Old 08-20-2007, 11:52 PM   #1
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
Default hybrid w/ 06 wrx short block
i searched and cant find anyone who has done one? Im looking to do a budget hybrid and have a great hookup on this block. Is it worth doing or hold out for sti block?? I have a vf39 setup now and want more tq.
AWDWRXLOVER is offline   Reply With Quote
Old 08-21-2007, 09:21 AM   #2
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
Someone correct me if i am wrong but i believe that the Shortblocks are the same. So sure go for the budget build
JMK508 is offline   Reply With Quote
Old 08-21-2007, 11:45 AM   #3
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
wrx shortblock is EJ255
Sti shortblock is EJ257
I believe they are different
Kenji815 is offline   Reply With Quote
Old 08-21-2007, 01:06 PM   #4
AWDWRXLOVER
Member#: 50267
02 built hybrid
they are different but its hard to nail down what the exact differences are being that there are so many opinions on here.
Old 08-21-2007, 01:24 PM   #5
LeoNYC
Member#: 106583
1999 2.5RSTi
i've heard that they're exactly the same except for the part #
LeoNYC is offline   Reply With Quote
Old 08-21-2007, 02:44 PM   #6
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
Sti block has hypercast pistons and rods. Not sure about the EJ255.
Acostafan is offline   Reply With Quote
Old 09-03-2007, 10:02 AM   #7
bearpaws1973
Member#: 145025
1992 Typhoon
06 wrx built to the hilt!
Default Differences
During my research, in buying an ej255 or ej257 what I found is the piston P/N is different, probably accounting for the CR difference, but casting #'s for the block are the same (rod and crank are same part #, I recieved this info from a suby engine builder, name withheld, but he is a quality builder that make some top end motors, and many guys run his built motors). Also during my research I found that 2004-6 sti, forester xt, 2006-7 wrx heads all use the same casting part number, differences have to do with valves and cams, and machining work (ie. the air pump for 2007 sti, 06-07 wrx), after casting though the machine work may be different and the WRX head may have more stock machined from the cylinder head deck, also accounting for a higher CR. I need a sti head to take the measurements to compare. I can this evening however take a measure of the ej255 piston, and ej257 piston and tell you exact measurement differences, if it helps.
Note: This is not the bible, just what I've come up with during my blow up/re-build experience, I did work in a die-cast machine shop auto parts and cast # can be different yet it is the same part.
I can tell you, I have my ej255 open and ej257 right next to each other, that the crank is better machined (on the ej257) but as a machinist myself I can tell you that it would depend on the forging I received, and then the machine work (amount of stock) that was needed to be done (and let's not forget tooling, if I just changed insets in my fly cutter etc. etc.).
You can definately roll with the EJ255 for the build, but look out for CR with stock heads, perhaps an investment in a thicker head gasket is in order. I plan on doing a similar build that you are, with my blown block (255) and I have a set of 2002 wrx heads, after I finish my ej257 block build. If your worried about it I have EJ257 pistons (brand new) you can put in. If not if you run with the stock ej255 pistons and stock head gasket, just make sure your tuning is good.
bearpaws1973 is offline   Reply With Quote
Old 09-06-2007, 09:55 PM   #8
bearpaws1973
Member#: 145025
1992 Typhoon
Sorry it took me so long, but piston difference, I see so far:
WRX Piston:
Crown to bottom of skirt 51.6mm
dish depth ~4.75mm
Valve relief depth ~5.25 mm
STI Piston
Crown to skirt 51.3 mm
dish depth ~4.68 mm
Valve relief ~5.05 mm
I hope this helps, I'm looking for a set of STI heads and I can give you differences between the 3 (2002-5 wrx, 2006-7 wrx, 2004-7 sti)
Old 09-23-2007, 04:09 PM   #9
1GR8WRX
Member#: 18792
Default Useful
This is really useful information regarding the differences between the EJ255 and EJ257. Can anyone confirm that the pistons are different, beyond the dimensions listed above?
-1GR8WRX
1GR8WRX is offline   Reply With Quote
04-06 STI short block= 08 STI short block stitchbad Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 01-22-2010 11:21 AM
fs: 06 wrx short block LateGc8 Engine/Power/Exhaust 1 03-28-2009 12:41 PM
RS SOHC and 06 WRX Short block neogold Subaru Conversions 5 09-06-2008 11:11 PM
06 STI Short Block, Turbo, Flywheel Maybe more.... Glenlivet NWIC Private Classifieds 14 05-08-2008 10:46 PM
06 STI Short Block and more.. Glenlivet Engine/Power/Exhaust 5 03-18-2008 11:19 AM
