Old 08-14-2007, 02:49 PM   #1
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
OMGHi2U 2008+ owners...please read....
Congrats on your new car and welcome to the forums!
Now before you start posting, please keep the following in mind:
1. Your car is brand new. Yes, it's just a new year, but for all intents and purposes, it might as well be a Jeep Cherokee as pretty much 100% of the car is new.
2. Will XXX fit my car? Probably not. The turbo is different, the intercooler is different, the exhaust is different, etc.
3. When will manufacturers start making XXX parts? We don't know, please bug the manufacturers.
4. I found XXX parts that will fit, can I bolt them up? Your best bet is to wait for engine management before you start bolting up things. Each car has something called open/closed loop fueling issues mandated by the EPA that can negatively affect vehicle modifications. The wise/safe course of action is to wait for engine management then modify. Yes, you can probably safely get away with simple mods, but the smart thing to do is engine management first, then parts.
5. But I found out that XXXX from an older Subaru will fit on my 2008. Well post that crap here and we'll update this for all to see.
If anyone sees anything to add, please post. The genesis behind this post is to prevent 9000 posts of will XXX fit my 2008. This is an annual annoyance and I'm hoping this may stem some of that.
Old parts that WONT fit:
Exhausts
TMICs
FMICs
Rear sway bars
Intakes for Legacy GT
Old parts that WILL fit:
Downpipes for Legacy GT
BPV/BOV for Legacy GT
Lightweight crank pulley
short throw shifters/bushings
front sway bar
TMIC for Legacy GT
FMIC for Legacy GT (may have to mod to fit)
Turbos for Legacy GT
Clutch and flywheel
THIS LINK contains a huge list of parts that will fit 08/09 cars
STI Exhausts that will fit
Old 08-14-2007, 02:59 PM   #2
mxturboracer86
Member#: 82398
2008 STi
555 Motorsports
I'd like to add that a good starting place to look for parts will most likely end up being the Legacy GT boards
mxturboracer86 is offline   Reply With Quote
Old 08-15-2007, 11:59 AM   #3
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
FYI, someone needs to try test fitting this, but I do believe that the 08 WRX Sedan exhaust system is ALMOST same as the Legacy GT exhaust system (including the mufflers!).
It looks like the mufflers mount exactly the same, however the Catback flange looks like it is rotated at a different angle... However, a FULL exhaust may bolt on without any problem, as would a dual muffler kit like the Prodrive mufflers (just axle backs and not the catback)
The 2.5i's (non-turbos) look EXACTLY the same though...
BTW, i'm going by diagrams here not the actual cars, so it will need to be verified first.
Old 09-17-2007, 06:13 PM   #4
samagon
Member#: 26859
of TXIC
I also like (oYo)!!!!
Unless someone else does it before me, I'm gonna grab my t-rusty old tape measure and do some measurin' to confirm/deny.
will post my findings.
Originally Posted by 2fst4u2c View Post
17" wheels of an 02 wrx will fit a 08 wrx!
and not that it belongs in the engine/power forum, but version 7 rims are a fine match, except that booger of a light that tells me the tire pressure is low is getting really annoying...
Old 09-18-2007, 04:32 PM   #5
FaisalT
Member#: 107097
09 Etnies
Gray/Black
funny, my brothers LGT does the same thing after his 19's.
FaisalT is offline   Reply With Quote
Old 09-18-2007, 05:07 PM   #6
samagon
Member#: 26859
of TXIC
from what I'm told there is a sensor in the wheel, and you can get the sensor from subaru, or tire rack.
I'm gonna see if subaru can just turn off the light from the ECU, otherwise it'll have to wait till I run through these tires.
I'll post the results regardless!
Old 09-19-2007, 11:32 AM   #7
FaisalT
Member#: 107097
09 Etnies
Gray/Black
I've been trying to get my hands on an LGT factory service manual, so I can get something figured out. I tried buying one on ebay, but they kept refunding me because they were bootleg.
Old 09-20-2007, 10:44 PM   #8
ringe
Member#: 49998
2007 WRX CT Stg 2
The wheel needs to be designed to recieve them, I think. Or, when you upgrade you could just take the sensors off your old wheels and bolt them to your new ones and see if they hold pressure. If so you're in luck.
ringe is offline   Reply With Quote
Old 09-19-2007, 05:45 PM   #9
samagon
Member#: 26859
of TXIC
initial findings are that from the bottom hangar (closest to ground) to the flange that bolts to the y pipe on the legacy muffler are 17" even, on the sedan it is 16".
didn't do any measurements on the top hangar for the legacy, but I'm guessing that is off by an inch as well, maybe more.
I'll probably not measure the rest of it though...
