Old 04-21-2008, 02:47 AM   #1
imisplacedmine
Member#: 102922
2012 WRX Wagon
Default Air in power steering line?
I just did a change of fluid for my power steering. Now my wheel is harder to turn sometimes and it vibrates and the power steering pump makes a noise. I used the recommended ATF fluid. I searched and followed the few guidelines of turning the wheel lock to lock about ten times or trying to drive around in figure eights. Neither worked even though I tried them both a few times.
So what should I do?
imisplacedmine is offline   Reply With Quote
Old 04-21-2008, 08:15 AM   #2
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
leave it overnight for the bubbles to settle and then go through the bleed sequence again - do the lock to lock a few times with the engine OFF first so any air in there doesn't just get whisked up again by the pump
UkNuck is offline   Reply With Quote
Old 04-21-2008, 03:12 PM   #3
imisplacedmine
Member#: 102922
2012 WRX Wagon
I gave this a try this morning (after letting it set since last night) and it worked pretty great. I might do it once more after tonight, but otherwise it's in much better order. Thanks for your help
Fix for air in Power Steering MasterKwan Brakes, Steering & Suspension 2 04-04-2009 09:52 AM
air in my power steering lines? IllNastyImpreza Service & Maintenance 5 05-08-2008 09:30 AM
air in power steering iamadam1122 Brakes, Steering & Suspension 7 01-15-2008 04:09 PM
Power Steering Lines always in the way GinoEJ253two Normally Aspirated with bolt-on Forced Induction Powertrain 22 01-12-2004 06:55 PM
