Old 04-09-2008, 02:12 AM   #1
JamesWilson
Member#: 124833
2000 Legacy Wagon
Mystic Mountain Blueberry
Exclamation Won't stay running, '98 2.2L
Over the last 2 years and 60K miles or so, about once a month the car would fire up fine (hot or cold) and die immediately.
Very recently, and as often as 4-5 times per day, I can start the car and it dies right away again, requiring a healthy dose of throttle to keep it lit the first 5 seconds or so.
All stock, Mobil1 turbodiesel 5w-40 and M1 filter, relatively fresh plugs/wires, fresh gas. The only things I can think of immediately are:
-Old fuel filter (last March, been a ton of miles though!), maybe not enough fuel pressure or gas right away
-Failing vacuum line, purge valve, or Idle Air Control Valve....but otherwise idles normally...oh-- except for an annoying off-idle stumble...hmm that could be it.
Otherwise, the car drives okay.
Any help? Thanks!
JamesWilson is offline   Reply With Quote
Old 04-09-2008, 03:24 AM   #2
kaos200
Member#: 2692
I think you may have nailed it with the IAC, does the problem arise more often when it is cold?
kaos200 is offline   Reply With Quote
Old 04-09-2008, 12:02 PM   #3
JamesWilson
Member#: 124833
2000 Legacy Wagon
Not really....before it was when it was "cold" (not run for a few hours), but now it is mostly doing it when it is already hot.
MY97 Impreza 2.2L -- Cleaned MAF, now car won't stay running Nihilator Normally Aspirated Powertrain 29 09-06-2015 04:12 PM
My car won't stay running.....Utec Pacobeagle Engine Management & Tuning 5 09-18-2005 07:33 AM
Engine won't stay running. Need help. Phantom Rex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 07-14-2004 01:16 AM
HELP.. car won't stay running WRXonmind Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-12-2004 05:40 PM
Help..My won't stay running... vinster02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 09-02-2003 12:11 AM
