Old 03-19-2008, 11:42 AM   #1
06AWD
Member#: 112843
2011 SWP STI Sedan
Speedline/RCE/Cobb
Default Gas light comes on too soon
It has happened twice now. The gas light comes on when there is still about 1/8 of a tank left (according to the gas guage). I consistantly get the same gas mileage since I drive mostly highways, and according to my odometer, there is still a good deal of gas left in the tank when the gas light comes on. Any thoughts on what could be causing this? Car is 2006 WRX Tr, 45K miles, stock. Thanks.
06AWD is offline   Reply With Quote
Old 03-19-2008, 01:17 PM   #2
Jim2752
Member#: 147610
2007 Stage 2 STi
I had this same problem with my jeep. When you get gas do you fill up your tank or only put in a few gallons? I have no idea if this will work for your car but the solution for my jeep was a trip to Florida. After going through a couple tanks of gas the gauge started working right.
Jim2752 is offline   Reply With Quote
Old 03-19-2008, 01:39 PM   #3
06AWD
Member#: 112843
2011 SWP STI Sedan
Speedline/RCE/Cobb
Always drive it til it's empty, then fill it.
Old 03-19-2008, 02:28 PM   #4
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
how much does it take to fill it after the light comes on ?
a6n6d6y is offline   Reply With Quote
Old 03-19-2008, 02:32 PM   #5
06AWD
Member#: 112843
2011 SWP STI Sedan
Speedline/RCE/Cobb
Not sure since it's only happened twice, but I see what you're getting at. If it take a full tank even though it's not showing "empty", something is screwed up. But any idea as so what would be causing this? Is something lose? broken?
Old 03-19-2008, 03:29 PM   #6
funky monk
Member#: 143094
08 LGT
DBM
I remember this happened to me once. The light was on much earlier than normal, I filled the tank and went on my way. Hasn't happened since.
funky monk is offline   Reply With Quote
Old 03-19-2008, 03:41 PM   #7
WRXLTD
Member#: 136314
2014 Grand Cherokee
We have low gas level idiot lights?
My tank is never less than 1/4...never seen this light come on.
WRXLTD is offline   Reply With Quote
Old 03-19-2008, 04:16 PM   #8
MOBBiN
Member#: 128441
2006 STi WRB
01 BRP RS, 01 Silver XJ
+11111
you should NEVER let it get past a 1/4 tank
MOBBiN is offline   Reply With Quote
Old 03-19-2008, 04:38 PM   #9
jasonallenross
Member#: 125978
2002 WRX Wagon
Originally Posted by MOBBiN View Post
+11111
Well, why don't they just make the tank 1/4 bigger?
jasonallenross is offline   Reply With Quote
Old 03-19-2008, 04:53 PM   #10
zombiekiller
Member#: 167010
letting gas tank fall below 1/4 = shorter fuel pump life = teh suck.
fill it up sooner.
zombiekiller is offline   Reply With Quote
Old 03-19-2008, 03:43 PM   #11
skydes
Member#: 141347
2005 WRX
My light comes on where there is about 4 gallons left.
skydes is offline   Reply With Quote
Old 03-19-2008, 03:43 PM   #12
madkayaker
Member#: 57378
2002 wrx w/ sti swap
04 sti, 11 forester xt
sometimes mine comes on at a 1/4 then goes back off. I rarely let it get that low though.
madkayaker is offline   Reply With Quote
Old 03-19-2008, 05:01 PM   #13
sluflyer06
Member#: 111641
2014 BRZ Ltd - DGM
E30 318is
I've heard that as well...I'm sure I really shouldn't be running mine down to the light with a Walbro every tank. I just like the feeling of getting a fresh full tank of gas LOL.
I think even subaru says not to get into boost once the gas light comes on, so I'm sure we shouldn't be running it that low. I'm actually suprised I haven't had any fueling problems with a near empty tank and a walbro. My best friends drag car runs a GSS342 and runs into major fuel pressure problems below 1/4 tank.
sluflyer06 is offline   Reply With Quote
Old 03-19-2008, 05:17 PM   #14
my scoop eats babies
Member#: 174894
I think this is pretty normal. For my car, the gas light will come on if I start the car with 1/4 tank or even a little more. It will stay on for 2 minutes, then shut off until it's down to just above empty, then it comes on and stays on.
my scoop eats babies is offline   Reply With Quote
Old 03-19-2008, 05:23 PM   #15
06AWD
Member#: 112843
2011 SWP STI Sedan
Speedline/RCE/Cobb
What year is your car?
Old 03-19-2008, 05:52 PM   #16
Member#: 174894
It's an 02.
Old 03-19-2008, 05:22 PM   #17
06AWD
Member#: 112843
2011 SWP STI Sedan
Speedline/RCE/Cobb
So I guess the conclusions here are that:
1. I shouldn't worry about it. It will go away.
2. I should get gas before the light comes on.
It reminds me of when I was a little kid. I would fall and scrape my knees. Later, I would hit them on something by accident and say, "Ouch, that hurts." And my parent's would say, "Well if that hurts, don't do it."
So I guess I could hope it goes away or never let the tank get below 1/4 tank, but the problem would still exist.
Old 03-19-2008, 06:34 PM   #18
manookie
Member#: 125495
06 Wrx
SGM stg 5+4-7
I've had this issue too. I thought nothing of it until the gas light came on with a full tank and the car threw a cel. bad fuel sending unit. the dealer said its a pretty common occurance.
manookie is offline   Reply With Quote
Old 03-19-2008, 06:42 PM   #19
06AWD
Member#: 112843
2011 SWP STI Sedan
Speedline/RCE/Cobb
^^^ And what was the resolution?
Old 03-20-2008, 01:04 AM   #20
manookie
Member#: 125495
06 Wrx
SGM stg 5+4-7
they had to replace the fuel sending unit... they did so under warranty. they said it would have been around $400 had it not been covered.
Old 03-20-2008, 09:51 AM   #21
06AWD
Member#: 112843
2011 SWP STI Sedan
Speedline/RCE/Cobb
Would not replacing the fuel sending unit lead to additional issues? Or is it more of an inconvienence, as in having the gas light come on too soon?
Old 03-19-2008, 06:50 PM   #22
wango55
Member#: 139895
10 2.5i Sedan
Dark Gray Metallic
Isn't the Gas light supposed to come on with around 2 gallons left in the tank?
If the gas tank is 15.9 gallons, then 1/8 remaining would be 2 gallons right?
I'm not trying to be a jerk - I hope that's the case and nothing is wrong with your car!
wango55 is offline   Reply With Quote
Old 03-19-2008, 09:03 PM   #23
06AWD
Member#: 112843
2011 SWP STI Sedan
Speedline/RCE/Cobb
Yes, you are right, in fact. 2 gallons is 1/8th of 15.9. Just wondering why this would be the first time it would have come on since I bought it in November of 2005.
Gas light comes on early Cakesniffer Service & Maintenance 2 01-08-2009 02:38 AM
gas light comes on early hockeygm Service & Maintenance 10 12-09-2008 08:08 PM
when does your gas light come on? Horten Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 05-18-2004 11:49 PM
How much gas is left when the low gas light comes on? catass STi Forum Archive 11 06-30-2003 07:21 PM
check engine light comes on at low gas? halftendril General Community 1 11-28-2002 03:49 AM
