Old 05-30-2008, 06:09 PM   #1
Mobutusan
Member#: 118017
2004 WRX Waggin'
Default DIY Front Lip - Version II
Version II Garage Door Lip Hahaha!
(Work in progress, still tweaking and updating...)
*FYI, all pictures were taken after driving ~500 miles over the last week. The lip scrapes coming into and out of my driveway, as well as many other places, and is holding up very well so far. Cleans up easy with Simple Green and a cloth.
I just got done doing this to my '04 WRX Wagon, and I thought I'd share. It's a different enough take on the DIY lip that others have done, that I thought it could use its own thread. I love how it came out.
This design covers most of the unsightly scrapes on the bottom of the bumper, and evens out the bottom of front bumper.
*This is for a stock '04 bumper without side splitters. I'm sure the method will be similar for other models, years, but I don't know for sure.
Materials:
EPDM foam rubber garage door sealer (same as in other threads. got mine from Lowe's for $16)
Double sided sticky tape (normal scotch tape style, not foam tape)
Small foam blocks or something similar. (should be stiff/hard material that can be cut with a sharp knife to specific shape. I had some foam blocks left by Stanley Steemer that are used to put under furniture after carpet cleaning.)
Self tapping screws ~3/4" (15-20pcs.) ~1.5" (5-10 pcs.)
Washers ~1/2"-1" wide (20-30pcs.)
Step 1: Cut the garage door sealer in half, into two sections that should be more than 90" long.
Step 2: Lay out both sections flat, and run strip or two of double sided tape along the top of one section. Carefully stick second section to first section so the cross section looks like the picture.
Step 3: Cut some foam blocks into sections with a trapezoidal cross sections about 25mm wide, 17mm tall on one side, and 20mm tall on opposite side. These pieces go between lip and bumper to even out the raised center section when mounting the lip.
Step 4: Fit lip around bottom of bumper, secure with screws and washers.
Step 5: (More details to come...)
Garage Door Material
Lip Cross Section
Prepped Lip
Before (Lots of ugly scrapes)
After
Close-Up
Finished Product
For more reference, check these threads:
http://www.clubwrx.net/forums/exteri...p-wrx-8-a.html
http://forums.nasioc.com/forums/show...hreadid=395394
http://forums.nasioc.com/forums/showthread.php?t=583184
http://forums.nasioc.com/forums/show....php?t=1275327
http://forums.nasioc.com/forums/show....php?t=1389639
http://dirtyimpreza.com/forums/showthread.php?t=3032
Mobutusan is offline   Reply With Quote
Old 05-30-2008, 06:13 PM   #2
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
4eat Stage 2 Protuned
I like it, good job.
eurospek is offline   Reply With Quote
Old 05-30-2008, 06:15 PM   #3
Paranoid Fabrications
Member#: 140712
2008 WRX STI
nice job. looks very clean
Paranoid Fabrications is offline   Reply With Quote
Old 05-30-2008, 06:19 PM   #4
smurfwrx
Member#: 151928
09 Triumph S3
good write-up. nicely done. good work, man.
smurfwrx is offline   Reply With Quote
Old 05-30-2008, 06:20 PM   #5
RS Guy1513
Member#: 102812
05 CGM 2.5 RS
07 Triumph Tiger 1050
very nice!! looks better then the single piece one that everyone (myself included) does
RS Guy1513 is offline   Reply With Quote
Old 05-30-2008, 07:19 PM   #6
wrxguy02
Member#: 174672
02 AW WRX
02wrxX2,06sti,94wgn,04sti
very nice....i like it alot more than my single layer
but will it work on the best imprezas of all... the bugeyes?
im going to attempt this tommorow and see if it works on my car, nice idea sir
wrxguy02 is offline   Reply With Quote
Old 05-31-2008, 06:16 AM   #7
thrasher
Member#: 40579
2002 WRX Stage 2+
Tuned by IA Performance
That looks really good, but I don't think it will work as well on the bugeyes because of the shape of the bumper bottom, and the fact that the brake ducts are so close to the bottom edge. I'm sure with some custom fabrication, it could be made to work though. I'm sure NASIOC will find a way...
J
thrasher is offline   Reply With Quote
Old 05-30-2008, 07:35 PM   #8
Mobutusan
Member#: 118017
2004 WRX Waggin'
Thanks guys. ^^^ Be sure to post some pics.
