory o2, the linear wideband sensor gives out a whole different voltage reading that the ecu wouldnt understand, you would just get more dtc's. the sensors work very differently, they are not interchangeable. hope that helps
NJWagon03 is offline   Reply With Quote
Old 08-14-2007, 09:22 PM   #8
sense of nature
Member#: 112759
SexyRP
AAAAhhhh the light has been seen
thanks all
Old 10-08-2007, 06:35 PM   #9
bboy
Member#: 56468
04 Improved STI
Dirty White
Thanks for playing the built motor forum.
bboy is offline   Reply With Quote
Old 10-08-2007, 06:39 PM   #10
jays05
Member#: 78165
05 STI 35r + e85
Thanks for bumping a 2-month old thread
If there were front o2 calibration maps in the ECU (I've never seen one) it might be possible to wire a wideband's analog output to the ecu wires for the front o2. I did the same with my rear o2.
jays05 is offline   Reply With Quote
LC-1 Wideband replacing factory o2 snbco07 Electrical & Lighting 7 04-02-2009 06:25 PM
FS: Front o2 sensor 2000 rs wideband GregBolby 1993 - 2001 Impreza Specific Parts 0 06-04-2008 02:23 PM
Looking for Cheap Replacement for Front Oxygen Sensor crystalhelix Service & Maintenance 3 09-10-2007 03:06 PM
replacing front a/f sensor adamoliver Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-28-2007 05:50 PM
Anyone had to replace their front O2 sensor? eightballrj Engine Management & Tuning 8 11-06-2003 04:26 PM
