Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Commercial ECU Reflashes
Old 09-27-2007, 10:57 PM   #1
Rexer06
Member#: 125065
2006 WRX
Default Accuracy of ECUtek software road dyno
Please be gentle with me if this is a noob/stupid qn... How accurate is the ECUtek software road dyno compared to actual 4WD dyno (say ABC or a specific dyno brand)? i'm assuming the software parameters (tire profile, weight of car, gear ratio, etc) are correct.
Rexer06 is offline   Reply With Quote
Old 09-30-2007, 12:28 AM   #2
Rexer06
Member#: 125065
2006 WRX
*bump* anyone knows?
Old 10-02-2007, 12:56 PM   #3
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
This actually came up in a discussion I was having on another forum. After the argument started, we were fortunate to have one of the developers of a particular road dyno package join the discussion. It quickly devolved into higher math, but the summary of the situation is that the math used to make the plot has a pretty serious problem. Interestingly, this is also true of the lower-end physical dynos.
The root of the problem is that as the dyno or dyno software sample speed (of the engine [RPM] or of the rolling drum [RPM]) over time, reality gets in the way and the change in RPM over time isn't very consistent from sample to sample. Sometimes, the RPM may even drop between samples (leading to NEGATIVE power). To deal with this, the software (road dyno or real), applies smoothing to the graph in the form of fitting a high-order (x^16) polynomial function to the data. Most of the time, that works out just fine. However, from time to time, the function will have an inflection point (change in curvature) that the real power curve doesn't. Obviously, this is a BIG problem for tuning.
Here's an example from my RS. See that hook at the top end? That's completely fake, not there at all. It's totally an artifact of the math.
The safest/easiest to get plots that don't have math weirdness are RPM vs time (a line running generally up and to the right, getting higher, faster means more power), or a plot of dRPM/dt vs. RPM (higher is better). Both of those can easily be plotted in Excel and would allow you to do overlays to compare different runs.
Question on ECUtek Road Dyno Graph (SMOOTHING) BlackSun Engine Management & Tuning 0 11-11-2008 04:41 AM
software to do road dyno? rapturem3 Open Source Reflashes 13 08-05-2008 06:02 PM
Road Dyno software OS Kastley85891 Engine Management & Tuning 6 01-22-2008 09:37 PM
Ecutek Road Dyno Results nicholam General Community 7 01-18-2007 01:10 PM
Impressed w/ DD road dyno repeatability/accuracy BIGSKYWRX Engine Management & Tuning 9 06-28-2003 01:43 PM
