Old 04-13-2008, 09:59 PM   #1
sonicyellowbugeye
Member#: 175869
2003 wrx
sonic yellow
Default squeaking problem
hey guys...i have an 03 wrx and every time i roll down or roll up my windows, there would be a loud squeaking noise. I just wanted to know if it's just my car or does everyone has this problem, also if anyone has any advice on how to fix it, i would appreciate it.
sonicyellowbugeye is offline   Reply With Quote
Old 04-13-2008, 11:01 PM   #2
nardvark
Member#: 145108
2002 Impreza TS
Mine does this. I haven't gotten around to fixing it yet, but the things to do (roughly in this order) that I know of are:
1) Make sure the glass is clean, inside and out.
2) Silicone spray on the rubber that rides against the glass.
3) You have to get into the guts of the door and use lithium grease on the tracks.
nardvark is offline   Reply With Quote
Old 04-14-2008, 12:02 AM   #3
sonicyellowbugeye
Member#: 175869
2003 wrx
sonic yellow
Default thanks
sounds like a plan, thanks a lot man
Old 04-14-2008, 12:05 AM   #4
Sudafed
Member#: 70090
2002 2.5 RS
replace the fuzzy window guides, that usually does the trick. there are two outer and two inner.
Sudafed is offline   Reply With Quote
Swaybar Squeaking Problems Always Return -- How can I stop them for good? Messier77 Brakes, Steering & Suspension 3 04-16-2009 04:17 PM
Squeaking problem gone! opio Brakes, Steering & Suspension 0 02-19-2009 06:35 PM
squeaking problem, sudden jolts Mr.Sprinkles Service & Maintenance 4 07-19-2007 05:40 AM
squeaking problem, sudden jolts Mr.Sprinkles Built Motor Discussion 1 07-05-2007 06:18 PM
2005 STi Brake Squeaking Problem Castor Troy Brakes, Steering & Suspension 4 12-07-2004 05:45 AM
