Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2016
Old 01-25-2008, 05:15 PM   #1
Rudywrx04
Member#: 134273
04 VF 48 P&P
289 WHP 275 WTQ
Default Stage 2 1 step colder plugs
I have been running stage 2 for about 30k miles with regular plugs. I installed 1 step colder iridium and all I can say is WOW! Seems to make the car run smoother and faster. Of course this is by my butt dyno. I know this is not Earth shattering news but for anyone who has not done it I would recommend it. I have about 70k on the car. Do you guys think this was just because they were new plugs or do the 1 step colder ones make that big of a difference? Maybe a combination of both.
Rudywrx04 is offline   Reply With Quote
Old 01-25-2008, 06:00 PM   #2
CynicX
Member#: 48199
06 WRX
Maybe the SLIGHTEST gains from swapping to one step colder without tuning the car for them. Probably if you are actually feeling a difference its because the old plugs were.....old.
Colder plugs reduce cylinder temp by better transferring heat into the head.
Now if the car retarded timing you could potential gain some back....like I said the slightest of gains with just installing plugs. You would have probably noticed the same results with the stock heat range plug esp. since the car is tuned for the stock range plugs. Colder plugs will foul faster and you'll get worse MPG (probably an un noticeable amount)....on the bright side you'll be less likely to have pre ignition and detonation....
CynicX is offline   Reply With Quote
Old 01-25-2008, 06:05 PM   #3
AllAWD
Member#: 17079
I was also thinking it was new plugs not one-step colder that made the difference. I don't even think protuners recommend colder plugs for stage 2.
30k is about as long as plugs last if you drive hard on stage 2.
AllAWD is offline   Reply With Quote
Old 01-25-2008, 06:16 PM   #4
CynicX
Member#: 48199
06 WRX
Agile Auto actually recommended me to go with colder plugs when I was protuned at stage 2......but I didnt until I upgraded the turbo....
Old 01-25-2008, 06:22 PM   #5
Rudywrx04
Member#: 134273
04 VF 48 P&P
289 WHP 275 WTQ
According to Unibombers Manifesto. You suppose to do it at about 100 HP over stock. I did change my plugs once at 35k, but put the same heat range. I probably wont get re - pro tunned just for this though. I hope I do not have problems we shall see.
Old 01-25-2008, 06:29 PM   #6
AllAWD
Member#: 17079
Really? I thought I even asked Hill and he said not to maybe he just said don't bother.
Old 01-25-2008, 06:39 PM   #7
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Now with more clunks!
PDX did the same with me. My stage 2 was + PnP headers + TB and a turbo inlet.
02WHITEDUB is offline   Reply With Quote
Old 06-29-2010, 07:56 PM   #8
SleepyWeasel
Member#: 192060
2004 WRX
Cool! This pretty much answered my question. I don't know why I had it stuck in my head that a step colder was a good idea for just stage II. About to go stage II, and my plugs are (I think) asking to be changed. Now I can go ahead and by stockers!
SleepyWeasel is offline   Reply With Quote
Old 01-25-2008, 06:20 PM   #9
quadtard
Member#: 104206
2004 WRX
Tunnel Ram Gray
Yeah, I don't think stage 2 puts out enough power to think about running colder plugs. I would think you would just wind up fouling them sooner. Its almost time for me to change my plugs, and I'll be going to one step colder, but I'm running an 18g.
quadtard is offline   Reply With Quote
Old 01-25-2008, 06:35 PM   #10
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
Of course Spark Plugs add like 10whp!!
I will just being using the OEM Spark Plugs.
tux121 is offline   Reply With Quote
Old 06-29-2010, 11:27 PM   #11
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
is that 100hp crank or whp? Even if its crank, it almost seems like unless you upgrade the turbo, 1 step colder are not necessary, because 100 crank horsepower over stock is tough to achieve on a wrx with stock td04 or for an sti with stock vf39, vf48.
scoobystas is offline   Reply With Quote
FS/SOCAL HKS SSQV var 1 and 2, NGK 1 step colder plugs. JasonSTI2005 Engine/Power/Exhaust 27 02-05-2009 01:36 AM
1 step colder plugs? REXLR8 Service & Maintenance 13 05-11-2005 03:58 PM
adjusting timing for 1 step colder plugs kenlee Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 01-28-2005 12:26 AM
Time for 1-step colder plugs? Jard Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 12-14-2004 04:46 PM
Knock after 1-step colder plugs? SJwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 10-22-2003 04:40 AM
