#1 |
Member#: 153038
SCIC
Vehicle:07 STI SWP |
I feel like an idiot but here it goes.....This is a 2007 STI mods are HKS catback and Cobb Intake. Maybe someone can help, yesturday I was adding some oil to my car was missing half a quart. To make a long story short i was in a hurry and i left the oil cap sitting on my intake manifold for about 24 hours unoticed obviously. While i was driving the car i was amazed to how much it pulled it had its initial jump but instead of staying consistent after 5,000 RPM it kept pulling like a champ. Thinking i was going crazy i took my buddy for a drive and he said my car felt faster and this morning my Girlfriend asked me if i did something else to make my car faster
...... I finally notice my oild cap was off check my oil lever and it was fine. My question is does running with your oil cap off release presure in the motor allowing you to inadvertly run more boost or am i going crazy..... On my car before a 2004 gto i know when people were running boost on them the got a breathable type oil cap to releave crankcase presure is this so on our car?Last edited by tico915007; 06-09-2008 at 11:49 AM. |
#2 |
Member#: 153038
SCIC
this is what im talking about
#3 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
n/m---
#4 |
Member#: 165744
Vehicle:2000 LGT 2007 STi |
wow. i never heard of a breathable oil cap, but i'm subscribing to see if anyone knows anything about this.
#5 |
Member#: 158586
Vehicle:2009 WRX Pearl White |
This to me does make sense... Kinda.
When the oil cap is on the engine is constantly creating a vacuum, which could be like saying the engine is "pulling itself", which creates a constant vacuum. You may notice on some high-powered Chevy motors that the valve covers have breathers (usually have K&N style filters on top of them.) The picture you provided with the filter that replaces the oil cap... I just don't like that idea, plus the design scares the crap out of me. (What is holding it on?!) Air filters block most of the airborne debris, but never 100% so who knows what is getting mixed up with your oil. Anyways, removing the oil cap eliminates the vacuum in the crankcase which in turn allows the engine to move more freely. It would be like going from a shirt that is a little snug to one that is a size or two bigger. Last edited by magnum2066; 05-06-2008 at 10:59 AM. |
#6 | |
Member#: 118209
Vehicle:2002 WRX Sedan |
#7 |
Member#: 144779
Vehicle:200X ZOMG a car 100% crabon fibre girlfrendorz |
This is the first I've heard of the breathable oil cap. I'm interested in learning more on it and what applications can utilize it.
#8 |
Member#: 26770
South East
Vehicle:'02 WRX midnight black |
Wouldn't this kill the vacuum needed for the assisted brakes (or is that vacuum created from some thing/place else)?
#9 |
Member#: 92003
South East
Vehicle:04 TDI Passat |
we have something similar to that on our cars its plumbed to the intake...
#10 | |
Member#: 26770
South East
I just remember auto-x'rs running out vacuum and the pedal getting hella heavy (then plowing into cones soon afterwards) as the stories went. |
#11 |
Member#: 158586
Eliminating vacuum in the crankcase has nothing to do with the brakes. Two completely different systems.
#12 |
Member#: 92003
South East
#13 |
Member#: 102749
SCIC
Vehicle:2005 impreza STi OBP' |
There is a decent amount of pressure in the crank case especially in these EJ's.
Why not tap your oil cap with a barbed fitting and run it to a catch can? (along with the other breather lines) I think I'm going to do this. |
#14 |
Member#: 147003
isn't there a company that makes high boost pcv valves? I'm sure I've seen that somewhere.
#15 |
Member#: 26770
South East
Found this related link, seems like a good read for/against:
http://www.supersixmotorsports.com/pdf/PCVBypass.pdf |
#16 |
Member#: 153038
SCIC
so i wasn't going crazy potentially this could of made my car feel "faster"...... it wasnt like it was 100 hp more just felt like the car was losser almost like i was accelarating downhill all the time
#17 |
Member#: 179605
ok so this is a good thing...why wasnt i aware of this before ,,,,,,,can the effect be seen on a normaly aspirated car
#18 |
Member#: 158586
Yep. Even non-turbo vehicles have a vacuum while the engine is running.
#19 | |
Member#: 119532
Vehicle:2006 WRX |
repeat ALL internal combusiton engines are, for all intents, vacuum pumps and create vac as a function of their functioning FI engines just change where they are creating vac when on boost compared to off boost operation. They ALWAYS suck air in at one end and force it out the other end while in operation. |
#20 |
Member#: 16087
South East
Vehicle:02 WRX Back seat with your mom |
Ya know when i get dyno'd i'm going to do that test.
This would be interesting to see. I have 2 oil caps i'll drill one and put a breather on it and have stock as well. |
#21 |
Member#: 153038
SCIC
#22 |
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
Ummmm... what about the vacuum helping the sealing of the rings?
#23 |
Member#: 160991
Vehicle:05 Corn Burner Dirt Silver? |
Vawy intewesting!!
http://www.speedwaymotors.com/p/1877...Breathers.html I found this link. Does anyone know the diameter of the oil cap hole? I would be willing to buy one for 15$ shipped and see if it does any good for a RS. |
#24 |
Member#: 158586
Keep in mind that although your car feels faster, you will get no gain in HP. The only difference would be how fast you are able to rev up. Again it reduces the load on the engine, which almost has the same effect as putting on a lightweight flywheel (or pulley). You are merely freeing up more power to the wheels.
#25 |
Member#: 70283
SWIC
There you go!! There's part of the next Periodic Review Of Nasioc video
| Thread Tools | |
| Display Modes | |
| gauges egt,oil pressure,& boost and pod looking to spend no more than 400shipped | jeremywrx15554 | Private 'Wanted' Classifieds | 2 | 06-04-2009 01:01 PM |
| FS: NJ CF Rad cooler, Alt cover & Hood dampers/ Prodrive oil cap & bat tie and more | ktulu990 | Interior/Dressup/Audio & Security | 19 | 11-17-2008 11:01 AM |
| 02 WRX part out - (gauges, shifter, knob, sti oil cap, morette, and more to come...) | silvscorp | Private 'For Sale' Classifieds | 40 | 10-18-2005 09:22 PM |
| boost, no boost, more boost...***!!1!11 | 03twrx | Factory 2.0L Turbo Powertrain | 12 | 11-05-2004 03:16 AM |
| Carbon fiber Belt Cover / Oil Cap / Boost Cover - On Ebay | ApexR | Private 'For Sale' Classifieds | 15 | 11-11-2003 12:36 PM |
