Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Gauges & Electronics
Closed Thread
Old 05-06-2008, 06:32 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default Sun Auto on Sale-Okada Projects Free Spark Plugs-Gauge Packages $499
Cyber Speed Hyper Ground System
The H.G.S. Cyber Speed Version is custom-tailored for the best fit and best performance in your vehicle. Giving your car a more efficient ground will help to pull out its full performance potential. The cables used are unlike anything else available: thick-gauge, 99.99% pure copper with 1477 strands per cable, 4-layered shielding, and gold-plated terminals. Designed to exceed stringent OEM specs for heat resistance and durability, these cables are the absolute best available. Cyber Speed Version kits have pre-determined mounting points to ensure the best performance and the cleanest installation.
$129 Shipped
Cyber Speed Hyper Force System
The Hyper Force system is the next gernation high-efficiency ignition tuning and strengthening system. It works by absorbing all back electromovtive force, which aids to improve plug voltage and promote complete combustion by producting 100$ coil efficiency. Also, the hyper Force System eliminates any ignition performance loss due to descreased electrical current under heavy throttle. Since ignition efficiency over the entire revolution range improves, available torque and acceleration response improves; this efficiency enhancement also contributes to better fuel efficiency and a reduction of harmful emission.
Hyper Force W/ Harness
$325 Shipped
Cyber Speed Hyper Voltage System
The H.V.S. Cyber Speed Version is designed to stabilize voltage in your vehicle for maximum battery efficiency, allowing its full potential to be released. H.V.S. Cyber Speed Version provides both function and stylish appearance; units are designed to fit perfectly for your vehicle, with specialized brackets and three additional grounding cables. The most secure and reliable mounting locations have been determined by our engineering and design team, to ensure an easy installation and excellent performance. An LED on the unit also operates as a system monitor, to alert you when your battery may need service or replacement.
$225 Shipped
Okada Projects Plasma Direct
The Plasma Direct is the ignition coil with a high power amplifier built in to it. The Plasma Directs produce 4 times more spark energy than stock coils and also generate an ultra fast multi spark discharge of 10 sparks up to highest RPM.
The spark amperage is increased 100%, allowing the spark to reach many more molecules and therefore accelerate the ignition and combustion process. This is extremely important in forced induction applications but also improves the performance of normally aspirated engines.
The Plasma Direct will increase horsepower and torque throughout the entire rpm range. This upgrade will also reduce fuel consumption. Even the engines with a legendary smoothness will be further refined with the Plasma Direct upgrade. Our Plasma Directs are OBD II compliant and C.A.R.B. approved.
Installation is easy. Direct bolt-in to the engine, no splicing or cutting into stock wiring, simply replace the stock coils with our Plasma Direct Coils and ready to go!
-100% secondary current (Spark Amperage) increase
-4 Times Spark Energy Increase for the initial spark discharge
-Easy installation. Only replace stock coils to Plasma Direct
-Compatible with all OEM components
-Compatible with OBD-II (On-Board-Diagnostics)
$599 Shipped
Okada Projects Plasma Spark
The Plasma Spark is the Spark Plug Boot (Socket) specially designed and developed to work as a secondary amplifier.
It creates strong sparks in very short time (nano-seconds), creating a faster flame front and quicker light-off of the mixture kernel to complete combustion. Installing the Plasma Spark, you can feel immediate torque up from low RPM and get more horsepower to the high RMP range!
Also installation is easy, direct bolt-in to the engine, no splicing or cutting into stock wiring. Simply replace the stock boots with our Plasma Spark Boots and ready to go!
-Creates strong sparks in very short time (nano-seconds)
-Creates Ultra fast spark discharge
-Easy installation. Only replace stock boots to Plasma Spark
-Compatible with Plasma Direct coils
Free Spark Plugs
$295 Shipped
Defi Gauges
The BF Series has a unique "masked" look that hides the gauge face until the car is started. Then you are treated with startup and shutdown sequences. These gauges are manufactured using the special manufacturing process used to by Defi's parent company to make many OEM gauge clusters such as for the STI. Defi BF Package 60mm(Black/White)
-Defi V2 Control Unit
-Boost + EGT + WT or OT
-ATI Triple Gauge Pod
$799 Shipped
Defi BF-R Package 60mm(Black/Red)
$799 Shipped
Blitz MD (Mirror Drive)
Identified by its "Mirror Face", the MD (Mirror Drive) Racing Meter features a carbon or white face and brushed aluminum bezel. The face of the gauge is back-lit with LED light bulbs and the needle is lit red. When the gague is off, the face disappears and your reflection can be seen, hence the name Mirror Drive. The MD Racing Meters are full electric gauges and are available in boost, oil/water temperature, oil/water pressure, and exhaust temperature. (Available only in 60mm, all gauges include necessary hardware and sensors.)
