Welcome to the North American Subaru Impreza Owners Club Tuesday May 31, 2016
Old 01-12-2002, 02:39 AM   #1
Foz
Member#: 1776
2000 2.5RS
BRP
Default Rubbing brakes / noise from front driver side/AC buzzing sound
I've started to notice to hear the rear brakes seem to be rubbing or something (notice it when you apply the brakes gradually.. thump..thump.. rubbing noise).. any clues? Is it the brake pads are worn or the calipers are rusted out?
Another thing is once in a while I'll hear a banging noise from the front driver side similar to a loose rod dangling back and forth. Usually occurs when you come to a stop or accelerate slowly.
One more question, is anyone hearing low buzzing/whining noise from their A/C fan turned on low (ie. 1 and 2). Any setting higher than 2, the noise seems to disappear.
thanks,
Foz is offline   Reply With Quote
Old 01-12-2002, 01:04 PM   #2
shortlid
Member#: 10297
2003 Legacy GT Sedan
Silver, 4EAT, 42k
Default Rubbing from rear also
Our '98 Legacy L Wagon, automatic, AWD, 2.2, ABS developed a rubbing noise from the right (passengers side) rear wheel area yesterday. I have tried using the E-brake a couple of time to see if it was hanging-up but no fix. We had the tires rotated about a week ago, the rear brakes were done by the dealer about 15,000 miles ago. We did drive it in some pretty bad conditions in Northern Mich., Canada, and Buffalo, NY fully loaded about two weeks ago. The car is has "500 miles" left on the Limited drivetrain warranty so if it's a rear wheel bearing or a covered part I want to get it addressed while it is still under warranty! Thanks
shortlid is offline   Reply With Quote
Old 01-12-2002, 05:03 PM   #3
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
You could do an emergency stop on a deserted road/parking lot to see if there's just crud on the surface of the rotors.
The fan noise is pretty much normal. My '98 did it, my '01 does it. . . but a service writer told me to take it in and have the fan replaced under warranty. It's only annoying when I've got somebody else in the car (radio off or low).
CosmoTheCat is offline   Reply With Quote
Old 01-13-2002, 12:09 AM   #4
Foz
Member#: 1776
2000 2.5RS
BRP
With respect to the rear wheel/brake thumping sound. It apparently went away after I took my car for a wand wash. It might have been some crude sticking to the rotors or something.
Yeah, have them check it out since it's still under warranty.
The A/C fan is more of an annoyance than anything else. I wasn't sure if that how it sounded when I first had the car.
I'm scheduled for a check up next week.
thanks for the replies.
HELP, loud clicking noise from front drivers side. ict-wrx Transmission (AT/MT) & Driveline 7 06-22-2009 12:20 AM
Weird Rubbing sound from front driver side ogboot Brakes, Steering & Suspension 17 05-09-2008 06:39 PM
Clunk noise from front passenger side suspension Gordata Transmission (AT/MT) & Driveline 15 07-18-2006 03:26 PM
clicking from front drivers side OneArmedScissor Brakes, Steering & Suspension 3 04-25-2005 11:53 PM
STI..Clanking noise from the drivers side wheel/brake 516_WRX_V2 Tri-State Area Forum 3 10-08-2003 12:53 PM
