Old 01-29-2008, 12:29 AM   #1
SuperTurbo
Member#: 152318
2002 mazda
mpv
Default How to modify the stock dummy water temp gauge to real water temp gauge?
OK... at the NA gauge post, we all understand that the temp gauge inside the dashboard is a dummy gauge.
So... can we modify the wiring or cut some parts off to make it become a real gauge?
If we can do that, in another word, we can put 1 more gauge into that slot.
SuperTurbo is offline   Reply With Quote
Old 01-29-2008, 02:04 AM   #2
impreza_GC8
Member#: 123295
2000 2.5RS moneypit
2012 Ford Fusion 6MT (DD)
I'm not sure I understand what you are saying....I would like to know though. I was under the impression my temp gauge was "real" LOL.
EDIT:
Is this what you are referring to? (Stolen from another thread
Originally Posted by H-Dtech View Post
the stock subie water temp gauge is basically a dummy gauge, its only moves at set temps. so when your car is first warming up it won't move until a set temp, then when it is at normal operation temp. it won't move until temps get into a dangerous area. basically they didn't want every commuter idiot that didn't know anything about cars bringing in there car every time they got stuck in traffic and the temps climbed abit. so the stock gauge only gives you enough info to get into trouble, and not enough to prevent it.
impreza_GC8 is offline   Reply With Quote
Old 01-29-2008, 12:08 PM   #3
SuperTurbo
Member#: 152318
2002 mazda
mpv
Bingo! that's what am I referring to!
I just don't want to buy put so much of those stuff into the car, and attract Police & Thief's attention!
Old 01-29-2008, 01:16 PM   #4
2.5i
Member#: 112986
N/A Cam'd & Cornfed
DOM TUNED 06 Impreza
I didnt know gauges attracted the attention of the police.
2.5i is offline   Reply With Quote
Old 01-29-2008, 03:06 PM   #5
joecerv
Member#: 110459
2006 Impreza 2.5i
Steel gray metallic
In older cars, I can remember cars from the late 70's, that the temp gauge provided an actual reading.
As indicated above:
"basically they didn't want every commuter idiot that didn't know anything about cars bringing in there car every time they got stuck in traffic and the temps climbed abit."
that the manufactures made the 'upgraded' temp gauge.
Take a look at the MY08 impreza 2.5i. The temp gauge has been replaced by a dummy light that stays on until it reaches safe normal operating temperature.
I do not have an answer, but, I do believe it can be done.
joecerv is offline   Reply With Quote
Old 01-29-2008, 08:14 PM   #6
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
Does anyone know what type pf sending unit is used? If you know the sending unit (I think voltage range is really the only important detail) then you should be able to wire the OEM sending unit to any gauge that is compatible. If the sending unit is a "dummy" sending unit (only sends a cold/hot signal) then the gauge you use wont help. Need more info! And out of curiosity, being a dummy unit, how does the OEM gauge climb from cold to operating temp slowly? Seems like a dummy unit would be either all the way cold or almost immediately at operating temp once the sending unit gave it the signal. Feed my brain!
RaceFaceXC is offline   Reply With Quote
Old 01-29-2008, 11:59 PM   #7
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
That's wierd... See my temp gauge gradually rises with the warming of the motor. And further more, earlier, the gauge deflected 3-4 degrees of angle while sitting at a light (I'm having cooling issues). It's also gone up 3/4 of the way, and as soon as I got moving in traffic again it began dropping down. Now you're saying these things aren't really actively giving the driver info?
Plays_With_toys is offline   Reply With Quote
Old 01-30-2008, 04:29 AM   #8
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
No, they're not. My factory gauge sits at its "normal" indication with actual coolant temp being anywhere from 70 - 100*C. I haven't had temp any higher than that, so I don't know at what point the gauge will budge. 70*C is well below the thermostat setting, so 70 is not what I would consider "normal", but the gauge thinks it is.
This isn't just a Subaru thing. There are very, very few cars that have real gauges, and it's for exactly the reason that H-Dtech said (and that I've said in other threads).
As for the original question, unless you're going to tear apart the instrument cluster and put a new gauge head behind the existing gauge face I don't see any way to make the dummy gauge into a real gauge.
Pat Olsen
Old 01-30-2008, 10:23 AM   #9
subikid
Member#: 114122
1990 miata(RIP 05rs)
red
Pat and OP,
Excuse any typos, I'm on my phone...
