Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 08-22-2007, 08:57 AM   #1
jays05
Member#: 78165
05 STI 35r + e85
Default utec logs - gt35r+cams+93/meth
Here's a datalog from last night... 4th and 5th gear pull (the 1000cc bike in the other lane, an R1 I believe, lost )
Code:
                    Load Knock                     Mod   Mod         Mod
 RPM   MAP  MAF TPS Site Count  AFR  Ign#1  Inj#1  Ign   Fuel Boost  MAF
       psia  V   %                    deg   duty   deg    %   (CL)    V
 5184  -4.0 3.0  29  00    00   12.4 +26.8   18.3 +22.3  +0.0 ECU.   2.9
 5232  -4.5 3.0  29  00    00   13.3 +28.2   17.1 +22.4  +0.0 ECU.   3.0
 5274  +2.5 3.5  56  00    00   13.0 +20.4   29.7 +22.5  +0.0 375.00 3.7
 5324  +9.6 4.0 100  40    00   12.2 +13.7   47.3 +19.0  +0.0 375.00 4.1
 5411 +16.4 4.3 102  70    01   rich +12.9   62.8 +19.0  +0.0 375.00 4.4
 5537 +22.3 4.5 103  90    01   rich +10.8   73.3 +19.8  +0.0 375.00 4.5
 5797 +23.7 4.5 103 100    01   rich +10.8   71.2 +20.1  +0.0 375.00 4.5
 5931 +24.1 4.5 103 100    00   rich +10.9   70.9 +20.7  +0.0 375.00 4.6
 6138 +24.5 4.6 103 100    00   rich  +8.9   72.9 +21.4  +0.0 375.00 4.6
 6242 +24.5 4.6 103 100    00   rich  +9.5   74.3 +22.0  +0.0 375.00 4.6
 6574 +24.7 4.6 103 100    00   rich +10.6   74.3 +23.0  +0.0 375.00 4.7
 6653 +24.5 4.7 103 100    00   rich +11.1   75.7 +23.2  +0.0 375.00 4.7
 6872 +24.7 4.7 104 100    00   rich +11.5   76.5 +24.1  +0.0 375.00 4.7
 6901 +24.7 4.7 103 100    00   rich +11.8   77.2 +25.0  +0.0 375.00 4.7
 6816 +24.7 4.7 103 100    00   rich +11.8   78.6 +25.0  +0.0 375.00 4.7
 7278 +24.7 4.7 103 100    00   rich +12.3   78.0 +25.0  +0.0 375.00 4.7
 7278 +24.7 4.7 103 100    00   rich +12.0   80.1 +25.0  +0.0 375.00 4.7
 7423 +24.7 4.7 103 100    00   rich +12.3   80.6 +25.0  +0.0 375.00 4.7
 7490 +22.7 4.7 103  90    00   rich +12.5   16.7 +25.0  +0.0 LCM.   4.5
 6313 +19.0 4.4 103  80    01   lean +13.1   60.5 +22.0  +0.0 LCM.   4.3
 5737 +16.1 4.1 103  70    01   lean  +6.0   51.0 +19.1  +0.0 LCM.   4.3
 5464 +22.7 4.4 104  90    00   13.0  +5.1   61.6 +19.4  +0.0 375.00 4.4
 5446 +24.3 4.4 104 100    00   rich  +4.5   64.5 +19.5  +0.0 375.00 4.4
 5518 +24.9 4.5 104 100    00   rich  +4.0   67.8 +19.5  +0.0 375.00 4.5
 5546 +24.9 4.5 104 100    01   rich  +3.4   70.6 +19.6  +0.0 375.00 4.5
 5899 +25.1 4.5 104 100    00   rich  +3.2   70.4 +19.9  +0.0 375.00 4.5
 5602 +25.1 4.5 104 100    01   rich  +2.9   70.6 +19.8  +0.0 375.00 4.6
 5817 +25.1 4.5 104 100    00   rich  +2.8   71.8 +20.5  +0.0 375.00 4.6
 5847 +25.1 4.6 104 100    00   rich  +2.8   72.3 +20.3  +0.0 375.00 4.6
 6006 +25.1 4.6 104 100    00   rich  +2.8   73.5 +20.8  +0.0 375.00 4.6
 6016 +25.3 4.6 104 100    00   rich  +3.0   72.4 +21.1  +0.0 375.00 4.6
 6027 +25.1 4.6 104 100    00   rich  +4.1   74.1 +21.4  +0.0 375.00 4.6
 6207 +25.1 4.6 104 100    00   rich  +4.7   75.8 +21.5  +0.0 375.00 4.6
 6195 +25.1 4.6 104 100    00   rich  +5.0   74.5 +21.6  +0.0 375.00 4.6
 6325 +25.1 4.6 104 100    00   rich  +5.5   74.4 +22.1  +0.0 375.00 4.7
 6373 +25.1 4.7 106 100    00   rich  +6.0   74.8 +22.4  +0.0 375.00 4.6
 6497 +25.1 4.7 104 100    00   rich  +6.0   75.9 +22.9  +0.0 375.00 4.7
 6548 +25.1 4.7 104 100    00   rich  +6.3   80.2 +22.8  +0.0 375.00 4.7
 6561 +25.3 4.7 104 100    00   rich  +6.1   80.4 +23.3  +0.0 375.00 4.7
 6734 +25.1 4.7 104 100    00   rich  +6.1   79.1 +23.7  +0.0 375.00 4.7
 6816 +25.1 4.7 104 100    00   rich  +6.1   79.0 +23.9  +0.0 375.00 4.7
 6901 +25.1 4.7 104 100    00   rich  +7.4   79.2 +24.5  +0.0 375.00 4.7
 6930 +25.1 4.7 103 100    00   rich  +7.4   80.7 +24.9  +0.0 375.00 4.7
 6666  -1.6 4.6   1  00    00   rich +22.3   80.4 +24.6  +0.0 ECU.   2.1
 6535 -11.4 4.0   1  00    00   rich +22.9   80.4 +24.4  +0.0 ECU.   3.7
 6385 -11.8 3.3   1  00    00   rich +23.3   80.4 +24.1  +0.0 ECU.   3.1
AFR is low 11's right now, but the car seemed happier in the high 11's.