Blitz MD Gauge Package 60mm (Black/Red)
-Blitz MD Electronic Boost
-Blitz MD Electronic Water Temp
-Blitz MD Electronic Oil Temp
$699 Free Shipping
STRI DSD SLM
The Defi STRI premium DSD (Digital Stepper Drive) analog gauge series is the top choice among professional racers & race car builders. Full electric warning gauges with peak recall memory. All DSD senders are industrial grade to ensure most accurate reading under the toughest racing environments. Featured specs:
- Micro Stepping Movement high resolution and accurate readings
- Gearless noiseless operation / more durable
- Open / Closing Ceremony in sequences
- User preset warning values alarm by LED
- Peak Recall
- Automatic Self Calibration
- Short Circuit Auto Detect
- Racing Spec Sensors - Exteme Accuracy
- 270 Degree Full Sweep - High Resolution
- Sequential Open / Closing Mode
- LED Backlighting
- Reduce backlighting brightness for night time driving.
- Dimmer
STRI DSD SLM Gauge Package 52/60mm (Black/Red)
-STRI DSD SLM Electronic Boost
-STRI DSD SLM Electronic Water Temp
-STRI DSD SLM Electronic Oil Temp
$499 Free Shipping
Also Available in (Balck/ White)
Apexi AVCR Digital Boost Controller
Silver Edition
The AVC-R is a digital boost controller that allows the user to modify the boost pressure level on turbocharged vehicles. While there are many boost controllers on the market, none of the other includes as many features as the AVC-R, period. Despite all of the complex features included the unit, the AVC-R is flexible enough to be used by beginners. Entry level users need only to input a desired boost level and the AVC-R's trademark self learning CPU processor does the rest.
$499 Shipped
Turbo Timers
All Timers on Sale! PM for Price!
Gruppe-S is offline
Old 05-06-2008, 06:33 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Hydra Nemesis ECU
Stand-alone systems have been around for many years but the difficulty in finding good tuners, lack of tech support, poor base maps, difficult installations, and expensive price tags have kept them out of reach of the average consumer. Hydra has developed a superior engine management system exclusively for your car. Systems that piggy-back the factory ecu for engine control can become tiresome tuning. Hesitation is a common theme caused by rough transitions as the two switch control from the factory ecu map to the piggy-back map. With modern day “dynamic” engine management systems that widely vary ignition timing and fuel tables, piggy-back systems can often be difficult to tune as it is nearly impossible to stabilize the ecu over a wide range of conditions. Knock under throttle lift and transitions from the factory ecu map into the aftermarket ecu map can be difficult to tune out without severely limiting performance under all conditions.
-Capable of drive by wire control
-Launch control
-No lift shifting
-Capable of controlling AVCS
-Blow through MAF capability
-Capable of controlling 6 cylinder motors (EZ30R)
-Integrated 3 bar MAP sensor
-Wideband closed loop fueling (wideband optional)
-Secondary map triggering using primary map offsets
02-05 WRX
$1750 Free 02 Wideband
04-07 STi
$1950 Free 02 Wideband
AEM EMS (ENGINE MANAGMENT SYSTEM)
The AEM EMS is a full stand-alone engine management computer that replaces your restrictive factory ECU. The AEM EMS is fully programmable, direct plug & play, and fully capable of controlling all engine management functions. Fuel, ignition, boost, knock control, maps are all user accessible. Other features include soft fuel / rev limits, user definable inputs including wideband inputs, (requires wideband controller), 2 step control, etc. is all available. With it’s 32 bit processor, you can be assured this engine management computer is the state of the art technology for your Subaru. The AEM EMS is fully user-programmable, and can be controlled with your Windows ™ laptop.
The bottom line is that for big power the AEM EMS is an absolute must! The primary reason? MAF elimination and full fuel / ignition control. The factory MAF is maxed out at about 300-320whp, and to push anywhere beyond this level with the stock MAF causes an unstable and sometimes dangerous tune. (such as with larger than stock turbos).
We highly recommend the AEM EMS for any owner looking to have the capability for eliminating MAF and running pump gas / race gas maps on 320+ whp cars.
Please contact us if professional installation and dyno tuning is required. Installation Starts at $250.
Features : Plug and Play Technology! No Wiring Necessary Uses all the Factory sensors Fuel Table Automapping Base Maps Included Programmable Traction Control Onboard 512kb Datalogger 10cyl sequential fuel injection capability Much Much more!