My aftermarket temp gauge follows the oem gauge almost perfectly (or visa versa). Also, when I driver slowly or let it warm up just sitting, the oem temp gauge goes slowly up, following my other temp gauge.
Another thing I notice is the popping we get sometimes. When my car is very cold and you get on it (don't do that!) and shift, it doesn't pop. However, as the oem temp gauge goes up a little, in between the first and second hash, and you get on it, when you shift, I get an EXTREMELY loud pop, so loud it has scared people. Then, when the oem temp gauge reaches normal operating temp, no more extremely loud popping.
I say this because I based my driving on my oem temp gauge before I got my aftermarket, so that I didn't pop and scare people sheeetless.
Based on these things, I don't think the oem gauge (at least for the 05) is a dummy, but I do think that it works in intervals, maybe of 5 or10 degrees, and thus slowly rises, paralleling my other wt gauge.
Kevin
subikid is offline   Reply With Quote
Old 01-30-2008, 07:42 PM   #10
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
well i think it depends on the sending unit more than the gauge.. the gauge would be more complex as a "dummy" gauge than if it were just a voltage sensitive gauge. and the sending unit could be a "dummy" quite easily with the use of a bimetallic strip or bellows, etc. I would guess the newer stuff is a solid state sending unit and im sure they could make it send whatever signal they want @ whatever temp they want with that type. Still, no one knows if the sending unit is the "dummy" or if its the gauge?
Old 01-31-2008, 12:13 PM   #11
RyanE
Member#: 118354
2005 Legacy GT LTD
Regal Blue Pearl
My Legacy has a "dummy" gauge as well, so I poked around in the service manual to see what the schematics say. In my car, the gauge gets its info from the ECU. I think that would make it pretty hard to make it accurately move.
You folks might want to get ahold of the factory service manual page that shows the "combination meter" (instrument panel) wiring diagram and see if that's the case for your cars as well.
-Ryan
RyanE is offline   Reply With Quote
Old 01-31-2008, 12:41 PM   #12
8Complex
Member#: 922
04 FXT
Red
I know the ECU gets a real temperature reading off of the stock sensor, so I suppose it'd just be a matter of making tick marks on the dash gauge at certain temperatures so you're actually able to read it.
8Complex is offline   Reply With Quote
Old 01-31-2008, 01:50 PM   #13
RyanE
Member#: 118354
2005 Legacy GT LTD
Regal Blue Pearl
I think the OP's desire was to have a gauge that fluctuated as the motor heated and cooled, such as when the car was stopped in traffic. The (late model only?) stock gauges are "damped" or "dummy" gauges so that they don't move from the middle position unless it's almost too late.
-Ryan
Old 01-31-2008, 09:32 PM   #14
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
Does the ECU send the gauge real temp data that is "dampened" @ the gauge or does the ECU do the "damping" to the signal it sends the gauge before it leaves? I guess im just trying to find out of the gauge being replaced with a accurate gauge will allow for accurate current temp readings or if the ECU needs to be reprogrammed to send the more accurate data to the gauge in the first place. I guess im asking about an 07 2.5i specifically but info about any year would be appreciated by someone im sure.
Old 02-01-2008, 06:38 PM   #15
Guerice
Member#: 51519
2000 SRP GF
AKA Lilwgn
Ok let me get this straight....
When you want to wire up a water temp gauge, whitch wire do you take?
The one going to the gauge or the one from the sensor?
Can you tell me what are the voltage of both wires from the service manual?
I know it's alot of questions but I think i can figure how to do it with those answers.
I'll check in my service manual too see if i can figure it out in the meantime.
Guerice is offline   Reply With Quote
Has anybody modified the stock blow off valve to be louder? kenshiro Factory 2.0L Turbo Powertrain 14 06-13-2012 12:28 AM
how to read the stock turbo gauge hagood22 Newbies & FAQs 6 03-24-2008 11:31 PM
How to modify the wastegate spring? yellowmustang94 Factory 2.0L Turbo Powertrain 8 02-24-2006 05:32 PM
How to read the stock turbo boost gauge? mRgUnN Newbies & FAQs 13 05-31-2003 12:30 PM
('93-'01) How should I begin to modify the RS with $500? jImp Impreza Forum 22 08-08-2001 09:31 AM
Message Board Statistics All times are GMT -4. The time now is 02:36 AM.
