Welcome to the North American Subaru Impreza Owners Club Thursday August 21, 2014
Old 02-27-2008, 01:54 PM   #1
HomeRun217
Member#: 112765
2005 Impreza WRX
Crystal Grey Metallic
Default Had a 'Hiccup' - advice?
Was wondering if someone has had this problem before or knows what it could be...
I'm just driving at a fairly normal speed, when all of a sudden, my car "hiccups". The revs drop almost 1,000rpm, and feels like my car has hit a wall. This hiccup is less than a second long, and then the car drives normal as if nothing has happened.
This has happened twice.
My theory is air/water in the fuel lines, because it has been very cold outside and there could be possible condensation in the gas tank.
Any ideas on what could have caused this, and how I could resolve this would be much appreciated!
HomeRun217 is offline   Reply With Quote
Old 02-27-2008, 01:57 PM   #2
Okeyd57
Member#: 113271
2006 STi
Obsidian Black Pearl
Could it be your A/C compressor engaging ? If that's not it, I'm not sure what to tell you !
Okeyd57 is offline   Reply With Quote
Old 02-27-2008, 04:14 PM   #3
HomeRun217
Member#: 112765
2005 Impreza WRX
nope, not the AC. Even if it were a faulty wire or something with the A/C...it wouldn't have been that sevre.
When this "hiccup" happens, its scary...feels like my car has thrown a road or something...not that i know what that would feel like, but i'm just saying its not the slight loss in power you get from turning the AC on.
Thanks though!
Old 02-27-2008, 04:28 PM   #4
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
Only felt something like once in someone's car with boost creep and that was under load... not driving along.
Mavrik is offline   Reply With Quote
Old 02-27-2008, 04:32 PM   #5
nhmtns
Member#: 94283
'05 OBXT Stage 2
Min bil är svart
My car does this when it's snowing. It feels like fuel cut, but I think it's an airflow problem. I have no idea what causes it.
nhmtns is offline   Reply With Quote
Old 02-27-2008, 04:49 PM   #6
NRTmotorsports
Member#: 16517
'13 BRZ
Mine acts up to in the snow, im glad to see someone else has the same problem I have been trying to figure out for the past few winters its really strange
NRTmotorsports is offline   Reply With Quote
Old 02-27-2008, 08:46 PM   #7
nhmtns
Member#: 94283
'05 OBXT Stage 2
Min bil är svart
Misery loves company.
Old 02-28-2008, 11:22 AM   #8
HomeRun217
Member#: 112765
2005 Impreza WRX
bump!
Does anyone else have a huge problem starting their Suby in cold (below freezing) weather?
It took me about 5 attempts to start my WRX this morning...just keeps cranking and cranking...
would this be a battery or starter issue?
Old 02-27-2008, 04:31 PM   #9
DiscoGsus
Member#: 47646
0211 RallyWagon
DGM Sedan
Are you driving under steady boost at the time? Could be, with the cold weather, you run knock just at the edge of operation so it pulls a lot of timing for a little while.
Its not condensation in the gas line.
What mods do you have?
DiscoGsus is offline   Reply With Quote
Old 02-27-2008, 04:49 PM   #10
HomeRun217
Member#: 112765
2005 Impreza WRX
Utec - Stage 2 map
TurboXS Stealth back mated to the Prodrive Axle back
SPT Intake (please don't jump to conclusions and blame this as the source )
This happens under load. first time was moderate load, 2nd time i was flooring it in 2nd gear. It is random, so i cannot replicate it whenever i wish, otherwise i'd take a datalog. All my data logs look normal...just running a bit rich.
Old 02-27-2008, 04:46 PM   #11
pweizman
Member#: 131268
.... GOD........
Could be a slight miss by one of the plugs...my car did this before, but threw a misfire code...
Patrick
pweizman is offline   Reply With Quote
Old 02-27-2008, 04:50 PM   #12
HomeRun217
Member#: 112765
2005 Impreza WRX
Patrick
my CEL has been on for a while, but its the pesky "evaporative emissions control leak (small)" code.
I was thinking it could be a plug misfiring...
Could changing them out for 1 step colder help?
Old 03-01-2008, 11:24 AM   #13
flstffxe
Member#: 155358
2008 Forester
Steel Silver
^^ did you guys ever check for the code with a code reader. even though a cel never came on a code may still be stored.
flstffxe is offline   Reply With Quote
Old 03-01-2008, 03:29 PM   #14
ccc_is_for_me
Member#: 171561
2002 WRX wagon
blue
it sounds like an air problem to me. That is exactly what would happen if your throttle body suddenly closed or air flow suddenly stopped or decreased significantly. It isn't the cold because everyone is saying it happens when it is snowing, not just when it is cold. My assumption is that since snow is real light that it gets sucked to the cold air easier than rain. This could cause water to be getting in and likely consfusing the ecu at some point and closing the throttle on you or decreasing gas flow significantly. This is just a theory, maybe it is ridiculous but it has to be the snow, not the cold
ccc_is_for_me is offline   Reply With Quote
Old 03-01-2008, 05:35 PM   #15
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
Not jumping to conclusions, but for lack of any other solutions perhaps try replacing the stock intake. You won't really lose any power and it might solve your problem.
whtlegacy is offline   Reply With Quote
Old 03-02-2008, 08:48 PM   #16
HomeRun217
Member#: 112765
2005 Impreza WRX
Understandable... but it's been happening to others who are using the stock intake.
It didn't happen when it was snowing... I think its the cold.
Old 01-11-2011, 08:54 AM   #17
sublyme
Member#: 244114
2005 WRX 18g EWG
Has anyone isolated this issue??
I have had my subie replicate this exact behavior at random, while under moderate load, and snowing. throws no visible cell..
sublyme is offline   Reply With Quote
Old 01-14-2011, 09:07 AM   #18
sublyme
Member#: 244114
2005 WRX 18g EWG
*bump for an answer*
Old 01-16-2011, 08:46 PM   #19
'02 Subaru Rex
Member#: 160725
2005 STi
WRB sittin on GOLD
I've had it happen a couple of times this winter as well. I have no idea what the cause of it is but it bugs the **** out of me.
Still looking for an answer.
'02 Subaru Rex is offline   Reply With Quote
Old 01-16-2011, 08:55 PM   #20
Ernest
Member#: 45076
2004 Stg2 Wagon 4eat
Did you try some dry gas, just in case it was from water in the tank. If you run the tank low condensation can build up.
Ernest is offline   Reply With Quote
Old 01-20-2011, 02:30 PM   #21
sublyme
Member#: 244114
2005 WRX 18g EWG
I have tried getting different gas. Tried injector cleaner. Looked diligently for a vac leak. I have mentioned it in different threads in completely different forums. No clue what is causing this. Anybody have any other ideas?
Old 01-20-2011, 04:59 PM   #22
sublyme
Member#: 244114
2005 WRX 18g EWG
Just like post#6, this behavior Only occurs when its snowing. If it were condensation in the tank, wouldn't this occur at other times other than snowing?
Any young people with kids? Or had kids at a young age with advice? stevey323 Off-Topic 30 02-26-2007 12:22 PM
had a buddy get a bad ticket any advice WRX_Nick Texas Impreza Club Forum -- TXIC 24 03-20-2006 08:58 PM
More banking advice. Credit card, never had one, want to build credit. 2.5RSMatt Off-Topic 63 09-27-2004 11:24 PM
Tire had a nail, need advice for next track day ilara72 Tire & Wheel 2 09-10-2004 07:29 PM
