Welcome to the North American Subaru Impreza Owners Club Thursday April 28, 2016
Old 02-23-2008, 09:49 PM   #1
48mpg
Member#: 58405
2004 Element GT65'd
Hydra, Hydramist'd STi
Default Broken Nipple on Purge Control Solenoid Valve
i was swapping out Intake manifolds today and snapped a nipple off the purge control solenoid valve.
I am running a hydra w/ rotated mount turbo, do i even need this? I'm assuming that its not essential and for emmissions, how do i go about bypassing it?
thanks
48mpg is offline   Reply With Quote
Old 02-24-2008, 03:10 AM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Considering the hydra does not use the OBD system, no you don't need it. Just cap everything off.
Tony
Old 02-24-2008, 07:40 PM   #3
48mpg
Member#: 58405
2004 Element GT65'd
cool thanks, just did it, capped off everything,
I left the hard line coming out by the fire wall to vent and capped off both ends of the hard line under the manifold
the MAP line to Hydra is still going into the little black nipple coming out of the intake manifold ,
side question?? that black nipple, any idea where i can get one that is a 90, i guess i'll run over the theDepot and check if they have anything that would fit
Purge Control Solenoid Valve DELETE! Any Info? guitarmaster1195 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-27-2009 03:15 PM
WTB: Purge control solenoid valve jblaine Private 'Wanted' Classifieds 7 04-21-2009 08:51 PM
Purge Control Solenoid valve? Synx Service & Maintenance 4 07-02-2008 05:40 PM
Purge Control Solenoid Valve?? abosworth Normally Aspirated Powertrain 3 07-21-2005 04:20 PM
Code 35 purge control solenoid valve troubles theascen Service & Maintenance 2 04-02-2004 04:36 AM