Old 08-17-2007, 11:16 AM   #10
IMPRZV1
Member#: 40306
2007 STi, finally!
Suby # 4, UGM
I know all kinds of stuff about the Jeep Cherokee if you need some info just let me know
On the other hand I don't know anything about the 2008 cars though
IMPRZV1 is offline   Reply With Quote
Old 03-17-2008, 05:58 PM   #11
MurphysLaww
Member#: 171245
99 328i
STX for 2013?
I traded my 97 Jeep Cherokee in on my 08 WRX,
MurphysLaww is offline   Reply With Quote
Old 03-17-2008, 11:15 PM   #12
VolkWRX56
Member#: 93083
2015 WRX Premium
Crystal White Pearl
I got an email from them last week saying the exhaust was 1395 for the TBE and 725 for the catback.
VolkWRX56 is offline   Reply With Quote
Old 03-17-2008, 11:37 PM   #13
Linfone
Member#: 163622
2008 Impreza WRX
Sounds about right.
If you're going catless downpipe, go with Ultimate Racing. on their site for 325.
Linfone is offline   Reply With Quote
Old 03-17-2008, 11:55 PM   #14
VolkWRX56
Member#: 93083
2015 WRX Premium
Crystal White Pearl
I think im going to wait and see what Cobb does. They told me last week the sedan exhaust should be out by summer.
Old 03-28-2008, 10:14 AM   #15
fabricated
Member#: 175765
Has anyone tried to install an 08' hatchback exhaust on the sedan? I have not heard anyone try it and succeed or fail. If it does not quite fit, what would it take to make it fit. The only issue I see is probably from the flange behind the differential and back. I am tired of waiting and would like to know what modification is needed to make it work. I also do not really want to put a dual on there because I thing it looks tacky coming off a single turbo. I don't care that the bumper it cutout for two tips. I am looking at possible modifying the Invidia turbo back system.
fabricated is offline   Reply With Quote
Old 03-18-2008, 12:52 AM   #16
lateralus1082
Member#: 170764
2008 VF40'd WRX
OBP 4 door Corolla
sedan or hatch?
lateralus1082 is offline   Reply With Quote
Old 03-18-2008, 10:45 AM   #17
Linfone
Member#: 163622
2008 Impreza WRX
I hesitate about Cobb because they don't have catless yet.
Old 03-24-2008, 08:22 PM   #18
VolkWRX56
Member#: 93083
2015 WRX Premium
Crystal White Pearl
Originally Posted by lateralus1082 View Post
sedan or hatch?
Sedan is what I asked about.
Old 08-17-2007, 12:51 PM   #19
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Score one for the LGT owners! I cannot wait for decently priced turbos that fit the stock location. And rotated manifold setups just got a whole lot better because of the redesign.
wcbjr is offline   Reply With Quote
Old 08-20-2007, 03:15 PM   #20
biz77
Member#: 45119
Cobb is already showing a catted DP, short-shift kit and front sway-bar for the new WRX.
biz77 is offline   Reply With Quote
Old 08-20-2007, 03:32 PM   #21
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Probably because they fit the LGTs.
Old 08-20-2007, 05:02 PM   #22
biz77
Member#: 45119
Part numbers are identical.
Old 08-30-2007, 02:03 PM   #23
vet
Member#: 42194
05 LGT Wagon
GRP, sold 98 2.5rs Acadia
Has it been verified that the turbo fitment is the same as the LGT?
vet is offline   Reply With Quote
Old 08-30-2007, 09:14 PM   #24
Purple
Member#: 116757
08 wrx Rally Blue
Colin McRae RIP!!!
they better start coming up with mods soon, im picking up my impreza tommorow, or if something goes to ***** tuesday after long weekend.
Purple is offline   Reply With Quote
Old 01-24-2008, 01:48 PM   #25
Bigjohnt2008
Member#: 169933
2008 WRX
Most aftermarket parts won't be available till lat Fed. and into March I hear......first things first, go to Cobb Tuning and get the AccessPort. Well worth it!
Bigjohnt2008 is offline   Reply With Quote
2000 Legacy GT owners please read... Dr. Spud Funk Legacy Forum 1 06-04-2001 08:32 PM
HID owners please read wop Interior & Exterior Modification 3 12-28-2000 09:16 AM
4 door 2.5RS owners please read wop General Forum Archive 10 10-31-2000 12:00 AM
Tein Owners....Please Read! SCOOBER Brakes, Steering & Suspension 10 10-21-2000 07:01 AM
Minnam Kit FYI - Turbo weight and your header - Minnam kit owners please read. Geoff Technical Forum Archive 1 09-19-2000 09:51 AM
