Welcome to the North American Subaru Impreza Owners Club Saturday December 3, 2016
Old 05-20-2008, 04:51 PM   #1
Computergeek24
Member#: 108964
2013 Ford Focus ST
Performance Blue
Default A/C Clutch no engaging after compressor install?
Did some searches but couldn't come up with much (mostly because the search engine won't recognize "A/C" cause it's too short).
Anyway, when I bought my 04 WRX back in November, the A/C pulley had a horrible screech to it. So, not needing A/C in the winter, I pulled the belt off. Now it's about 5 months later and I finally got around to finding and installing a new compressor (From an 06 STi). I finished putting the belt back on, started the car up and hit the A/C button. The button lit up as normal but the clutch on the compressor pulley did not engage.
I know I will have to refill the system with refrigerant, but I wanted to check and make sure the thing worked first before starting to dump $50 worth of refrigerant into the system. I tried testing the 1-pin connector in the compressor with a voltmeter but got nothing (not even sure what kind of signal it uses).
Anyone have any suggestions as to why the clutch won't engage?
Any help would be appreciated!
-Kevin
Computergeek24 is offline   Reply With Quote
Old 05-20-2008, 05:30 PM   #2
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
The clutch won't engage if there is low pressure in the A/C system.
jey is offline   Reply With Quote
Old 05-20-2008, 05:43 PM   #3
Computergeek24
Member#: 108964
2013 Ford Focus ST
Performance Blue
That's just the answer I was hoping for actually. Thanks!
no heatshield after DP installed Nactos Newbies & FAQs 36 12-30-2006 09:18 PM
Help clutch not engaging after engine install racrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-12-2006 11:04 PM
no CEL AFTER header install...? jefersun Engine Management & Tuning 1 03-13-2004 11:15 PM
No CEL after DP install wrxpeed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 01-22-2004 01:00 PM
car no start after CAI install? help please Solomon Normally Aspirated Powertrain 12 07-30-2003 01:31 AM
