Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 02-08-2008, 10:52 PM   #1
sidwin
Member#: 168099
2004 impreza sti
wrb
Default can i zip tie second o2 sensor and put wideband o2 in that spot?
I got my car stage 2 and i would like to pull out the existing o2 sensor and put my wideband there and i'm trying to not have to take the down pipe off again.. i read from the notes the map for stage 2 will remove CEL for o2 sensor. does that mean i can simply pull it out and zip tie it to something?
Thanks,
Sid
sidwin is offline   Reply With Quote
Old 02-09-2008, 12:40 AM   #2
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
yes ,but you car will run a bit rich ,mine idled about 14.0 to 1 when I did it
a6n6d6y is offline   Reply With Quote
Old 02-11-2008, 06:18 PM   #3
dpbgst13
Member#: 106582
2002 Suspension mod
Siegel Tuned FP GREEN
Don't do that. Just pull the downpipe out. It takes 30min. Its only 7bolts. If you take out the second o2 the ecu will hang at 13.5 a/f for sometime before it goes back to 14.7. It has to do with some sort of delay table.
Just do the job right. It will make it easier for a tuner if you get tuned.
dpbgst13 is offline   Reply With Quote
Wideband O2 sensor and separate wiring/gauge elislider Engine Management & Tuning 3 05-18-2010 05:33 PM
FS: (FL) PLX Wideband O2 sensor and wiring javasti Engine/Power/Exhaust 2 03-18-2010 02:14 PM
WTB: Knock Link with sensor, and a wideband o2 sensor with monitor SolidSnake Private 'Wanted' Classifieds 2 05-04-2006 09:30 AM
Wideband O2 sensor and Helix V2 dp JDM 3SGTE Engine Management & Tuning 7 03-03-2005 09:24 AM
ne1 here has a deltadash and/or wideband o2 sensor? Benjamin Tang Vancouver Impreza Club Forum -- VIC 4 11-18-2003 04:37 PM