Pm For Best Price
Greddy V-Manage
The V-Manage, Variable Valve Timing Controller was designed by GReddy engineers to take advantage of some of the modern technology OE Manufactures* are now commonly incorporating into their latest engines. Based on the intuitive controls, datalogging and Maps of the e-manage Ultimate software, a tuner with a laptop computer, can now alter the factory’s ECU control of valve-timing at any RPM and load to optimize power output and fuel economy. However by purchasing GReddy's application specific V-manage Kits, you can simply "plug & play." V-manage Kits, include the V-manage, CD software, Plug-in Harness with adapter, and Pre-programmed MAP to optimise cam timing for increase horsepower, toque, and boost response.
04-06 STI AVCS ENGINES ONLY
$475 Shipped
AIM Sports XML Gauge Cluster
-1 AMP + 2 binder connectors
-Lap Times & Split Lap Times
-RPM - numerical and graphical display tach
-Max RPM stored for later recall
-Total Run Time
-Gear Position
-Total and partial odometer
-8 analog sensor inputs for temperature, pressure, lambda sond, potentiometers, etc.
-1 wheel speed input.
-128 kb of non-volatile memory.
-Brilliant blue display with backlight.
-6 fully configurable alarm LEDs.
-10 fully configurable shift LEDs.
-Requires 8-15V power from vehicle. Auto Power OFF feature.
-Weight: 21.2 oz (600 grams)
-Size: 6.9"x4.3"x1"
$1099 Shipped
Gruppe-S is offline
Old 05-07-2008, 03:05 PM   #3
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Gruppe-S is offline
Old 05-08-2008, 02:59 PM   #4
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Gruppe-S is offline
Old 05-08-2008, 07:12 PM   #5
preacher#1
Top Scoob 022
Member Sales Rating: (17)
Member#: 129894
FSTI '04 4EAT Sierra
Gold Metallic 20G-XT, EWG
pm sent..
preacher#1 is offline
Old 05-08-2008, 07:40 PM   #6
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
All Pm'S replied
Gruppe-S is offline
Old 05-09-2008, 06:22 PM   #7
preacher#1
Top Scoob 022
Member#: 129894
Originally Posted by Gruppe-S View Post
All Pm'S replied
No PM on my end..
Old 05-09-2008, 08:03 PM   #8
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Originally Posted by preacher#1 View Post
No PM on my end..
Please resend
Gruppe-S is offline
Old 05-09-2008, 02:01 PM   #9
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Gruppe-S is offline
Old 05-11-2008, 04:18 PM   #10
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Gruppe-S is offline
Old 05-12-2008, 02:26 PM   #11
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Gruppe-S is offline
Old 05-13-2008, 01:48 PM   #12
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Gruppe-S is offline
Old 05-14-2008, 02:24 PM   #13
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
[COLOR=black][B]Please Note:[/B]
[I]- All Competitors Prices Beat
- All Items Are Shipped Via FEDEX
- All Orders Are Repackaged To Help Prevent Any Damage Which May Occur During Transit
- Any Order Cancellation Will Result In A 25% Processing Fee
- Local Pick-Ups Available[/I][/COLOR][I]
- [B][COLOR=Red]No Cancellation on JDM Or Special Orders. No Exceptions![/COLOR][/B][/I]
Gruppe-S is offline
Old 05-15-2008, 03:53 PM   #14
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 05-16-2008, 02:17 PM   #15
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 05-19-2008, 02:15 PM   #16
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 05-20-2008, 01:36 PM   #17
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 05-21-2008, 02:31 PM   #18
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 05-22-2008, 02:36 PM   #19
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 05-23-2008, 02:28 PM   #20
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 05-27-2008, 03:09 PM   #21
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 05-28-2008, 01:40 PM   #22
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 05-29-2008, 01:22 PM   #23
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 05-30-2008, 02:01 PM   #24
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 06-02-2008, 02:09 PM   #25
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Closed Thread
GRB STI Fitments-Ame TM-02 From $1460-All Enkei On Sale From $899-Free Rays Unbrella Gruppe-S Wheels/Tires 67 06-11-2008 09:19 PM
free Spark Plugs (NA 2.2) shemoves SWIC Private Classifieds 0 10-12-2007 11:28 PM
Need Help & Info on Blue Smoke, Turbo and Spark Plugs RonBang Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-05-2007 08:56 PM
Gasoline smell on 2 of the 4 spark plugs subynube Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-22-2005 09:12 AM
