Welcome to the North American Subaru Impreza Owners Club Sunday March 29, 2015
Old 10-03-2007, 01:13 PM   #1
ted dibiase
Member#: 94752
2003 wrx
wrb
Default just ordered some STi heads to go wiith my EJ257 block...what else do I need?
I have been driving my hybrid (ej257 block & 2.0 liter heads) bugeye for about 8 months now. I went this route because my wrx engine broke and I needed to rebuild the 2.0 or just go with a 2.5. I have been concerned with issues relating to the compression and overall of having an engine that wasn't engineered by Subaru. Well I just ordered a set of STi heads and I'm hoping that it will give me piece of mind. What else will I need other than gaskets to make this work? How should I control AVCS?
I have contemplated getting AEM EMS or Hydra if I'm able to sell my AP, wrx heads and a couple of other things I have laying around. I have heard that I can disable AVCS, but I'm not sure that works with my longterm plans. What else will I need or need to do to make sure that I won't blow up another engine and that I will have good factory like power?
Thanks for the help.
ted dibiase is offline   Reply With Quote
Old 10-03-2007, 02:03 PM   #2
sjl1614
Member#: 56791
06 OBS
Did you order all the parts for the avcs? Even if you don't you avcs, you still need to route to oil for the avcs. I just went through this with a set of cosworth heads on a wrx.
sjl1614 is offline   Reply With Quote
Old 10-03-2007, 02:07 PM   #3
ted dibiase
Member#: 94752
2003 wrx
wrb
All that I have ordered so far are a complete set of STi heads (complete as in cams, shims, buckets, valves). Can I use the throttle body that I have? Will my PE 650 injectors work?
Old 10-03-2007, 02:11 PM   #4
sjl1614
Member#: 56791
06 OBS
I take it the heads are used then? Just make sure all parts are there. You can use your 2.0l intake and TB and injectors. The sti have different fuel rails and side feed injectors.
Old 10-03-2007, 03:31 PM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
Won't you be re-using your EJ20 cam gears? That will eliminate the AVCS anyway, no?
Jay
Old 10-04-2007, 10:20 AM   #6
ted dibiase
Member#: 94752
2003 wrx
wrb
I'm not sure. I'm trying to piece everything together and I'm on a budget. That budget being as much as my wife will let me get away with. I'm more than a little confused about how to piece it all together. I've heard that someone makes some wiring harnesses for this set up but I haven't been able to locate them yet. Thanks again for all of the help.
Old 10-04-2007, 11:15 AM   #7
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp 9.91@146
The only issue I think you are going to have is going to be with the AVCS.
You need the AVCS solenoids, AVCS hard lines that are on the front of the heads and AVCS cam gears.
Don't have one of these items and AVCS won't work.
Don't have the hardlines and you will burn up the front cam bearing as thats where it gets it's oil...oh and you'll have a rather large oil leak.
Don't have the solenoids and you will have a rather large oil leak.
As for controlling the AVCS, the only way you will be able to do it is with a standalone ECU....Hydra or AEM. The stock WRX ECU can not be flashed to control the AVCS. You will then have to manually wire from the standalone to the AVCS solenoids as you don't have the wiring to run it in your car now.
SloRice is offline   Reply With Quote
Old 10-04-2007, 11:24 AM   #8
ted dibiase
Member#: 94752
2003 wrx
wrb
That is an informative post. Hopefully Tristan at Fred Beans can hook me up with that stuff.
Old 10-04-2007, 01:11 PM   #9
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp 9.91@146
Also, I'm not sure if the cam sensor pickups on the cams are different between the STI and the WRX. If they are, your stock WRX computer is going to have an issue with that. If you go standalone, it won't matter because you can configure the cam sensor for any type of pickup.
Old 10-04-2007, 01:34 PM   #10
SPIN2GST
Member#: 106665
05 Buschur Powered
Evo w/corn in da poop
Did you also buy the STi cams? I cant remember if the cams come with the heads or they are seperate.
SPIN2GST is offline   Reply With Quote
Old 10-04-2007, 01:40 PM   #11
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp 9.91@146
When I priced out a set of heads from the dealership, I think the cams are seperate.
Just ordered a Invidia Q300 Catback, What else do I need to hook it up? STIStalker Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 06-05-2010 02:01 AM
Finally bought ej257 block, What else do i need ? sgiord86 Built Motor Discussion 13 09-02-2009 04:44 PM
Finally decided to go with the Blouch 18G, what else do I need to get? lateralus1082 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 29 03-24-2009 06:49 PM
Going to install mods what else do I need? breathinez Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-09-2006 11:40 AM
Selling My 04 Sti Springs To A 02-03 Wrx Owner...what Else Does He Need? mpower22 Brakes, Steering & Suspension 2 07-23-2004 05:54 PM
