Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2016
Old 01-26-2008, 09:51 PM   #1
1320Fastback
Member#: 131461
1998 Outback
White/Grey
Default How to change starter contacts.
This is a little write up for those of you whose starters “click” when you turn the key. While this is not the only thing that may cause your starter to click it is very likely one of the reasons.
Note: My car is a stock 98 Outback, 2.5L NA, 4EAT. I don’t know if older/newer or standard shift transmissions use a different starter or not, but I would be surprised if the internals are different.
I am NOT responsible for any damage you do to your own car, house or whatever. While this is not a difficult project, we all know that Sh_t happens.
  • Raise driver’s side of car and place on jack stand. It’s not necessary to lift the car off the ground as long as you can slide under it comfortably.
  • Write down radio station presets and disconnect battery.
  • Remove air chamber bolts 10mm and air chamber mount 12mm (yellow arrows below).
  • Remove the B+ wire from the starter and unplug the ING wire.
  • Loosen the top starter mounting bolt 14mm (red arrow above).
  • Remove the bottom starter mounting nut and washer 16mm. (I used a 16mm socket with wobble joint and a 14” extension, 3/8 ratchet).
  • Remove the top mount bolt and remove the starter from the top of the engine bay.
  • Remove the 3 solenoid cover screws then the cover. (yellow arrows below)
  • Remove the plunger, there is a spring and a little ball that may fall out also.
  • Remove the B+ post. Hold the post with a 13mm (it’s the never been used wrench in the back of your roll away drawer) the outer nut on the post is 14mm.
  • Removal of the other post and contact is the same as above.
  • Hold the contact with pliers and tap out the stud with a nut on it to protect the threads.
  • Press new contact onto bolt with pliers.
  • Reinstall is the reversal of removal.
  • Connect the battery last and push the CD back into the CD player.
My old contacts measured .056” thick and the new ones are .095”thick. The old plunger measured .066” thick and the new one is .080” thick. These had over 188,000 miles on them. The new ones are the two inner ones.
1320Fastback is offline   Reply With Quote
Old 01-27-2008, 03:33 AM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Nice job 1320Fastback. I'm sure this will help a lot of folks.
Cougar4 is offline   Reply With Quote
Old 01-28-2008, 07:02 PM   #3
voodoochylde
Member#: 135005
1999 Impreza L
Red
Good Job! I did this on my old '90 Legacy before she threw a rod. Hardest part for me was getting the daggone bottom bolt out and back into the starter.
Hrm...looks like the contacts are exactly the same on your '98 and my old '90...
voodoochylde is offline   Reply With Quote
Old 01-28-2008, 08:45 PM   #4
1320Fastback
Member#: 131461
1998 Outback
White/Grey
Yea I think Nipondenso(sp) starters are all pretty much the same.
My 86 Toyota 4Runner is VERY similar to my 98 Subaru.
Old 02-04-2009, 05:03 PM   #5
fredythemachine
Member#: 159344
Thanks for the thread!!!
It saved me a couple of bucks, it has actually cost me 10$!
I had to go to a starter-alternator shop to get the contacts.
My car is a 97 legacy mt and has 314k km on it, so the contacts were worse than yours.
Really easy job to do, I didn't have to raise the car at all.
fredythemachine is offline   Reply With Quote
Old 10-03-2011, 09:55 PM   #6
dvancleve
Member#: 5211
2007 Outback XT Ltd.
Diamond Gray Metallic
Smile Thanks and a some notes...
I got mine swapped out with less difficulty than I expected. I got the top bolt out with a 14mm socket and 6" extension from the top. I got the bottom nut off with a 17mm socket and the same extension. I pulled the starter out from the bottom. I used a rebuild kit from eBay: http://cgi.ebay.com/ebaymotors/?cmd=...m=220757918951 which I tried to confirm was right for my '97 Legacy Outback 5 speed, but the rod on the plunger that I got was much shorter than the original:
I will try to get the correct part from the seller or maybe a 50% refund or something. The washer on the plunger was a lot less worn that the side contacts so I filed it a bit smoother and reused it. My contacts looked like this:
Anyway, thanks again to 1320Fastback and I hope my notes might help somebody else a bit... Doug
Update: I got the correct plunger from the eBay seller and got my return postage refunded. Seller is "suppersellstore"
dvancleve is offline   Reply With Quote
Old 03-11-2012, 04:18 AM   #7
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Question
On this site here which one of the contacts fit the starter on a 97 Outback?
http://www.nationsautoelectric.com/densoparts.html
SubaruImpreza_power is offline   Reply With Quote
Old 05-25-2012, 12:09 AM   #8
jk91001
Member#: 280915
Thanks to the original poster. I replaced the 2 connectors on my 1999 Legacy SUS Special Edition today. Went pretty smooth, best as I can tell. I didn't replace the plunger, it looked to be in good shape, but I frankly didn't read the full post well enough to order one to be on the safe side. It sounds to my ear that perhaps the starter turns a bit longer before it actually gets the engine to turn over (maybe just a 1-Mississippi count), but hopefully it's just my imagination and I haven't just kicked the problem down the road a bit. I was getting the loud click with increasing frequency, especially in the AM, so I was happy to find this solve online. Cheers. jk
jk91001 is offline   Reply With Quote
Old 05-27-2012, 05:11 PM   #9
KyleH
Member#: 203780
When you say click, do you mean one click and then no cranking at all or click click click click like when your battery doesnt have enough power to turn over?
KyleH is offline   Reply With Quote
Old 05-27-2012, 09:06 PM   #10
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
when the starter contacts go out it's just one solid click and nothing else.. I never heard the click sound like anything else as far as how it sounds.. my guess is he mean it was starting to happen more often.
Old 05-28-2012, 08:40 PM   #11
jk91001
Member#: 280915
That's right. Sorry to be vague. One click, increasing frequency as to whether on any given day the car would start w/o a problem or NOT start, with this problem. Generally on the 3d try it would connect and turn over on the days it was troublesome, but I had a few occasions where after a few minutes of dealing with it I was still stuck.
How to sync iPhone contacts with Pioneer AVIC-Z2 Bluetooth?? island boyeee Car Audio, Video & Security 2 01-20-2010 12:41 PM
How do you open forward opening hoods and how to change bulbs on headlights of cars t rice h8r Off-Topic 18 05-18-2006 11:36 PM
how to pull starter on '95-ish legacy? alacrity024 Legacy Forum 0 03-21-2004 08:14 AM
How to change filter w/o changing oil? TimStevens Service & Maintenance 11 04-29-2003 08:49 AM
changed dash color/how to change cruise control light? wrx_n_ah Electrical & Lighting 16 04-24-2003 03:01 AM