Old 04-20-2011, 10:44 PM   #9
NutWagon
Member#: 230925
04 WRX Wag Stage 4
06 Impreza 2.5I
I just bought mine, Gonna try it on an 06, We will see how it goes. Fingers Crossed.
NutWagon is offline   Reply With Quote
Old 05-30-2008, 08:04 PM   #10
SiFuSpEc
Top Scoob 008
Member#: 77299
'05 2.5RS
#78 ST, MAXIMUM ATTACK!
very very nice job!
SiFuSpEc is offline   Reply With Quote
Old 05-31-2008, 12:46 AM   #11
dave_88
Member#: 65864
WRX gone; hate the
Honda forums so much.
that actually does look good. as a bugeye wagon owner, i'm going to try this.
dave_88 is offline   Reply With Quote
Old 05-31-2008, 12:48 AM   #12
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I don't normally like DIY front lip, but I gotta say good job.
txl146 is offline   Reply With Quote
Old 05-31-2008, 12:53 AM   #13
SUBYDOODIE
Member#: 71490
05 cgm wrx
rubbing axles haha
damn it does look pretty good...
SUBYDOODIE is offline   Reply With Quote
Old 05-31-2008, 12:58 AM   #14
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Wow v2 DIY lip rocks!
djerickd is offline   Reply With Quote
Old 05-31-2008, 01:30 AM   #15
wrx_eD
Member#: 104896
wow! props to you!
wrx_eD is offline   Reply With Quote
Old 05-31-2008, 01:30 AM   #16
B00st3dWRX
Member#: 140978
02 WRX WRB
i-Nertia Dynamics
V2 Ftw!!!!!!!
B00st3dWRX is offline   Reply With Quote
Old 05-31-2008, 02:15 AM   #17
silverF4turbo
Member#: 20492
4 -valve Derper
Let's JDM styling!
Version 2 doesn't look DIY - looks like a real lip like V-limited hotness
awesome job
silverF4turbo is offline   Reply With Quote
Old 05-31-2008, 02:26 AM   #18
posite
Member#: 165055
09 335i ..tuned
wrx 18g ewg fmic meth
very nice thinking!
posite is offline   Reply With Quote
Old 05-31-2008, 02:43 AM   #19
the wagon
Member#: 116714
Wow that looks great. Hmm Bugeye anyone??
the wagon is offline   Reply With Quote
Old 05-31-2008, 02:53 AM   #20
Mobutusan
Member#: 118017
2004 WRX Waggin'
^^^I am very curious to see if this works on other years too. Anyone who makes this work, be sure to post pictures.
Old 05-31-2008, 03:00 AM   #21
Mechie3
Member#: 120152
The double layer makes it look really smooth and even. Nice work!
Old 05-31-2008, 03:47 AM   #22
iheartmysuby
Member#: 83638
def looks better than og version on 04.
iheartmysuby is offline   Reply With Quote
Old 05-31-2008, 06:51 AM   #23
xdrian
Member#: 104200
000 WHP BUGEYE
Street Proven Performance
nice work!
xdrian is offline   Reply With Quote
Old 05-31-2008, 08:57 AM   #24
STIckySTIfee
Member#: 162812
2004 STI
awesome work, good thing about the double layer is that it covers up the scuffs and gashes in the bumper cover
STIckySTIfee is offline   Reply With Quote
Old 05-31-2008, 09:49 AM   #25
ADAS1223
Member#: 159853
2005 Impreza
wrb
THAT rocks. I love my diy diffuser. dare i say, but it looks expensive. like the rally type lips
ADAS1223 is offline   Reply With Quote
Finally did my DIY Front Lip.... JoeSUBARU Member's Car Gallery 154 03-03-2013 07:57 PM
Can you say DIY front lip? J-Chow Vancouver Impreza Club Forum -- VIC 52 07-26-2009 07:34 PM
DIY Front Lip!! turbowagon02 Member's Car Gallery 116 07-18-2009 09:30 AM
Another DIY front lip txl146 Interior & Exterior Modification 5 04-30-2007 09:53 AM
post your STI front lip. Version I or II please ! trustz Member's Car Gallery 24 09-18-2002 03:53 PM