93 octane + 80/20 meth/h2o with an M15 nozzle.
built ej257 w/cp pistons, pauter rods, stock crank
ported heads, cosworth 278/274 avcs cams (avcs map still zeroed out)
gt35r .82ar @ 25-26psi. perrin kit with a custom dump tube.
Was just wondering what the utec wizards here think of the log. I started out really conservative with timing and have been slowly adding it back in - I think it still wants more but I am happy to stop at this point.
I am still running with the stock ecu in control of fuel, with a perrin bigmaf. I haven't even managed to get the car to start with OLF but I will probably start working on a SD tune next week.
jays05 is offline   Reply With Quote
Old 08-22-2007, 09:08 AM   #2
TheMadScientist
Member#: 23717
2005 Big red
WAY TOO RICH ON WI!!!
Try getting into the high 12's.
TheMadScientist is offline   Reply With Quote
Old 08-22-2007, 09:19 AM   #3
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Before adding timing, lean that thing out. With Meth don't go any richer than 12:1. You will have problems if you try to keep it that rich under that much boost.
Master2192 is offline   Reply With Quote
Old 08-22-2007, 09:23 AM   #4
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Question: Are you running an aftermarket boost sensor tied into the UTEC? If not, what was the actual boost you were running?
11:1 on 80% meth is a little rich, 11.7->12 would still be ok but your EGT's will be hot, which I would not overly worry about.
You have flat foot knock which is real so you are going to need to tune that out before you knock out your bearings. It's very small so I suggest you remove a degree of timing from the 7250 and 7500 70/80/90 and 100% load columns.
You have other small knock counts which IMO are real, drop timing at 5750 to be around 17 degrees, then ramp it back up to the same timing you are running at 6250. That should solve that.
Other than that have fun.
mick_the_ginge is offline   Reply With Quote
Old 08-22-2007, 09:26 AM   #5
jays05
Member#: 78165
05 STI 35r + e85
Thanks. I was running high 11's with -0.5 in the fuel map earlier... I think a -1 will bring it to the 12.0-12.2 range.
Old 08-22-2007, 09:38 AM   #6
jays05
Member#: 78165
05 STI 35r + e85
My avcr says peak 26psi, but my boost gauge stays flat right at 25. Target is 1.80 kg/cm2 which is 25.5psi.
Thanks for the tip on the flat-foot knock, I will try that tonight. The motor has always made some noise right around 5700 +/- a couple hundred rpms. I will try pulling some timing there but I'm pretty sure I have datalogs showing 1-counts there on wastegate boost.
Old 08-22-2007, 09:46 AM   #7
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
While your setup is monstrous to say the least, I doubt you can beat an R1.
They will run 10's bone stock and trap a bit higher than I would expect you to run..somewhere in the 140's. Well, I guess if we're talking an '07 R1 because they are the fastest of all w/ 180hp.
akira02rex is offline   Reply With Quote
Old 08-22-2007, 09:52 AM   #8
jays05
Member#: 78165
05 STI 35r + e85
I don't think it was new, actually from what I read last night about performance stats on those bikes I would bet it was an '00 or something like that. No way was it a new one trapping 150 LOL. I got the jump FWIW.
/ot
Old 08-22-2007, 10:12 AM   #9
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
/ot
Well then I totally believe you!
Old 08-22-2007, 12:47 PM   #10
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Damn.. that thing must pull like crazy! I like how you never really let off the gas pedal when you shifted
The boost pressure looks SOLID nice job there.
PaulRex is offline   Reply With Quote
Old 03-05-2012, 07:22 PM   #11
mrfranqu
Member#: 211573
2007 Cosworth STi
no way, 10.6 - 11.2 for some safety
mrfranqu is offline   Reply With Quote
Old 04-05-2012, 09:44 AM   #12
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
1. you realize how old this thread is?
2. you realize at the time he was squirting methanol ADI?
Old 04-25-2012, 03:09 PM   #13
tofer9458
Member#: 248681
2002 newbuild 5558+
foglight = ;)
^^^^ Lmao
tofer9458 is online now   Reply With Quote
FS (GA): 2004 JBP STi, GT35r, Built engine, meth, 515whp PirateSanchez Private Vehicle 'For Sale' Classifieds 5 04-20-2010 03:28 PM
T3/TO4S comparison 93 + meth and c16 + meth LiquidForce Proven Power Bragging 43 02-06-2008 01:33 PM
Will utec log knock events in log when not in control? MAP 0 NITROS UTEC 1 08-21-2007 10:55 AM
check out these utec logs. gt35r AaronWRX UTEC 19 05-17-2007 10:04 AM
Utec+GT35R or UTEC/ECUTEK+GT35R Shabib67 UTEC 43 03-21-2006 11:10 AM
