#1 |
Member#: 126740
South East
Vehicle:2001 Swapped 2.5 RS Blue |
I'm done tearing apart a wrecked 2002 WRX and I'll be starting to take apart the RS this week. I'm keeping the RS drivetrain and the wrecked WRX has a new clutch that I'd like to use. I know the WRX has a pull type clutch and the RS has a push type. Anyone know if the pull type setup can be adapted over to the RS trans so I can use the new WRX clutch? It would help me save a few dollars from having to buy a new clutch for the RS trans while doing the swap.
Thanks! David L. |
#2 |
Member#: 177
Vehicle:The 93 Imp W/EJ20K flat black |
simple answer
--->no<-- |
#3 |
Member#: 15543
Vehicle:90BJ Legacy LS ABS AWD 946 Rio Red Jpn built |
Couldn't he put the WRX clutch disk into his RS flywheel and pressure plate?
#4 |
Member#: 156829
SCIC
Vehicle:05 legacygt,00 OBS red 95 supercharged nsx |
no u have to get a clutch made for your tranny
the 01 rs tranny not the 02 wrx only way u can you that clutch is with a 02 wrx tranny(or newer) |
#5 |
Member#: 126740
South East
Sucks, guess I'll be clutch shopping. Thanks for the help.
David |
#6 | |
Member#: 15543
Do you think pull style clutches came out with the 02 WRX? If so I'd like to introduce you to the 1991 Legacy Turbo which happens to use the "02 WRX tranny(or newer)" style of clutch. ![]() |
#7 |
Member#: 126740
South East
While we're at it, anyone have a favorite clutch for such an RS swap? I think the stock exedy wouldn't be enough.
#8 | |
Member#: 90750
SWIC
Vehicle:2000 RS EJ207 Hybrid 05 Ducati Monster S2R |
#9 |
Member#: 119995
W. Canada
Vehicle:2004 Outback XT Peachy |
I would still use the WRX tranny. The longer gears are really nice while you're in boost, short gears + boost can get annoying.
#10 |
Member#: 15543
I'm using the act clutch kit SB2-HDSS on a 98 RS with an 05 STI swap. The kit has the "performance disc" and the heavy duty pressure plate. The pedal is a little firmer than stock but once adjusted properly its very easy to drive.
#11 |
Member#: 126740
South East
Dag,
That clutch is $475. I paid $365 for a spec stage 3 clutch a while back for a different project and thought that was expensive. I'm going to cheap out in the short run and just install the WRX tranny and its rear end. I'll keep the RS stuff for if and when I feel like swapping that over. David |
#12 |
Member#: 126740
South East
With fire extinguisher readied, it started on the first turn of the key. Only the airbag light is on since the seats aren't connected. I need to bleed the clutch and fasten on a few things and it should be on the road. Its been just under two weeks since tearing up the RS and I need the car now since my truck decided to mess up.
David |
#13 |
Member#: 152176
Vehicle:2001 2xImpreza 2.5RS BRP/SRP |
i got act hdr4
look around on forums and ebay for clutches. could snatch it up cheap |
#14 |
Member#: 126740
South East
The car has been doing well over the past few weeks, no real issues other than the clutch is now slipping so now I'm thinking over putting the RS tranny and rear back in and upgrading the clutch and maybe flywheel. Anyone know if an upgraded RS clutch can be used on a WRX flywheel? I hope so b/c I sold the RS engine three weeks ago, if not, then I guess I'll be buying a lighter flywheel as well.
Thanks, David |
#15 |
Member#: 151248
AKIC
Vehicle:00 Impreza 2.5RS Whore Door |
Hey a few things you need to know...
The rs tranny isn't really made to take the abuse of a modded turbo engine so you may begin to lose gears and blow the tranny basically. A stock weight flywheel will help save on teh trans some, but don't go with a puck style disk becuase it will be really hard on the trans. Exedy makes some of the most reliable stuff it seems for subie and I love my stage 1 organic I have on my 98 leg. I will be using my stock flywheel and that clutch on my wrx swap in my leg. However I will be using all my legacy parts...keeping thigns with teh trans... I'd suggest just getting an organic clutch and using the rs tranny...they seem to be just as decent at the new wrx trannies becuase they both don't like abuse or get a mfactory set and beat the piss out of it...talk to dylan at ds1 if you have any ?'s relaly nice guy and the person i got all my info from |
| Thread Tools | |
| Display Modes | |
| JDM V7 wrx wheel installed into 2001 RS airbag question | scooby_snacks_imprez | Interior & Exterior Modification | 4 | 10-21-2006 02:27 PM |
| 2002 WRX Radio in 2001 RS | thetrev8588 | Electrical & Lighting | 1 | 10-19-2006 03:32 PM |
| 2.2 swap into 2001 rs | bryan2.5rs | Normally Aspirated with bolt-on Forced Induction Powertrain | 12 | 07-15-2003 02:23 PM |
| ('93-'01) besides HP, why is 2002 WRX better than 2001 RS? | Shrubba | Impreza Forum | 14 | 04-10-2001 04:10 PM |
